Is this a normal AC compressor sound?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Gourockian, Aug 3, 2025.
  1. Gourockian
    Gourockian Junior Member
    75
    23
    New Port Richey
    I know we have been getting record temperatures here in Florida (as in other states also) but this is the first time I've noticed my AC compressor being so loud. I first noticed it a couple of nights ago but it had disappeared when I checked it the following morning.
    This short video was taken today when the outside temperature was around 100F/38C. The car had been sitting in the sun for over an hour, after a 25 mile trip so probably hadn't had much chance to cool down. The temperature control was set to LO.
    Does this sound normal when trying to cope with high temps?
    https://youtube.com/shorts/c9xsJqjsxR0?feature=share
  2. PriusCamper
    PriusCamper Senior Member
    13,417
    5,416
    Pacific Northwest, USA
    It's a nearly 13 year old car and old cars make strange noises when they're stressed. I've heard plenty of ACs in a Prius that sounded like that were fine and some that sounded like that were failing.
    My recommendation is to wait for a drop in temperature and replace your cabin air filter then go through all the basic functions of your HVAC to confirm that everything is still working normally and let us know if you come up with anything and we'll walk you through next steps.
    If you don't find anything wrong then the message is that your car is getting old and you need to do everything possible to go easy on it by parking in the shade and avoid driving during the hottest parts of the day so you can get as many years out of it as possible before you have to repair or replace the vehicle.
    Gourockian likes this.
  3. Gourockian
    75
    23
    New Port Richey
    Thanks for your reply and good advice. One thing I forgot to say is that at present, I've not detected any deterioration in the cooling capacity of the system, even though it's having to work harder during this unusually hot spell. I'll try to monitor it meantime and hopefully, it will continue to work okay until the weather cools down somewhat.
  4. PriusCamper
    13,417
    5,416
    One of the best parts of an aftermarket Sodium-Ion pack is it produces a high amp charge for a much longer period of time. With an OEM battery pack when it gets super hot out and AC starts sounding funky it's because the battery pack is out of extra power for the AC system and computer dials back how much power it sends to AC. This problem is mostly eliminated with aftermarket LiFePo4 and Sodium-Ion packs.
  5. Gourockian
    75
    23
    New Port Richey
    That's certainly interesting information but to be honest, I don't think we are wanting to spend too much on this car. My wife has never been too keen on being "so low down" compared to the minivan we used to have. We've been contemplating swapping it out for a Rav4 Hybrid within the next few months but have not taken any steps in that direction as yet.
  6. PriusCamper
    13,417
    5,416
    The same company also makes a sodium-ion pack for Lexus hybrids... You can find older Lexus Hybrids for cheap once the OEM battery pack goes bad. Way nicer ride than a Rav4 too!
  7. Gourockian
    75
    23
    New Port Richey
    I hadn't thought of the Lexus models but that's certainly worth keeping in mind. Thanks.
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Look up the soother project add on from the previous sodium battery seller before buying.
  9. Tombukt2
    Tombukt2 Senior Member
    13,823
    2,509
    Durham NC
    You probably want to make that RAV4 happen sooner than later before something goes on with the 3. And becomes not viable .
  10. ASRDogman
    ASRDogman Senior Member
    8,052
    4,083
    That is normal. At least it's been for mine for 8 years.
    "feels like" temperatures don't count. It feels like it's already 150 degrees out to me and it's
    only 7:45am!
    When it's so humid out, the compressor will run fast to cool down the cabin quickly.
    Turn OFF recirculation and open the windows for a minute to blow out all the hot air.
    Then close the front windows, then the rear.
    Then you can turn on the recirculation. It's likely around 125 degrees in the car after sitting
    in the sun, but only 90-95 outside. That air cools much fast.
    Do you use a windshield screen when the car is parked? That will cut down on the heat.
    So will a dash cover. That really helps.
