Is there anything I can do to stop my catalytic converter from eroding? (See pic)
Discussion in 'Gen 2 Prius Main Forum' started by Ian Simons, Jul 4, 2020.
  1. Ian Simons
    Ian Simons Junior Member
    48
    Lake arrowhead
    I’m at the end of my 2nd caddy in four years. I’m concerned because after the second one was installed, the underlying problem that undoubtably existed was never diagnosed.
    I pressed the technician for answers, and his response was that the amount of labor it would take to diagnose the problem could tally three quarters of the car’s value, and even then there wasn’t a guarantee.
    I mean they couldn’t even give me a theory, which could of gave me some direction on what to do.
    So here’s what i know: I’m almost at 150,000 miles. I’m burning oil a little faster than I use to, and my converters keep clogging up and dying (see picture).
    I read installing a oil catch can won't stop oil use, but It will catch a lot of it from burning in the engine, and possibly help the cat.
    Does anybody have any other theories, remedies or solutions that they think may apply here?????
    #1 Ian Simons, Jul 4, 2020
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    @m.wynn has boiled his before :).
    It's gotten him through the NY inspection 2 cycles now;).
    He'll be along eventually and can show you his home brew boiling method(y).
    SFO likes this.
  3. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Thank you for the image, though it is hard to see if the Cat is eroding, or if it is just plugging up with carbon and SAPS.
    If the CAT in that image is under a year old, then installing a OCC would be a good idea, even if it didn't prevent future issues.
    Some have switched to a heavier oils, done oil flushes and additives, some have tried piston soaks, some replaced the valve stem seals, some have soaked the cat to remove the build up, the list goes on and you may want to try all of the options, or spend 2k every year on a cat.
    What weight/brand and type of oil do you currently use?
    Have you tried engine flushes or piston soaks to potentially mitigate the oil consumption issue?
    Raytheeagle likes this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,237
    5,937
    Columbia, SC
    What catalytic converter is it? Is it a Toyota OEM replacement or aftermarket?
  5. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,790
    2017 Prius c
    PLEASE STOP posting about the same subject in multiple threads.
    This should have gone in the OTHER cat converter thread that you started.
    And some of those questions have already been answered there.
    For instance, the catch can mod is NOT intended to protect the cat; it is there for other reasons.
  7. Ian Simons
    48
    Lake arrowhead
    It’s Toyota under warranty.
  8. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Since it's under warranty, then the dealer should be replacing it for little or nothing.
  9. Kenny94945
    Kenny94945 Active Member
    784
    400
    Sausalito
    2016 Prius v wagon
    Under warranty, so the cat replacement issue is cured?
    Yet, OP is concerned that there is an underlying problem?
    My 2 cent comment would be, noting the OP oil use comment, would be to first do a leak down test.
    See if there is a head gasket or valve stem seal issue leaking oil into the exhaust chamber, thereby clogging the cat.
    Also noting the OP states "keeps clogging", so how often?
    Catch cans can help reduce the amount of oil recycling through the heads and intake, with a cost of around $100 or $200.
    The "old style" full throttle "tuneup" might also help, in other words race around/ accelerate aggressively ever so often.
    Also inspecting the spark plug condition may add some insights, inspecting now and after the tune up.
    Yet repeating a leak down test is where I would start and I might doubt that would be a warranty covered test, but ask the dealer.
    Good luck.
  10. ETC(SS)
    6,564
    Last time i looked at a map, The OPs location put them behind the tinsel curtain, so OCCs are a no-go.
    I'm very skeptical of a car that's burning sooo much oil that it's fodding out a cat in 2 years.....in California.
    Is San Bernardino county asking you if they can borrow your car for mosquito control?
    How is it POSSIBLY passing a smog test burning that much oil?
    The first thing I would do is close the loop on the Toyota warranty thing....AT ANOTHER TOYOTA DEALER.
    If they fix it?
    You're good to go.
    If they don't, then you're going to have to navigate the wonderful world of cat replacements in the PRC, for G2 owners, and I would lean away from continuing to pour money into the car at the dealer.
    If Toyota won't fix it, see what 2-3 independent muffler shops in your area have to say about it.
    They'll be a little surprised at how quiet your car is when you drive up, but they will be able to close the loop on what is going on with your cat (or O2 sensor.)
    Good Luck!
  11. bisco
    49,519
    look at the brighr side, no one has stolen it
    SFO likes this.
