Is This The New PiP Transaxle?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Jeff N, Nov 5, 2015.
  1. bisco
    52,665
    i don't know what toyota's goal for the next pip is. i believe an official mentioned that they heard the customers, and will add some range. how much battery they decide to stuff in, and how much weight they want to add will probably affect the total ev availability.
    after that, i suspect, but have no idea, that they will want to make it as prius like as possible, meaning lowered emissions. i don't believe they are going to try to compete with the ev range of other phev's. i do think a sales target will drive some of their decisions.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Second revision. This time, I made the planetary gearsets in Sun/Ring/Carrier (SRC) order for all.
    Jeff N likes this.
  3. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Will it not be more logical to arrange them SCR order?
    #23 giora, Nov 6, 2015
  4. Emcguy
    Emcguy Member
    177
    29
    Australia
    This is what I mean with regards to slowly losing the simple elegance of the Gen 2 HSD
  5. bisco
    52,665
    elegance vs efficiency?
  6. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Dual motor mode!
    This means the Prius Prime has a clutch of some kind. It's not yet clear if they somehow added this as a modification to the 4th gen transaxle or if it gets the 3rd gen based "two-mode" transaxle reflected in the patent I wrote about. Based on no information whatever, I'll guess that they just stuck a one-way clutch on the planetary carrier connection to the gas engine of the 4th gen transaxle.
    #26 Jeff N, Mar 23, 2016
  7. bisco
    52,665
    what about 'charging on the fly'? how is that accomplished, and how efficient is it?
  8. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    That's just done by generating extra electricity with MG1, for example, while driving. The non-plugin Prius does that routinely in order to keep the hybrid battery at a happy charge level. The same idea applies to the Prime except that the battery is a lot bigger and the idea of "charging on the fly" is presumably to fill up the battery from the engine instead of the grid so that you can drive EV-only later on if you want to be quiet or are driving in certain core areas of European cities where any use of the gas engine results in a fine for local air pollution reasons.
    Doing this is less efficient than driving normally in hybrid mode because you are converting the mechanical motion of the gas engine into electricity rather than driving the wheels mechanically. It's still probably not too bad. I would guess the effective gas mileage of burning gas to store energy in the battery and then using it again later to drive in EV would still be in the mid-40 mpg range.
  9. bisco
    52,665
    and complaints in the 'why don't i get the rated mileage' thread.:cool:
  10. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I've gotta say... I called it!
    However, it's looking like the new gen 4 PHEV added one or more clutches to the gen 4 non-PHEV transaxle rather than adding clutches to an extended gen 3 transaxle.
  11. Tideland Prius
    16,653
    Except that the setup in the picture has a completely different purpose - performance.
