Is this a Faulty Cable Clockspring?
Discussion in 'Gen 3 Prius Main Forum' started by Ron Blake, Sep 25, 2022.
  1. Ron Blake
    Ron Blake New Member
    Perth Western Australia
    Gen 3 - 2010 Prius
    All the controls on my steering have failed including cruise control, all radio controls, and the menu system, only the horn works.
    The car runs fine but I have an airbag warning light on the dash.
    From reading on the forum it relates to a faulty clock spring, I plugged in OBD Reader I have the following codes, am I looking at something more serious? or could a defective clock spring bring these codes up.
    U0155
    Raw code: C155
    ECU: Gateway
    Status: Confirmed
    OBDII: Data bus, instrumentation control module - no communication
    U0142
    Raw code: C142
    ECU: Gateway
    Status: Confirmed
    OBDII: Data bus, body control module (BCM) B - no communication
  2. Tombukt2
    Tombukt2 Senior Member
    13,855
    2,515
    Durham NC
    Sounds like it . What happened in my Gen2 also. Quickly replaced 45 min . All restored.
  3. ChapmanF
    19,012
    I don't think those U codes would result from a faulty spiral cable ("clock spring").
    But those U codes could explain some of your symptoms. (Spiral cable could explain some too.)
    If the car were mine, I would go through the troubleshooting for the U codes first. After those issues were squared away, then I would see if any symptoms remained that would suggest a spiral cable problem.
  4. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    I had the same symptoms and it was the clock spring. I purchased it off of eBay for 30$ working great so far.
  5. Ron Blake
    Thanks for that, I have ordered a clockspring from Ebay, I have noticed when I turn the steering wheel at a certain position the controls work including the cruise control indicator, so hoping its just the clock spring.
  6. Ron Blake
    Thanks, everyone, I have ordered a clockspring from Ebay, I have noticed when I turn the steering wheel at a certain position the controls work including the cruise control indicator, so hoping it is just the clock spring.
  7. Tombukt2
    13,855
    2,515
    Durham NC
    That's why I replaced without worrying of codes . Of course theyres comm errors Duh the cable mis communicates at various rotation points . Yeppers . Good job man .
  8. ChapmanF
    19,012
    Of course, those codes are specifically comm errors between the gateway ECU and the combination meter, and the gateway ECU and the body ECU, and none of that communication goes through the spiral cable, as a wiring diagram will show you.
  9. Tombukt2
    13,855
    2,515
    Durham NC
    But if we move steer wheel.and things be intermittent. Then I would probably have to say the connection is shoddy between the steering wheel buttons and what connects it to the rest of the car which is I guess this cable do flachi. At least was in a few of mine so far. Thank goodness my Corolla AE cars don't have this too many to replace.
