Is there anything that I can do to fill the Prius gas tank to capacity (or 10-11gal.) in the winter?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rubberpill2002, Feb 17, 2009.
  1. rubberpill2002
    rubberpill2002 New Member
    Wilmington, DE
    I have a 2009 Prius which I fill up at 2 bars on the gas gauge, but it will only take 6 gallons or so. Is there a way to fill it the full capacity or at least close (10-11 gallons). There has to be some where to stretch out the bladder in the winter...
  2. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Re: Is there anything that I can do to fill the Prius gas tank to capacity (or 10-11gal.) in the win
    In the winter no. In the summer, fill it up, push the car side-to-side to burp the tank, fill more, repeat until your satisfied.
    Wayne
  3. judymcfarland
    judymcfarland Queen of Moral Indignation
    578
    Glendale, WI
    Oh man, the youngest child is almost 40 & now I have to start burping my "baby"?
  4. patsparks
    10,664
    567
    Adelaide South Australia
    Yep, but no need to hold it over your shoulder or change nappies.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    At two bars a six gallon fill *is* capacity, especially in cold weather. You have to run it dry to get ten gallons.
    Tom
  6. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    I wait until blink.
    That consistently means 8 gallon refills, regardless of distance or season.
  7. Graz
    Graz Member
    178
    28
    I have NEVER pit more than 10 gallons. I drive until I hear the beep then I set Trip A to zero. I have NEVER run out of gas. I have had over 40 miles on the TripA meter after the alarm went off. Though I rarely go far over 400 Miles per tank. I sometimes even get three weeks on a tank!
    In my years of surfing PriusChat I have decided that we "Prius People" need to be a little less anal about completely filling each tank. There are too many differences in the counter pressure sensors of all the various gas pumps to get a consistent fill anyway. Add to that the issues that the gas bladder add to the mix. Temperature, Time of day… There are too many variables in the formula.
    Granted... I say all of this knowing that I have an Excel spreadsheet with every cent I have ever spent on this car. EVERY tank full. Every wiper blade. Every filter. Everything! If I had access to that data now I could confirm that I get something like $0.45 per mile. (I think it should be better than that too).
    Happy Priusing!
    :rockon:
  8. fgoodyear
    fgoodyear New Member
    187
    Tillson, New York
    Winter in upstate New York...... I get the blink and the "add fuel" light....... I drive another 15 miles and put in 10.2 gal. The outside temp was apx. 28 degrees. In the summer, if I let it get to the "blink"... which usually I don't, I have put in 11.5 gallons as the tank is 11.9 capacity. I do have to burp it. If this is overfilling, then something is wrong. If the capacity is 11.9 it should hold 11.9 without doing any damage. I have 45k on it and have yet to have any problems.:cool:
  9. richard schumacher
    7,663
    1,038
    United States
    Resist the temptation to top off. It risks spilling fuel and increases hydrocarbon emission pollution.
