is this Gem true? 2014 with 47k miles
Discussion in 'Gen 3 Prius Main Forum' started by AC / DC, Jun 11, 2021.
  1. AC / DC
    AC / DC New Member
    Hi guys!
    I am a gearhead that has been waiting for the best opportunity to get a Prius 2. I am totally new to hybrids. I found a car at the Toyota Dealership. It is 2014 with only 47000k miles on it and going for $14k. It is a one-owner and this dealership is the original dealership that sold the car and has done all service maintenance on it. The car was just been traded in when I was on the phone inquiring what Prius was available. They still had to do their inspection, cleaning, etc to put it out for sale. I put $500 down to hold it. I will be looking at the car on Thursday. -- The Carfax checks out, The Toyota Owners website check out, The price looks right compared with KBB. My main question is about the hybrid battery. This car has been driven an average of 7k miles per year. Based on what I have read the battery warranty is 8 years /100k miles (I am in MN).
    How do you guys anticipate the life expectancy of the Battery and engine be on this thing?
    Thank you for any light you could shine my way.
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,117
    6,975
    Texas Hill Country
    Years will take their toll although cooler climates are more favorable. I would rather see you go for a 2016 or newer gen4 with more miles at the same price. Generally major maintenance is after 100k miles. I recommend reading some of the gen3 threads.
    #2 rjparker, Jun 12, 2021
  3. Samuel Williams Jr
    246
    Dayton NV
    The Gen 3, the problem child of the Prius world. :)
    I doubt you'll have to worry about the HV Battery, for the most part they are good for 150000 miles or more. But the engine ... not so much a lot of times. Barring intervention.
    Oil sludge, clogged ring's, lead to leaking Head Gasket's, leading to motors trying to compression liquid, leading to holes in block's.
    I can't say it happens, all the time but it does happen a lot. Here is one of many threads and there are many more.
    Oil Consumption 2010 Prius | PriusChat
    And the problems for the most part seem to crop up at close or slightly after 100,000 miles. And it seems to be in part, the low tension piston rings. But I think mostly the EGR system, the egr valve, the egr cooler and the intake manifold get a slug build up, the HG fail's eventually and it's bye, bye motor.
    But at 47k none of that has happened yet. I would be curious as to what those components look at 47K? But usually people just buying a car are not eager to pull stuff apart to clean it and install a Oil Catch Can?
    A higher mileage Gen 4 would be a better choice or a much less expensive if you find one with a bad battery or a blown engine. In the Gen 4 Toyota moved and added water cooling to the EGR valve, so you have to think, they knew something was wrong or they would not have changed it?
    It's your call but now you know. :)
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    I believe the head gasket issue was limited mostly to the 2010 and 2011 models. Wasn't it 2012 where they had the redesign to the piston/ring combo to alleviate that problem?
    Johnny Cakes likes this.
  5. Samuel Williams Jr
    246
    Dayton NV
    Oh no doubt someone here knows for sure. But I thought it was 2014 to 2015? I still think the ring change was a band aide. If the sludge was not there, the ring's would not know clog. (Is how I view it.)
    And I'm not down on the Gen3's ( I luv the new tranny) and I think that is why they get better mileage than the Gen 2's, without even trying? But if people are wise enough to ask first, they deserve to know the pit fall's of a given vehicle. I'm not a hater just a realist. :)
    AC / DC likes this.
  6. Mendel Leisk
    42,354
    Piston/ring revision apparently happened “sometime” through model year 2014. That was only to address oil consumption AFAIK. There were some revisions to the intake manifold, and one for the EGR valve, but I don’t think that did squat for the carbon clogging, which i suspect is a big factor in head gasket failure.
  7. bisco
    52,862
    looks like a good one. how many miles a year are you likely to put on it, and how many years do you want to keep it?
    the battery should be good for at least 10/150, probably more.
    47k is the perfect time to jum on the egr circuit cleaning, and instaling an oil catch can.
    that won't guarantee that it won't blow a headgasket, but it might help. also, some are changing the oil every 5k, instead of toyota's recommended 10k.
    mikey_t and Samuel Williams Jr like this.
  8. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Ok. I thought it was the oil consumption that was the root cause of the EGR carbon buildup. Are models later than 2010/2011 experiencing similar head gasket failure rates? When people have asked me about the Gen 3s, I've recommended staying away from the 10/11 year models due to HG failures, but after that should be ok. Wondering if I should adjust that recommendation.
