Is this considered a bad level for the 12v battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kn33, Nov 21, 2019.
Should I replace the battery?
Poll closed Nov 28, 2019.
  1. Yes
    66.7%
  2. No
    16.7%
  3. other
    16.7%
  1. bisco
    52,831
    @strawbrad is our minnesota 12v expert
  2. kn33
    kn33 New Member
    I tested it after work, it sat about 5 hours. Read 11.98 from the terminal. I took it to AutoZone without high hopes, and got exactly what I expected. It tested bad. It looks like it might be under warranty from the dealer, so I'm going to go in tomorrow and inquire.
    On a side note, that battery is a pain in the nice person to get in and out.
    jerrymildred and bisco like this.
    52,831
    yep.
    what makes you think it might be under warranty?
  4. kn33
    kn33 New Member
    It says "84 month warranty" on the side and "040916W" on the top
  5. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    The manufacture date is 4 Sep 2016, so some pro-rated warranty left.
    jerrymildred likes this.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    I hope he reports back with what the warranty did for him.
    This likely will be a good example of how "pro rated" warranties work......or don't.
  7. strawbrad
    953
    1,007
    It's 33 degrees outside this morning in the tundra. Perfect weather for checking battery voltage. The battery in my work car measured at 12.22 volts. It was last driven yesterday evening. I have another car that has sat since Wednesday, three days, and it's battery is at 11.88 volts. My wife drove her Prius this morning before I got around to checking voltage. After sitting for about a hour it's battery was at 12.12 volts.
    It would be great if more members would go measure the resting voltage of their 12 volt batteries and post the results.
  8. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,850
    Hyampom
    In the Coast Range of Oregon, overnight temperature 41, daytime highs around 54 about the beginning of October, I tested my direct from the dealer, purchased in January 2014, TrueStart battery manufactured by YUASA and it was at 12.3V after sitting overnight.
    I tested with my Klein digital Multi-tester at the jump point under the front hood.
    Decided to keep it around for at least another winter. Don't have a lot of spare cash, I am still restricted a fair amount with movement of arm and bending, plus, I am optimistic it should last at least one, maybe two more years.
    strawbrad likes this.
  9. Mendel Leisk
    42,331
    My wife drove ours yesterday, maybe 10 kms total. Checked this morning (at the under hood jump point, had to open door to pop it), current temp 6/42 C/F: 12.84 volts.
    It's an Optima Yellow Top, put in 4 years back as of September.
    Full disclosure: I'm a battery hypochondriac; our battery spends pretty much every idle day hooked up to a CTEK 4.3 charger. Our use of the car is sporadic, it'll regularly sit at least one day, sometimes 3 or 4. It had not been on the charger for a few days though, when I took the measurement this morning.
    #29 Mendel Leisk, Nov 23, 2019
    cyberpriusII likes this.
  10. bisco
    52,831
    my 7 1/2 year old was 12.7, until it wasn't.
    otoh, my 15 year old dakota battery was load tested yesterday, and they said it was good. i'll put a meter on it.
    Raytheeagle likes this.
  11. bisco
    52,831
    the 6 month old prius oem battery measured 12.88v this morning, and the 14 year old dakota battery measure 13.07v
    the prius dropped to 12.7 when i opened the drivers door
  12. Mendel Leisk
    42,331
    Yeah I'm a believer. If you're trying to get consistant conditions for measuring, I found too, that act of opening the door to pop the hood does knock about 1/10 of a volt off.
    Your Dakota battery is unreal!
  13. bisco
    52,831
    i wonder if the 28,000 miles is actually good for the battery?(n)
    i do keep a maintainer on it all winter
  14. Mendel Leisk
    42,331
    That's the key. Our garage queen 2010 Prius is almost constantly on a charger.
