Is this the end?
Discussion in 'Gen 2 Prius Main Forum' started by speedyroo, May 25, 2012.
  1. speedyroo
    speedyroo RIP 2006 Prius
    37
    I have had my Prius since it was a little sprout with just 20miles on it. Now it has 111,573. Maybe more than that. I know it's 111,000 something. I drive it about 3-4 times a week. I have chosen to walk to my train station instead of driving to it in order to reduce my carbon footprint.
    Anyway for the last month or so I've noticed when I start the Prius up that I'd go about 300yards and the hybrid battery would go down to one bar. It kinda freaked me out but then a little further it'd be back to normal and for the rest of the day that I drive it, it's fine.
    Until today. I hadn't driven it since Monday or Sunday and went to get into it this afternoon and it was DEAD. More dead than it's ever been. Now I've left a light on or something before but even then there's SOME life - like it'd turn on and give me a <!> or the mechanisms are slower. I get a jump. Not today. It didn't turn on, nothing on the car worked at all - I couldn't unlock doors.
    I live across the street from a mom & pop garage that's been here for 70+ years so I asked if they could give me a jump (they have before!) It was a mess because my driveway is so narrow the guy had to drive on the lawn. It was really tight but we got it jumped. It turned on.
    I noticed that the hybrid battery monitor was acting erratic. But it was on. I thought all I'd need to do was drive it and get the juices flowing. So I started to drive it and after a few ft the <!> light came on. Crap. I got to a gas station and filled up. I turned the car on and the <!> light AND the "check engine" light was on. Double crap.
    I immediately drove to the dealers (about 7 miles) and they just barely took my car. I explained my car is having a midlife crisis and all my lights are on. They told me that since I didn't have an appt to come back on Tuesday.
    Um, no. I could feel the car laboring trying to get over 45mph. I am NOT going home!
    So my poor Prius is sitting at the dealer's for the weekend. They said they MIGHT be able to call me tomorrow and tell me what's up with it. I'm kind of thinking it's the hybrid battery and that it's met its expiration date.
    The Prius is due for for brake pads, tires, and an oil change (in a few miles) so this might get costly......................no longer under warranty.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Seems like some mixed symptoms, but my initial inclination is to think this may just be your 12v battery. How old is it?
  3. speedyroo
    37
    It's 6yrs old. I got it new in 2006. Actually 6yrs old to the month. I remember getting it in May.
    I probably didn't do it any favors driving it to the dealer but I wanted to get it somewhere quick and where it'd receive attention. The garage across the street is a full service garage but they're CLUELESS about hybrids. I'm still surprised the dealers said to come back Tuesday....I would hate to have drove it home in that condition.
    NOTHING in this car has been replaced since I got it (other than tires). It's never given me any issue. Not even a flat tire. So I imagine things got to expire sometime...
  4. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Then the 12 volt's probably toast. I replaced mine last year. I bought my 06 new in January 06.
    Run a check via http://priuschat.com/forums/newbie-forum/73400-weird-stuff-happening-mpgs-dropping-test-battery.html and tell us the voltages at each step after the car has sat overnight or MANY hours.
    I wouldn't be surprised if it's well under 12 volts with a load on it.
  5. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    I agree ,you need a new 12v. If you are not going to use the car for days then you may want to purchase a electronic 2 amp charger to keep your 12v charged for when you need it. It is a very small 12v and does not last long if you don't drive most every day! H
  6. speedyroo
    37
    Thanks for the info! I really do hope it's the 12v and not the hybrid battery. I can't check it myself because it's in the shop because they said they MIGHT be able to get to it tomorrow.
    I've talked to folks that said their hybrid has lasted them over 200k so I was very surprised when my car started having a midlife crisis.
  7. easted
    easted Junior Member
    64
    Pillow PA.
    2018 Prius
    After 6 years of service it would be my opinion that the 12v battery is the culprit. Check on this web site about "replacing the 12volt battery".
  8. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    See if you (or they) can run the check that I described.
    If it's the dealer, don't bother having them "test" the 12 volt. See http://priuschat.com/forums/gen-ii-...turned-off-then-wont-start-3.html#post1310197 (Patrick's one of our repair experts). We've often heard of dealers "testing" the 12 volt, claiming it's fine, when it seems like a false positive. At its current age and mileage, it's almost certainly due for replacement.
  9. pcdave
    pcdave Junior Member
    48
    Scotland
    Sounds like the 12v mine was doing all sorts of crazy thing as well it died at 122k at 6 years old seems like a theme ;)
    Hopefully the simple 12v battery swap and you will be back up and running also advise you dont let them test it mine said it was absolutely perfect then it died and was dead a dodo his face was priceless lol.
