Is this EV range normal?!?
Discussion in 'Prime Fuel Economy & EV Range' started by Shameless, Apr 9, 2018.
  1. bisco
    52,821
    the charts are great, but only you can determine if conditions are similar. i do the same drive almost every day, and get the same amount of ev miles except for extreme climate changes, mostly temperature or precipitation.
    Salamander_King likes this.
  2. EazyPeazy
    EazyPeazy Member
    110
    83
    New York
    Hello. I am new prime advanced owner as of 4/27/2018! 2017 model year. After a couple days of mixed driving, decided to deplete my battery completely for the first time and check out range in EV mode. Started at 100% with 23.2 miles of electric range onscreen. I work approx 38 miles from home and knew it wouldn’t reach there, but impressed I got to 30 miles before the engine kicked in. BTW I could have gotten a bit more if not for a steep hill I had to climb on the last leg of the trip! Very happy so far!
    bisco, Andyprius1 and Salamander_King like this.
  3. Darken
    Darken Active Member
    553
    49
    PA Dutch Country
    Wow that is an impressive spreadsheet, you have far more patience then I would ever have with your data. Thanks for posting.
    I'm going to look at my data a little more carefully this summer but more just for fun then anything else. I did a simple test yesterday by driving my commute in EV mode without a care for range and as expected my estimate this morning was lower. I'm not sure if its a day to day thing and/or averaged over time but the software has to be leaning heavily on driving style.
    52,821
    averaged over time. some type of algorithm, but toyota isn't talking.
  5. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    The problem with PRIME is that there really isn't an easy way to record ACTUAL EV miles the car run on EV mode to depletion of battery capacity. The car logs EV ratio, but it includes EV driving while running on HV mode, so if you drive beyond EV range, the number is not accurate. Similarly, if you switch back and force between EV and HV while you have EV range left, then you have no idea how far your EV mode run was. I recorded those data over span of three month last summer to fall before it got really cold. My conclusion is that there is definitely variation in ACTUAL EV range day to day despite I was very careful about driving similarly.
    Andyprius1 likes this.
  6. bisco
    52,821
    why isn't it easy just to go for a drive until the engine fires up?
  7. Salamander_King
    11,024
    8,978
    New England
    Yes, that's exactly what I did. The problem is the engine could fire up in a middle of busy intersection. I have to make mental note of what the trip meter reading from the start was then write it down on a piece of paper so I don't forget it when I get home.
    Darken, Andyprius1 and bisco like this.
  8. bisco
    52,821
    i have that problem too.:oops:
  9. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    That’s astrology!
  10. Salamander_King
    11,024
    8,978
    New England
    Maybe comes with our age? LOL:LOL:
  11. Andyprius1
    2,327
    859
    Cool CA
    One can never be sure when the ICE and, is it really running or freeing or getting rid of unwanted extra energy?
  12. Salamander_King
    11,024
    8,978
    New England
    Well, I used visual que of EV range display approaching to 0 mile and EV mode light shutting off, so I am pretty sure that was when EV range ended and ICE kicked in for HV mode.
  13. ClemsonSteve
    ClemsonSteve Active Member
    270
    248
    South Carolina
    I use EV Auto on the highway--then switch back to EV (only) when I get off the highway. The engine runs a little, but I save the EV for slower, stop and go driving. I have not calculated it, but it seems to increase the overall MPG.
  14. Andyprius1
    2,327
    859
    Cool CA
    Great, you will know from the lifetime mpg, just to the right of the odometer. Have fun.
    ClemsonSteve likes this.
  15. Andyprius1
    2,327
    859
    Cool CA
    I forgot, there is one way to tell for sure that the ICE is on: The lifetime Average mpg goes down.
  16. bisco
    52,821
    even if it is just burning off excess?
  17. Andyprius1
    2,327
    859
    Cool CA
  18. Darken
    553
    49
    PA Dutch Country
    I would think any time it's running no? Haven't run into this yet so I can't say from experience.
    You will find many PC users switch to HV mode on the highways to conserve EV range. I myself haven't tried EV Auto on highways for fear it would still run down the EV range to depletion, I'll have to give it a shot sometime.
  19. ClemsonSteve
    270
    248
    South Carolina
    This seems like one of the problems presented in the movie Apollo 13, where they had to conduct the startup sequence to conserve the batteries!
  20. Andyprius1
    2,327
    859
    Cool CA
    Yup, that’s the Prime.
