Is there a weight in the hatch?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by ghostwheel, Mar 7, 2021.
  1. ghostwheel
    ghostwheel Junior Member
    30
    Santa Fe, NM
    I installed an internal button to open the hatch in my Prius Gen 2. While digging through the hatch I discovered a piece that simply looks like an additional weight. It is located in the center bottom of the hatch. Just above the lock. I took it out, and it doesn't seem to be connected to anything else. Since my pneumatic mechanism (already replaced once) isn't the strongest any more, I decided to leave it out.
    Does this weight have any other purpose?
  2. ChapmanF
    15,629
    Got a photo?
    49,500
    is it shaped like a dumbell?
  4. ChapmanF
    15,629
    Is it bigger than a breadbox?
  5. ghostwheel
    30
    Santa Fe, NM
    Oops, sorry, didn't track.
    Here are some images. It's around 960g
  6. ChapmanF
    15,629
    Vibration damper, exactly as described in the video in post #2.
  7. ETC(SS)
    6,555
    Your hatch doesn't NEED a weight.
    It's pretty heavy just being a hatch.
    If you want to see how heavy, take the lift assist struts off of it for a day or two..... ;)
  8. bisco
    49,500
    if everything works fine, and the hatch opens easier, leave it out
  9. ChapmanF
    15,629
    and you don't mind the vibration
  10. ghostwheel
    30
    Santa Fe, NM
    I took it out some time ago. Works well. Though now I'll start noticing the vibration ;)
  11. bisco
    49,500
    ignorance is bliss, i should know :cool:
