1. bigmichaelkim
    bigmichaelkim Member
    70
    US
    Today I had a nail in my tire so i decided to plug it myself and did tire rotations at 9592 miles just for the hell of it. I think I plugged it successfully fingers crossed but when I was rotating my tires I noticed something in my front brake rotors. Is this level of rust on the brake rotor normal for a car of such low mileage? I live in so cal so no salt on the roads for what it's worth. Thanks in advance.
    iPhone ?
    52,872
    yep. although i'm not familiar with gen 4, looks normal for prius.
    kithmo likes this.
  3. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    That is the cleanest looking set of rotors I have ever seen, but I'm from the East Coast :LOL::cry:
  4. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    Looks great. I hope the my Gen 4 goes the same distance my Gen 2 went without touching the brakes. 200 K!
  5. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I think you'll find all rotors tend to rust because of humidity as much as anything else due to the high iron content of the steel used. However it will form a barrier against deeper rust, I believe. (n)
  6. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Has the car been sitting out in the rain? The rotor surfaces are the first thing to rust if the air is moist, even overnight, I've noticed rusted rotors (even on brand new cars) in the car-park of the apartment block where I live.
    RCO likes this.
  7. bigmichaelkim
    70
    US
    Nope. I live in so cal, the Prius capital of the world, so we don't get much rain at all and I park with his car in the garage. It did however rain a little more than usual this past winter...wonder if that has anything to do with it.
    iPhone ?
  8. William Redoubt
    William Redoubt Senior Member
    1,228
    1,174
    Coronado Island, California
    Those rotors look normal. For any car.
    RCO likes this.
  9. Mendel Leisk
    42,359
    That's NOT normal...: looks too dang clean.
    Here's our 2010, this spring, with 67K km's:
    Good luck with the plug repair, btw. I've done a couple so far, and they've both held up just fine, for several years.
    fuzzy1 and RCO like this.
  10. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    The initial oxidation (i.e., corrosion) layer does indeed protect the underlying metal from further corrosion. That's why it never made sense to me to "polish the brass" when I was in the Navy. They just (a) wanted to give us some "busy work", and/or (b) wanted everything to be all nice and pretty.
  11. Prodigyplace
    12,718
    11,850
    Central Virginia
    Are you sure they wanted you to polish physical brass or compliment the upper military brass? :LOL: :D
  12. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    A bit of both, really. We air force types always said...
    .. Bull..it baffles brains!
  13. fuzzy1
    10,715
    I wish!
    Not in my climate zone. Especially since politicians in my region discovered winter salt.
    RCO likes this.
  14. Mendel Leisk
    42,359
    A good thing to coat with a bit of anti-rust is the center hubs, the threaded axle end and nut. It can turn into a rusty mess real fast, especially on salted roads. Much of Toyota's hardware, nuts and bolts, seems to have zero rust coating. Especially vulnerable if you're using steel rims without center caps of some sort:
    This is the same hub that I pictured above. After this pic, I went hammer and tong with wire brushing, and anti-rust coating. And jury-rigged a center cap (2" ABS end cap with a rubber gasket) to make it less exposed in future.
    William Redoubt and RCO like this.
  15. bigmichaelkim
    70
    US
    Thank you. I plugged it successfully, it has been about 5 days and I checked the pressure and it doesn't seem leaking for now, fingers crossed.
    Also the center nut is the only thing that seems prone to rust as of now on my rotors after looking at that of others. I am just surprised a new car has rust on a bolt like that already. I love toyota as a manufacturer but would it have been that hard to make that center bolt a little bit more rust proof? Calling you out toyota!
    iPhone ?
  16. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    A quick squirt of WD40 or similar gunk should sort the problem. Just be careful not to get it on the disk /rotor.
  17. Mendel Leisk
    42,359
    Keep in mind the hub and rotors spin with the wheels. Whatever you apply, use it sparingly, and let any liquids dry-off before driving, they will migrate outwards as the hub spins.