  9. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    47k is a very low number and I'm guessing that the only necessary maintenance so far has been oil/filter changes (as per the manual). There's a way to log into the Toyota website to see the maintenance history of this particular vehicle. It sounds like this could be a good deal.
    You're still under warranty for the hybrid battery. There's a belief around here that the life of the hybrid battery is based on years, not miles. Expect 10+ years. Unfortunately, inactivity is bad for the hybrid battery, but at least for now, it's still under warranty.
    From what I've read here, the EGR issues are related to miles. You should have no problems at 47k miles.
  10. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    If it's a Minnesota car, it's probably never had heat issues. That battery is likely a diamond in the rough.
  11. rjparker
    11,117
    6,975
    Texas Hill Country
    Excessive oil consumption caused by the rings was 2010-2014. Not much mystery since Toyota has the vins defined when the new rings hit production in 2014.
    Prodigyplace likes this.
  12. Mendel Leisk
    42,354
    Yeah I think EGR fails due too constrictive design, and the inlet is so close to the exhaust ports. Fourth gen greatly increases the cross sectional area, and relocated input, to be downstream of the CAT. I take this as tacit admission of the third gens shortcomings,
  13. AC / DC
    AC / DC New Member
    Thank you all for your posts. I truly appreciate your input.
    It sounds to me the Gen 3 is not the right car for me. I did some further research and the car was produced in October 2013 and sold 01/2014, so I am quite sure it is subject to the issues you are mentioning. Although I have done plenty of engine repairs in my life, at this time I want to get into a hybrid that will not keep me awake at night thinking about a catastrophic internal/gasket failure around the corner. Maybe I would feel more comfortable if it were a late 2014 production. - I will look for a Gen4 with higher miles as some of you recommended.
    Thank you very much you guys are great!
  14. AC / DC
    AC / DC New Member
    Did the Gen4 fix the EGR/ head gasket issue? -- if it did, do you guys know how?
  15. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    "keep me awake at night thinking about a catastrophic internal/gasket failure around the corner"
    What about other catastrophic failures???
    No promise the Gen4 headgasket won't fail. It could fail on any car.
    Maybe get one of those extended warranties from the ads that keep popping on all over the place and tv commercies???
    AC / DC and Samuel Williams Jr like this.
  16. Samuel Williams Jr
    246
    Dayton NV
    Time will tell but the Gen 4 changed the piston ring's and moved and water cooled the erg valve on the Gen 4. One has to "assume," that Toyota did that for a reason?
    I'd take a higher mileage Gen 4, over a lower mileage Gen 3 any day but that's me.
    Aaron Vitolins and AC / DC like this.
  17. ASRDogman
    8,066
    4,089
    It all depends on how much money you have to spend.... (y)
  18. AC / DC
    AC / DC New Member
    I hear you, and understand your point. At any time any of the thousand parts in a car can break prematurely. My experience as a mechanic, and point of view as owner is my evaluation of the issue /what part breaks in relationship to safety and/or how difficult/expensive/etc the replacement will be. - In a car there are maintenance items of parts that are inherently disposable (breaks, rotors, belts, water pumps, etc) and there are others that by design should not be (Steering shafts, crankshafts, pistons, piston rings, valves, technically all internals). The Acura TLX engine had bad internals that in conjunction with a design flaw ended up in blown engines. After a class action lawsuit, Acura had to bite hard and extend the warranty.
    I really thank you all for your input.
    ASRDogman and Samuel Williams Jr like this.
  19. Neicy
    Neicy Member
    834
    Wakefield, MA.
    My 2012 #3 had 42300 miles on it when I traded it last week and the only unusual problem I had was that the headlights were cloudy and had to be restored just a couple of months ago. Other than that all routine stuff. Never had any issues with oil consumption. I just wanted a plugin with newer features.
    AC / DC likes this.
  20. AC / DC
    AC / DC New Member
    I started a new thread within the 4th Gen section of PRIUSCHAT. the title is " Did 4th Gen fix 3rd Gen?".
    RJParker just posted wonderful information about the ERG/Piston/Head Gasket system design/features Gen 4 implemented.
    I recommend you guys take a look at it.
    Cheers! - It's Friday! :)
    Samuel Williams Jr likes this.
