Featured Is Toyota Prius hybrid simply passe now that plug-in cars are here?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, Jul 19, 2016.
  1. austingreen
    austingreen Senior Member
    13,671
    4,209
    Austin, TX, USA
    larger battery (higher charge rate) along with active liquid cooling, bigger inverter, lower mass, proper software should all be in consideration on regen. Feel may stop a company from doing the most efficient regen.
    In a car like a prius at most 25% of braking energy can be recaptured. In a phev this can increase.
    The big boost though is in efficiency at low speeds of battery to motor versus gas tank to engine.
    Regen recovery is small compared to use to overcome rolling resistance and drag.
    i3 - 138 mpge city, 111 hwy
    i3-rex 127 mpge city, 107 hwy
    accord 124 mpge city, 105 hwy
    accord has lower drag, i3 has lower rolling resistance. Adding the rex engine raises weight and rolling resistance.
  2. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    However, as the battery ages, it would appear as though the chemistry responds differently. My observations over the past 4.5 years is that the internal electrical resistance has become lower. So even though the recharge quantity has dropped from 3.1 kWh to just 2.5 kWh of electricity, the distance I am able to travel with EV has remained consistent. There’s also the fact that the vehicle loosens up over time and consequently becomes more efficient.
    For example, today’s commute to work delivered 14 miles of EV driving. 80,000 miles and 2,400 recharges later, that’s still right on par for what I got when the Prius was new.
    In other words, the net result is showing no loss.
    #102 john1701a, Aug 1, 2016
    alanclarkeau likes this.
  3. hill
    8,799
    Boy, the PiP dynamics/results sure contradict Honda's capacity loss. Ergo their class action lawsuit. Once their traction packs' capacity dropped, their mpg's sank into the bogs -
  4. john1701a
    12,817
    5,303
    58
    257 MPG from my 18.6 mile commute this morning.
    I am clearly not see any degredation from the battery-pack... despite all the miles and the number of charges.
  5. hill
    8,799
    Do you use a kill-a-watt meter or similar device to measure how much energy is going into your traction pack?
  6. john1701a
    12,817
    5,303
    58
    ChargePoint has my entire charging history for each time I parked at work, since way back in March 2012.
  7. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I'm not sure these kW ratings are relevant. Often the main limiting factor is the battery. For example, the Accord Plug-in has a 124 kW motor but it's battery outputs a peak of less than 60 kW.
    I'm not sure why the Prius Plug-in is listed as 18 kW. The motor is 60 kW and the battery has a reported peak output of 38 kW although INL measured closer to 30 kW under full acceleration with the gas engine kicking in.
    This may be useful:
    2015 Honda Accord Hybrid | Advanced Vehicle Testing Activity
  8. hill
    8,799
    - do you mean limits in the battery path?
  9. bisco
    51,892
    my pip has lost about 5-10% of ev miles, but at 28,000 ev miles, i'm a lot higher use than most.
  10. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I'm not sure what you mean....
    The battery has ratings for max output and max input. These can be a lot less than the motor size with a smaller battery pack and a series hybrid mode with a bigger gas engine like in the case of the Honda. Just comparing based on motor ratings alone seems misleading for this kind of comparison, as I understand it.
  11. hill
    8,799
    max charge/discharge 'ratings' are not max charge/discharge. Think coat hanger between the ± terminals. That coat hanger is strictly a 'mechanical' limit based on the wires' diameter. Very little work load, lots of resistance. Electronic limits are your controllers. So, by battery path limits - i simply meant the electronics used to regulate how much can go in or out of the traction pack. Think Tesla, when you buy one with regular power - or upgrade to Ludacris. Ypu may have a 700hp motor - but if the software limits the top 20% - then your battery will deliver accordingly. It's simply a software "rating". So I think we're saying the same thing pretty much.
    #111 hill, Aug 1, 2016
  12. bwilson4web
    16,201
    The right idea but reversed:
    • (117 MPGe) 27 lbs/kW = 3375 lbs / 125 kW - BMW i3-REx
    • (115 MPGe) 32 lbs/kW = 4000 lbs / 124 kW - Accord Plug-in
    • (98 MPGe) 36 lbs/kW = 4000 lbs / 111 kW - Volt
    • (95 MPGe) 194 lbs/kW = 3500 lbs / 18 kW - Prius Plug-in
    The ratio of mass-to-motor_power determines how much energy can be recovered (and how fast it is off the line in EV-only mode.) The BMW i3-REx has the lowest mass per unit of motor power so it can absorb more of the kinetic energy (i.e., regen) before having to use friction braking.
