Is This A Coolant Leak?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Aaron, Jan 27, 2013.
  1. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Thanks John. I appreciate all your help with this.
    DROID RAZR ? 2
  2. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    My pleasure, let us know how things work out.
    John (Britprius)
  3. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    You might consider marking the drain plug for the inverter coolant to see if they just pinch the hoses and replace only the pump or if they actually drain the fluid and possibly replace it. Or you could see if they will let you watch the repair, but, I have yet to see that happen.
    Avi
  4. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Great idea. Where can I find the Inverter drain plug.?
    DROID RAZR ? 2
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  6. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Got the car back from the dealer today. They replaced the Inverter Coolant Pump per the recall. Coolant was replaced as well. The Engine Water Pump was replaced free of charge as it was still under my Platinum Warranty (6 year/100K miles). All engine coolant was replaced as well without charge. While they were replacing the Water Pump I had them also replace the Serpentine Belt since I am at 85K miles. Thought it was a good idea so I didn't get charged for labor. The belt cost me $24.
    PriusGuy32 and JimboPalmer like this.
  7. Britprius
    5,194
    1,922
    All in a great outcome. Now no need to change coolants at 100,000. As a foot note to all this have you changed the transmission fluid (oil) if not I really recommend you do this even though Toyota do not require it. It is good insurance for transmission longevity. Do not let the dealer sell you a flush and the total cost should be no more than $100. Fluid used should be "Toyota WS".
    John (Britprius)
  8. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Yes, I changed the transmission fluid myself at around 50K. Drain and fill. It was super easy.
    How many miles until my next coolant change? I read somewhere it's not 100K the second time around.
    DROID RAZR ? 2
  9. Britprius
    5,194
    1,922
    The next coolant change us not due for 50,000 miles but you could reasonably stretch this given your millage to the normal change service point at 150,000.
    Glad to hear you've changed your transmission fluid I would change this again at 100,000 miles.
    John (Britprius)
  10. K8A
    K8A New Member
    Boise
    Water pump is not the only one cause for the coolant leakage!
  11. Avi's Advanced Automotive
    776
    363
    Who put that faulty o-ring in? I doubt it's the one the factory installed.
  12. K8A
    K8A New Member
    Boise
    it probably was never replaced for 200k miles. it was pretty stuck there.