  10. uart
    uart Senior Member
    4,220
    1,211
    Australia
    The 12V battery is dead and needs replacing. It has been weak for some time, here's what's been happening. Every time you start with your 12V battery nearly dead then the it takes a lot of energy from the inverter to try and charge it rapidly in the first few minutes, and this helps to drain the HV battery.
    Also in the first few minutes of driving when the engine is cold it tries to use the traction battery much more for motive power, so together these things can drain the HV battery rapidly at start up. If you're also using the A/C from startup then that's the trifecta.
    You can greatly reduce the amount of traction battery discharge in the first few minutes by leaving the Prius in "P" and allowing it to warm for about 45 seconds before driving off. The fuel you waste warming up is saved later due to the Prius running more efficiently with a healthy state of charge.
  11. speedyroo
    37
    Thanks everyone! I think since this sounds like exactly what it is and if they tell me that it's fine I will have them replace it anyway. I can't remember what they told me last time I was there that the car needed other than break pads and they MIGHT have said something about the battery but I might be hallucinating. The papers are all in the car so I can't check it. I hope they call me today and let me know what's up and so I can get it back but with it being a holiday weekend I'm not holding my breath.
  12. speedyroo
    37
    They just called me back and they said "the 12v is the first thing they checked" when I asked them about it. They said they've been working on it all day but coudln't find anything. Their "Prius Experts" are all away for the long weekend and won't be back til Tuesday. They mentioned something about "factory" too.
  13. PriusTech
    PriusTech Active Member
    264
    124
    Reno
  14. speedyroo
    37
    I'm just curious as to why the dealer wouldn't pick up on this if it's a battery issue. Wouldn't they WANT to sell me a new battery? $$$?
  15. Ophbalance
    Ophbalance Member
    205
    16
    North Carolina
    I'd hazard that the average tech doesn't own a Prius and/or doesn't visit this site. One of the greatest strengths in a community such as PC is the shear amount of knowledge that you gain just by reading the daily threads. Even without having a trouble code to point the way, sometimes the symptoms have been repeated enough a goodly portion of the board can get you pointed in the right direction.
    The other thought would be that without a trouble code pointing the dealer to a conclusion, leading a customer into an unnecessary expense would be bad for business.
    Just my opinions on it, for what it's worth.
  16. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Because the 12 battery powers the computers, the computers cannot check the 12 volt battery: Catch-22. Without a code from the computers, the tech is clueless.
    You will notice that the test for the 12 battery involves letting your Prius sit overnight, the tech cannot tie up a bay that long.
  17. speedyroo
    37
    Ok. I have been trying to reply for DAYS trying to give folks an update, but I just was able to post now after the switch.
    Sooooooooooooooo - everyone was right: it was the 12v. They called me Saturday saying they couldn't figure out what was wrong and I had to wait for the Prius expert to come in. The Prius expert came in and immediately knew it was the 12v. (Hey, the car sat there all weekend and without a doubt was dead when they tried to start it up, it's not rocket science). So they called me and said that it needed replacing. GREAT! It also needed new break pads (which I knew, they haven't been replaced in the 6yrs I had it) and an oil change. It would be ready that day (Tuesday).
    They did the above and then tested it out.....but it still wasn't okay. They called me back and turns out there's a dead cell on the hybrid battery. It needs to be replaced. I'm 11,864 miles over warranty. <insert expletive here>
    Well - believe it or not - they gave me a hybrid battery anyway. I just had to pay shipping and handling. Not even labor for insertion of the hybrid battery. I have no idea what I did to deserve this sort of treatment, but I truly appreciate it. I love Toyota.
    So now my car has new oil, new brakes, and 2 new batteries. I feel like I have a whole new car!
    uart and TonyPSchaefer like this.
  18. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Way to go!
    (I am proud of such dedication to report back, I love folks who give us feedback on how well we guessed)
  19. PriusTech
    264
    124
    Reno
    Typically when the small battery goes out it's sort of intermittent, it doesn't go out all at once. It will fail once or twice then the car recharges it and it then tests okay.
    You may have gotten a rookie too that tried to diagnose it. It's a trend that some of the dealers are cutting costs in the service department. That means the top techs are going elsewhere and new rookie hires are coming in.
  20. PriusTech
    264
    124
    Reno
    You can thank Toyota AND the dealer. In the industry this is called "goodwill warranty". Toyota will generally approve something like this but the dealer has to request it first. The dealer doesn't make as much money from warranty compared to customer pay, so they did you a favor to gain/keep your loyalty to them and to Toyota.
    Not all dealerships are stealerships.
    TonyPSchaefer likes this.