  11. Gourockian
    75
    23
    New Port Richey
    Well, I checked it again just a few minutes ago and the noise is still there, although not quite as loud. The car shows the air temp as 88F, which is about right, compared to my thermometer. Turning off recirculation does reduce the noise somewhat, as does increasing the cabin temperature from LO to 70F.
    I occasionally do open the windows to let hot air out and always use a windshield screen when parked but have never tried a dash cover. I guess we'l just have to live with the noise for now and hope it doesn't fail completely, any time soon.
  12. Gourockian
    75
    23
    New Port Richey
    Good advice but as we are involved with a couple of fairly large home projects at present, It's probably going to be a while yet.
  13. ChapmanF
    18,969
    A simple thing you can do is plug in an OBD-II device that can show you live data, and have it show you the "AC Watts"—the electrical power being sent to the variable-speed compressor.
    The compressor can operate anywhere from 250 watts up to 2.5–3 kilowatts. At the lower end of the range it's rather quiet, and at the higher end it can sound a little like a passing motorboat. With a display showing you the power, you can get used to the way it normally sounds at different power levels.
    Naturally, the pitch is related to RPM and drops steadily as the power drops. The loudness drops mostly steadily too, but there can be spots where something nearby happens to resonate at a particular pitch and gives a little loudness boost if the pitch of the compressor is near that. (You can play with the same effect by humming or whistling different pitches in a public restroom, ideally when no one else is there to think you're weird.) In my car, there's a resonance right around 1–1.1 kilowatts where the sound is a little more noticeable than it is just above or just below.
    You can also sanity-check that claim by watching the power sent to the A/C and getting used to how it sounds at different power levels. You'll get used to the way dialing back the power doesn't make it sound funky, only lower-pitch and generally quieter, except for certain pitches where something resonates.
  14. Tombukt2
    13,823
    2,509
    Durham NC
    Yes sir I know how all four of mines sound and that ain't it so if no sight glass at least look at what lol can top gauge states. usually with the low side gauge hooked up I can generally tell what I have going on enough toknow what's going to happen . usually running Enviro temp . And oil that goes in bigger molecule easier to pump all that nonsense . Been running it since R12 hullabaloo. Seems easier on system .
  15. ASRDogman
    8,052
    4,083
    70? That's cold! I set mine to 75. Then very it between 75 and 77.
    You are making the compressor work harder than it needs too.
    Once the cabin starts to get cooler, adjust the temp to 75 or so.
    Then adjust the fan speed.
    98% of the time I set it to 75 and on auto. Even when it was it was 94 out....
    It's going to be noisier when the recirc on. But the lower fan speed will make it
    less noisy.
    #15 ASRDogman, Aug 4, 2025
  16. Tombukt2
    13,823
    2,509
    Durham NC
    I make a recording later mine are pretty dang quiet in the gen2 and ice cold on lo a pip before med fan and moving . The inside windows are fogging up almost it so cold . The big GM Volt AC do not do this . It's 3 years newer GM big azz AC too.
  17. Gourockian
    75
    23
    New Port Richey
    Yes, I agree that 70 does seem low and we would never set our house thermostat as low as that. However, we do seem to need it set quite low to maintain a comfortable temp while driving, especially when carrying passengers in the back. We've had this car for over 5 years and up until recently, have not noticed any excessive noise.
  18. Tombukt2
    13,823
    2,509
    Durham NC
    I don't like the fact that the heater core which is in the cabin is always hot if I was 20 yrs younger here I se 8 would put the firewall heater hose together till December.
  19. ASRDogman
    8,052
    4,083
    It has been a LOT more humid the last few weeks.
    I would wonder if perhaps you are low on freon???
    You might want to get it checked. And check your cabin air filter.
    Also the condensor, it might need to be cleaned also.
  20. Gourockian
    75
    23
    New Port Richey
    Yes, humidity has been a problem recently. I think my freon may be okay as the car cools down quite well.
    The cabin filter has not been checked in a couple of years so that is definitely suspect, especially as we usually have the system recirculating. The same goes for the condenser, which I don't think has been checked since buying the car.
    Thanks for the reminders.
    ASRDogman likes this.
