Is there a way to stay in just eletric?
Discussion in 'Gen 2 Prius Main Forum' started by tracysbeans, Jan 11, 2006.
  1. tracysbeans
    tracysbeans Member
    979
    Wisconsin
    But alot of my driving is at 34mph or less!
  2. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    Their FACT sheet only advertises PROS area and no CONS Facts was written.
    Their first Prius conversion used lead-acid batteries.(page-2 of the fact-sheet)
    Ron Gremban reported that the $700 battery lasted only 200 cycle charging and the battry cost was $0.35/mile.
    http://autos.groups.yahoo.com/group/priusplus/message/519
    Ken@Japan
  3. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    The only one worth getting at that price would be the LiIon one... but even at higher speeds, they implied that you still save gas because of the huge reserve to store regen and the ICE would not have to work as hard as it could use some the the battery energy. Its a perfect Idea, but the prius is not yet ready to utilize it in its "perfect state"....
    Yes, you could use it now in pure electric with an EV button, you would just be limited to a few miles 2 - 4 until the ICE came on by force to charge the batteries.
    The novelty of what your wanting to do may wear off in time.. I don't know. But from what I have read, "purposely" using EV mode till you milk the battery dry does not save energy since there are conversion losses and the ICE just has to make it all back anyway... but it "may" be fun!.... sometimes fun is more important than gas savings.. especially if its just for short special periods.
    You can get an EV button for about 50 bucks and then get someone to install it for you..... meanwhile the 12K price of these cool kits will come way down. Batteries are getting cheaper and better and if Toyota doesn't incorporate it, someone else will "if" its usable.
    Thats what I fear... its not too usable for the price!.....
    If you could charge your car all night and then use the energy at full freeway speeds so as to not get ran over and take twice as long to get to work, then people would use it and the demand would make it profitable and cost effective to produce it. Until that happens.. its just a fun project that may not get off the ground. Toyota themselves can simply add another battery or two in parallel and simulate the same thing they are doing.
    Right now, we could buy extra prius batteries and wire them in parallel and get the exact same effect they are doing. But we need some way to reprogram the computer.
  4. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    Paralleling the NiMH batteries do not work that way.
    It is a bad idea to connect NiMH batteries in parallel.
    Ken@Japan
  5. windstrings
    6,280
    378
    Central Texas
    I've never heard of that?.... do they have a hard time staying balanced with each other?
  6. Tideland Prius
    16,559
    Nono, all that is already programmed into the computer at the factory. All dave's device does is add a switch with the usual wires to ground and to send the signal.
  7. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    They are not going to balanced state, but they are going to be unbalanced.
    The only lower internal resistance pack works harder and higher internal resistance pack works less.
    Charging the NiHM is done by current and NiMH should be charged in series.
    OTOH, charging the lead-acid is done by voltage and they should be charged in parallel.
    Ken@Japan
  8. EricGo
    EricGo New Member
    1,805
    Albuquerque, NM (SouthWest US)
    I cannot understand why a 34 mph limit would exist.
    addendum ..
    Wikipage published by the Seattle EVA folks.
  9. windstrings
    6,280
    378
    Central Texas
    Yea, but even the NiMH get voltage to pass the current... no current is passed without voltage?... thats the pressure that pushes the current or amperage.
    Without voltage nothing is going to get charged no matter what kind of battery it is?
    Are you trying to say that they all need the same amount of current? If so lead acid works the same way since they are only 2 volt cells.
    I have studied Lead acid extensively, but not NiMH.... I didn't have access to those when I was off the grid.
    So I will guess, you can correct me if I'm wrong:
    Since NiMH take such high fluxes of current "or are capable of".. I see how it may be easy for several banks to get out of balance with each other if they are not prefectly matched. Cells become matched with "time".. to bring up the weak cells to match the good cells that charge faster and easier. With quick charge discharge duties like the prius battery has.. it may be that the weaker cells would "never" get fully charged and just be a load on the system without benifit?
    Normally if all the banks in parallel are the same age, type, size and capacity there are no problems.
    Because if there is a weaker bank, then like you say, the weak one is lazy and sucks all the charge current with its lower voltages and then keeps it back when in discharge and lets the good bank do all the work. The resulting effect is that the good banks are overworked and brought down to the level of the weakest bank.
    but I have always messed with Lead acid in such cases.
    Anyway, if this is really the problem, then Toyota will only be able to increase battery capacity for the prius as technology allows for the individual cells to be larger.
  10. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    Sorry, but I have no time to discuss about this.
    I'll let anyone to explain more.
    If you found a good professional application using parallel NiMH, please let me know.
    Anyway, there is a same kind of debate...
    - How do you connect tungsten lamps together, series or parallel?
    - How do you connect LED's together, series or parallel?
    Yes.
    Toyota RAV4-EV has 95AH cells.
    Ken@Japan
  11. tracysbeans
    tracysbeans Member
    979
    Wisconsin
    Can you discuss bringing me one of those dark blue Priuses from over there :huh:
  12. maggieddd
    maggieddd Senior Member
    2,090
    Boston
    Here for you
    [Broken External Image]:http://www.ribghe.org/Maggie/blueprius.jpg
  13. tracysbeans
    tracysbeans Member
    979
    Wisconsin
    Oh I though it was darker than that. I though it was almost Navy. I guess I like my black better. So far blacks the best color to me on a Prius.
    Weird that I like black for a car cause I don't like anything else black. I wouldn't think about wearing a black top. Washes my face out. I like wearing bringht colors like lots of red and blue!
    I think the white Prius are pretty nice too. I didn't like the new red which suprises me because I have owed alot of red cars. I had a red camero that was a sharp looking car!
  14. benighted
    benighted New Member
    530
    Westport, WA
    I second that notion.
  15. benighted
    530
    Westport, WA
    The 34 MPH limit exists because the cooling system for the electric motors would have to be bigger and heavier.
  16. EricGo
    EricGo New Member
    1,805
    benighted:
    I can imagine the LiIon battery pack having increased heat dissipation req's, but the M/G's are stock. And w hy would that be a speed limit, and not a power limit ?
  17. maggieddd
    2,090
    Boston
    well then, now all your worries are over and no need to cry any more. The color you want simply does not exist on a Prius :p
  18. tracysbeans
    tracysbeans Member
    979
    Wisconsin
    No the color does exist and it's black!
  19. maggieddd
    2,090
    Boston
    OK, so the color that you've been wining about that you wanted to have brought to the States from Japan :p
  20. tracysbeans
    tracysbeans Member
    979
    Wisconsin
    Well I though I like that color until I saw closer up pic of it.
    So so far black is my color. BUT maybe there will be another color that comes out I like better. I doubt it though.
