Is this the original battery?
Discussion in 'Prius v Main Forum' started by PreusV, Sep 17, 2018.
  1. PreusV
    PreusV Junior Member
    16
    Chicago
    2013 Prius v wagon
    Is it possible to determine if this is the original factory battery in my 2013 Prius? I need a car battery for a side project and if this is original I'll utilize/replace it. Are there any recommendations for a replacement battery?
    DLC82SV likes this.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Most likely it is the original. I believe the 09-12-12 on the center sticker is September 12, 2012 manufacture date. At least that is the coding I use when I examine these batteries.
    Sorry, off my game today....091212 should be December 9, 2012. First 2 are the day of the month....second 2 are the month and last 2 are the year
    #2 TMR-JWAP, Sep 17, 2018
    DLC82SV and Raytheeagle like this.
  3. Mendel Leisk
    42,343
    Just to ask the obvious: are you second owner of the car?
    Hard to tell, it might be. Maybe test it, check the at-rest voltage for starters, with a digital volt meter, first thing in the morning. For a much clearer picture: test it with one of the lower electronic load testers.
    Here's a pic of our original battery, for what it's worth (2010 Prius hatchback). I see some differences, but the labels likely undergo revisions. CCA is noted on yours, which is an improvement, for example.
    DLC82SV likes this.
  4. PreusV
    16
    Chicago
    2013 Prius v wagon
    I am the second owner of the car. The car was originally purchased/used in Chicago and that's where I live/use the car. Batteries generally only last 3-5 years here; I doubted this battery could be original given its 6 year age and lack of corrosion. Would this battery last longer because it is inside the vehicle and because this is a hybrid?
    DLC82SV likes this.
  5. Mendel Leisk
    42,343
    Test it. More important than it's lineage.
  6. burnout8488
    burnout8488 Member
    124
    81
    Endwell, NY
    091212 date code. It's original. The one above from a 2010 is 240210.
    DLC82SV and Mendel Leisk like this.
  7. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Just like this one I bought in 2016 to have as a back up spare....
    231215W = December 23, 2015 manufacture date code...
    DLC82SV likes this.
  8. Prodigyplace
    12,712
    11,848
    Central Virginia
    The battery generally lasts longer in the Prius if it has not been deeply discharged. The battery only boots up the computers in the car and closes the high voltage battery relay. The high voltage battery is used to charge the 12 volt battery and to start the engine when needed.
    In the traditional car, the high current draw to start the engine in cold weather tends to reduce their battery lifespan.
    DLC82SV likes this.
  9. PreusV
    16
    Chicago
    2013 Prius v wagon
    If the car is in park does the hybrid battery or the 12v battery start the engine? Where is the best place to buy a replacement battery?
    DLC82SV likes this.
  10. Mendel Leisk
    42,343
    That's debatable: the hybrid battery turns the engine over, but if the 12 volt battery runs the "intelligence", and without that the car won't start.
    Just for giggles check with a dealership parts department (or two), see what they're asking. Pep Boys is one place I've heard that has a compatible and low-cost battery, by Bosch IIRC.
  11. Prodigyplace
    12,712
    11,848
    Central Virginia
    Many time a weak 12V battery can confuse the "intelligence" too and display false error codes.
  12. DLC82SV
    DLC82SV Member
    241
    119
    Toyota cor where and that is a stock battery imo. Why not get another that will last just as long and run everything correctly?
