Is this a leak?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by marooned, Oct 14, 2019.
  1. marooned
    marooned Junior Member
    Metro Detroit
    2010 Prius with 125k miles on it. I spent a couple daysv recently cleaning out the intake manifold, installing oil catch can, swap out spark plugs and pcv valve. Wrestled with the EGR assembly with no success. A week later i noticed some leaks around timing chain cover. So I gave that part a scrub and hose down to try to identify the source of the leak. Took these pictures yesterday... picture shows what's right below the exhaust manifold. There's a wet spot below the head. Is this concerning? Haven't noticed any drop in the coolant level. My plan is to have the engine checked out for leaks. Any other suggestions?
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Normal
    NutzAboutBolts likes this.
