Is this normal
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by johnnychimpo, Oct 18, 2021.
  1. johnnychimpo
    johnnychimpo Active Member
    522
    112
    Monterey
    I upgraded my engine from gen three to gen four in the process I serviced the trans.
    I drained the fluid at 189K it was black I suspect it had not been done before.
    I drove the car for about 8k so drained it this weekend and it came out grey silver slightly blueberry greyish.
    Planning to do it again till fluid it red. Now if you look at the pic there is tiny metal shavings I suspect this is normal wear on the trans of this age or am i looking a potential trans failure. only issue on trans is on occasion I hear a clunk when the engine starts of stops. its rare but I have heard other folks experience the same thing so I suspect this is normal the sound that is.
  2. JC91006
    16,936
    8,647
    You don't have to change the fluid again, just keep it. It doesn't have to be bright red.
    There's nothing more you can do to prolong that transaxle, if it fails (which nobody knows when this will occur), then you replace it. Other than that, just enjoy the car. Don't change the fluid for another 60k+ miles
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,062
    6,933
    Texas Hill Country
    Didn't you change the damper a few months ago?
  4. johnnychimpo
    522
    112
    Monterey
    yes and it worked great. This is just me doing preventative maintenance.
