Is this a G2 design?
Discussion in 'Gen 2 Prius Main Forum' started by Hal W, Jan 17, 2011.
  1. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    When the time comes to fill my tank I notice the cap is always loose when I remove it. I always give the cap three clicks when tightening it. Why is it loose when I want to add fuel?:confused: Hal
  2. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    hmmm. .mine doesn't do that. I thought it would light up the dash if the cap wasn't sealed.
  3. Tideland Prius
    16,445
    It shouldn't be loose.
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Is it the original cap? It should only click once when tight and should not loosen.
  5. Hal W
    Hal W New Member
    872
    53
    Yes it is original.The car only has 20,000 kilometers on it. No effort what so ever to remove it. No lights coming on! I give it three clicks when I put it on. I guess I will check after a few hundred kilometers. Hal
  6. Patrick Wong
    18,200
    6,492
    1. I suggest that you take a look at the O-ring which seals the gas cap, to make sure it is not damaged.
    2. It is only necessary to turn the gas cap to one click when tightening it.
    3. If the check engine light does not come on, then no worries.
  7. wmcbrine
    wmcbrine Junior Member
    56
    Laurel, MD
    I kinda thought the same thing about my cap. No warning lights.
