Is this what normal water pump function is like?
Discussion in 'Gen 3 Prius Technical Discussion' started by freshedie92, Oct 1, 2018.
  1. freshedie92
    freshedie92 Member
    73
    37
    San Bernardino, California
    Okay so I was testing my water pump to see how it works. It spins. But it shutters right at the beginning. Not sure if that's what's supposed to happen.
    I uploaded the video to YouTube let me know :)
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    How many miles on your Prius?
    Seems normal, but when I swapped out the water pump at 173 k miles on our 2010, there was a difference between te old and new in terms of smoothness through rotation.
    What activity are you working on?
    Good luck and keep us posted (y).
  3. freshedie92
    freshedie92 Member
    73
    37
    I've heard new will perform slightly better. But if it ain't broke don't spend 250 I say.
    I just bought a prius, cleaning egr and intake. Supposedly overheated and losing coolant. Compression is fine. Oil looks good. And other than redder than normal coolant everything looks good.
    I'm swapping the thermostat for precaution, that things a pita with everything in place
  4. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    So have you verified it is losing coolant?
    A $250 water pump is cheaper than doing the head gasket or swapping engines.
    If swapping the thermostat, you’re right there to do the pump as you are finding out.
    I think the egr cooler is more of a chore than the thermostat, in comparison.
    Good luck with your project(y).
  5. freshedie92
    freshedie92 Member
    73
    37
    I can't say any of your points are wrong. But I still want to wait on a pump. Changing that won't be too bad imo. Does it give a code for failed pump? I have not verified it's losing coolant. I towed it home, started wrenching and doing research. When it's all back together either I have a good prius or one that needs to be dismantled all over again.
  6. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    It’ll throw a code, but you’ll be without coolant flow when it does. You can imagine what happens next.
    This happened to another member here at around 157 k miles. Happened suddenly and without notice. A mag drive pump doesn’t give failure warnings like usual water pumps do.
    I took this as a cautionary tale. I did both the thermostat and water pump together along with the egr cooler swap and circuit cleaning, spark plugs and changing the coolant at the same time.
    A bit of a job, but I had a spare set of experienced hands spending some time with us (grandkids are a great lure).
  7. freshedie92
    freshedie92 Member
    73
    37
    That's basically what I'm doing. It is a lot of work. When I save some money up I'll buy the pump it does seem worth it. Thanks for your help! :)
    Raytheeagle likes this.
