Is this stuff really taught in churches?
Discussion in 'Fred's House of Pancakes' started by F8L, Nov 24, 2007.
  1. Darwood
    Darwood Senior Member
    5,259
    268
    "My understanding was that it's possible to measure activity, not as blood blood flow but as actual neuronal activity (like measuring theta waves in Buddhist monks). You can measure an intensity and then, based on the regions of the brain that are active, you have some idea what kind of emotional response it was."
    You can measure individual cell activity (firing), but you can't measure all of the cells at once. There's too many of them.
    With PET scanning, you are measuring activity, but you do so by measuring the blood flows in the brain. By using an slightly radioactive isotope that decays quickly, you can map out what parts of the brain are most active for a short period of time. The active parts of the brain use much more blood than the inactive parts, and this is what you are measuring. You inject the solution, while simultaneously illiciting the activity you wish to "map", and turning on the machine for about 10 seconds. You do this about 5 times, while also mixing in about 5 baseline scans where no stimuli is given. Then you subtract the images to give you the "change" in blood flow for that given stimuli.
    "My understanding is that the brain doesn't differentiate between memory and current events. "
    Sure it does. Memory recall is different than current memory formation. Also, there is more than one way the brain can set something in memory as well as pull an old memory up. You're frontal cortex knows if it is pulling the memory from the temporal lobe or if it is reacting to new stimuli.
  2. HolyPotato
    HolyPotato Junior Member
    92
    Toronto, Ontario
    <div class='quotetop'>QUOTE(Darwood @ Nov 29 2007, 09:40 AM) [snapback]545633[/snapback]</div>
    Actually, it's fMRI that measures activity by blood flow changes. PET (with FDG) uses glucose uptake (or, with rarer isotopes, oxygen utilization, and something we're working towards with radiopharmacology is tracers that bind to specific receptors)... There's also MEG (magnetoencephalography) which I didn't see mentioned yet. It's similar to EEG in that it can measure the electrical activity of a large group of neurons, but isn't as limited to the surface of the cortex as EEG is. It's a lot more resource intensive though!
  3. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    wow, you clinical folks inspire me :)
    i don't know how well i'd like a radioactive tracer in my brain... not so much even for the radioactivity (said the girl who gets more irritated with the associated paperwork than the actual chemical use) but the receptor activity leading to altering of signaling! i suppose a partial agonist would be the most safe route to go but even that kinda worries me.
    we have plenty of radioactive tracer research in fixed brains, but i do wonder about a dynamic system and how that would interfere.
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    <div class='quotetop'>QUOTE(galaxee @ Nov 29 2007, 11:40 AM) [snapback]545782[/snapback]</div>
    Same here.
    I'm still down at the level where lab experiments consisting of playing with DNA samples from my cheek tissue is fascinating. :lol: Hell at least I now understand the process (Haplogroup X mtDNA)by which some conclude humans arrived in North America well before 11,500 years ago (Pre-Clovis) and the real number is closer to 21k-18k years ago. Well according to the Solutrean hypothesis (Stanford and Bradley 2002). From France no less! :lol:
