Is this a big Boo Boo?
Discussion in 'Gen 3 Prius Technical Discussion' started by Taxi/Limo, Sep 22, 2016.
  1. Taxi/Limo
    Taxi/Limo Active Member
    526
    107
    Hello All
    I ran a wire down the hole that goes from the A Pillar to the fuse area of my 2010 Prius in preparation to power my camera
    How I did it was I used a coat hanger to find the hole and then taped the camera wire including the little plastic fuse receptacle on the coat hanger and pulled it though
    The wire came through but the little plastic fuse receptacle with the fuse got stuck
    so I pullled the wires through down to the fuse box and left the little fuse receptacle in there
    I can get another inline fuse receptacle
    Now the little fuse and plastic receptacle are stuck in that passage with whatever else is in there
    Do I need to worry that this may cause problems later?
    Does it get hot down that tube or does a lot of electricity go through there?
    Newbie Just wondering
    Thanks
  2. Bluegrassman
    Bluegrassman Active Member
    229
    185
    US
    What happens when that fuse blows and you can't replace it? Might as well do a whole new run
