Is this considered a bad level for the 12v battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kn33, Nov 21, 2019.
Should I replace the battery?
Poll closed Nov 28, 2019.
  1. Yes
    66.7%
  2. No
    16.7%
  3. other
    16.7%
  1. kn33
    kn33 New Member
    I followed some steps online to get my battery voltages, and it looks bad but I want to confirm.
    I let the car sit for 30-40 minutes, then pressed the power button once (without pressing the brakes) and performed the steps to get to the Vehicle Signal Check Mode. This is the level that was displayed:
    Then I pressed the power button once more (again without pressing the brakes) and got this output:
    Is this a level I should be concerned about? Should I replace the battery?
  2. jerrymildred
    jerrymildred Senior Member
    11,511
    14,111
    Tampa, FL
    Welcome. I don't necessarily trust that method, but it looks pretty grim. If you just stopped the car and left the lights off and now 30-40 minutes later this is the voltage, I'd say you'd better be getting yourself a new 12V battery very soon. Like maybe today. But before shelling out the dough, get it tested by a proper tester that will load it. That's more money than I care to spend without knowing for sure.
    JC91006 likes this.
  3. kn33
    kn33 New Member
    Thanks.
    Yeah, the lights all turn off automatically so they weren't draining it. Would the testing that AutoZone offers be fine or is there something else I should look for?
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    How OLD is this battery ?
    What made you think it needs attention ?
    That voltage is marginal. If the battery is more than 4 years old, just replace it.
    Keeping it fully charged might get you a few more months of service.
  5. kn33
    kn33 New Member
    I don't know how old it is. I bought the car this past spring. I'll take a look at the battery after work and see if it says.
  6. bisco
    49,469
    where are you located?
    Raytheeagle likes this.
  7. bisco
    49,469
    auto zone is fine. they will do a proper load test and give you a report
  8. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    The grand old US of A isn’t a small enough geography:whistle:?
    States are over rated(y).
  9. bisco
    49,469
    not cali (y)
  10. ETC(SS)
    6,554
    "USA" is a pretty big place, but in nearly all of the lower 48, Old Man Winter is starting to harvest his yearly quota of over-ripe batteries....climate change notwithstanding.
    This comes just in time for tow truck drivers to save for those last minute stocking stuffers!!
    If you want to get every last possible vehicle-start out of the battery, then....yeah.
    Roll the dice!
    However (comma!!) do not be surprised if Old Man Winter's first cousin, Murphy, comes to pay you a visit when you HAVE to be somewhere.
    Or...it's raining.
    Or...you're leaving a watering hole at oh-dark-thirty in a sketch neighborhood.
    Me?
    I've already had all of the thrills and excitement that I need for a while...... ;)
  11. sam spade 2
    7,035
    2,788
    2017 Prius c
    You can get a multi-meter at Harbor Freight for about $10 and sometimes free with another purchase.
    That is a MUCH more versatile tool than the built-in screens.
    Also available at WalMart and auto parts stores for a few bucks more.
    With no load, 12.0 volts indicates about half discharged.
    But with the test you did, you can't be sure how much load there was on it.
  12. Mendel Leisk
    38,718
    I wish the car didn't display battery voltage, lol. A volt meter will do in a pinch. For a decent DIY assessment, get something like a Solar BA9.
    A measurement of 12.0, with a volt meter, after the car's sat overnight, would say to me: seriously depleted battery, maybe recoverable with a smart charger intervention, but I wouldn't give it long, would start researching replacement.
  13. kn33
    kn33 New Member
    Southern Minnesota
  14. sam spade 2
    7,035
    2,788
    2017 Prius c
    That is pretty much what I was trying to say a few posts back with the term MARGINAL.
  15. Mendel Leisk
    38,718
    The Solar (and similar) test CCA.
  16. sam spade 2
    7,035
    2,788
    2017 Prius c
    Come on, Mendel. I know you aren't that dense.
    (Or at least I think so.)
    ALL battery "testers" use the various functions of a MULTI-METER to gauge the actual battery health.
    Voltmeter and ammeter under various loads.
    That's it. No magic involved.
  17. Mendel Leisk
    38,718
    Not gonna get drawn into this, just hit the ignore button.
  18. kn33
    kn33 New Member
    I feel like I've unintentionally started something...
    bisco and jerrymildred like this.
  19. jerrymildred
    11,511
    14,111
    Tampa, FL
    Not your fault. There is a variety of personalities here just like on all forums.
  20. Mendel Leisk
    38,718
    Couple of cranks start butting heads, not a pretty sight...
    jerrymildred likes this.