    Sources:
    (1) MPGe - Fuel Economy
    (2) kw - Fuel Economy
    (3) "Test Car List Data" epa.gov for 2014
    Understand I prefer Argonne Labs data because they fully instrument the cars, control the test conditions, and provide data with 0.1 second resolution.
    The Idaho National Labs testing appears to be more focused on 'field' testing and some of their numbers are not well defined (i.e., BMW i3-REx 'cost per mile'.) If there is a specific metric INL have that is different from these sources, bring them out.
    BTW, if there is a conflict in data sources, I've found the web curators quite approachable and responsive to questions from the public. In fact, it makes their day to know people care about the data and their work.
    #112 bwilson4web, Aug 1, 2016
  13. plug-it-in
    plug-it-in Active Member
    179
    113
    Kitchener, ON, Canada
    Check and compare the internal and external dimensions. The Volt slightly bulkier outside and with slightly less passenger room.
  14. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Well sure, you can drop a metal wrench across the + and - terminals and watch the battery flame out...
    I was talking about the recommended/designed power ratings from the manufacturer that are then enforced by the car maker's engineers.
  15. JeffHastings
    JeffHastings Member
    223
    79
    Whippany, NJ
    Yes, a LOT of folks like me keep their car outside; making a a plug-in impractical. Another car occupies the 1 car garage in my condo so the Prius is outside all the time. Running a charge line under the garage door daily would be HIGHLY inconvenient and many other drivers are in the same boat so an awful lot of people will likely NEVER buy a plug-in for that reason alone. Therefore, I see hybrids remaining relevant for the long-term. Right now, low gas prices are depressing sales but that reality won't endure forever.
    telmo744 and alanclarkeau like this.
  16. bwilson4web
    16,201
    I fully appreciate the problem and would add some technical details.
    Our BMW i3-REx was barely tolerable using a 120VAC circuit. The charger that came with it would only use 12A which meant always over night to make up for my daily, 10 mile commute. So I became a 'free charger' vampire looking for all high-capacity, 240VAC 30A, chargers.
    For reasons having to do with a 48 year old house, adding a NEMA 14-50, wired for 50A, turned out to be expensive just under $5k. Yes, I could have done it cheaper but I never want to have it done over again.
    If you have a dryer circuit, the affordable, cost effective solution would be a circuit with a dryer plug on one end and NEMA 14-50 in an outdoor, curb side, all-weather box. Obviously 'condo' issues.
    Another approach would be upgrading the facilities to have a designated, Level 2 EVSE. There are electro-political issues we should discuss in another thread.
    I found that having a plug-in changes your perspective, gestalt.
    Today I was thrilled to find another 'free' charger closer to home and a different business area. I can walk the dogs away from traffic; find food to bring home and; beverages with WiFi while waiting. The new 'free' Level 2 charger is strong and only 3 miles from home, 3% SOC. I'm headed there to walk the dogs and investigate the walk-around places.
  17. El Dobro
    El Dobro A Member
    7,088
    3,270
  18. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Ultimately, in my case, the problem is that to get to a public J1772 (not someone's garage), I'd have to drive a Prime's AER to get to it, one way.
    Seeing as I don't want to just run an extension cord across a sidewalk (granted, not a public sidewalk, but still)... that's part of why I went non-plugin.
    wjtracy likes this.
  19. Tideland Prius
    16,553
    And I think the plug-in crowd gets caught up in it and forget about other people that can't really plug in. Hybrids still have their place and can still help. It would be naive for someone to think that because PHEVs and BEVs are getting more affordable, they're the end-all-be-all. Again, there are many cities outside of the U.S. where multi-family complexes are common and only the very wealthy own single detached houses.
    Pijoto likes this.
  20. bisco
    51,892
    it's the inevitable transition from horse and buggy to automobile. it won't happen overnight, and surely some people took their horse to the grave for one reason or another.
    that doesn't mean hybrids are passé, just that they're a bridge, as toyota stated a long time ago. some have crossed the bridge, many are on it, but most are still avoiding the river. does that make them passé?(n)
    #120 bisco, Aug 2, 2016
    Zythryn likes this.
