ISS Cooling Problem
Discussion in 'Fred's House of Pancakes' started by bwilson4web, Dec 21, 2013.
  1. bwilson4web
    16,374
    Peripherally impacted by the spacewalk repairs, I started looking for more technical information and found a detailed description:
    http://www.nasa.gov/pdf/162182main_STS-116_Press_Kit.pdf
    However, this doesn't do a good job of explaining the big picture:
    • "A" loop - this is an ammonia cooling loop that uses the external radiators to dump heat. Ammonia is the coolant loop gas, not freon, that is compressed, condenses to release heat, and the liquid pumped to a heat exchanger to cool by evaporating. But ammonia is toxic so no part of that loop enters the human occupied space. FYI, freon is less toxic BUT in the limited atmosphere of a spacecraft, not something you want displacing the breathable air.
    • "B" loop - this is a water, heat exchange loop that is chilled by the ammonia system and then 'cold plate' cools the electronics and interior.
    The problem is unregulated, the ammonia loop can freeze the water. This would crack the heat exchanger and risk ammonia coming into the living space, the interior of the station.
    The primary, ammonia control valve, a proportional valve, has failed, apparently in the "cold" mode. But the controllers have found they can operate an ammonia isolation valve, normally and ON/OFF to regulate the cooling . . . sort of. They are commanding it to turn ON or OFF and then 'yanking the power' to leave it in a partial state. In effect the ON/OFF valve is providing proportional control with the ground controllers 'in the loop.' But there is a problem that to control the valve accurately, they really need 0.1 second control and humans and control loops at best are in the 0.2-0.3 second range.
    Now hindsight is always 20/20 and obviously one wonders if having two proportional valves wouldn't have worked better. The second valve replacing the ON/OFF isolation valve. Then if the pump assembly has to be replaced, command the working valve to OFF and problem solved. Alternatively if the ON/OFF valve can stop at a proportional setting by pulling the power at the right time, use a simple timing circuit with two such valves and eliminate the proportional valve. Regardless, the clever trick is figuring out to sustain station operation by using the ON/OFF valve as a pseudo, proportional control valve.
    My impact is each 'space walk' results in a 'mission freeze' on the network I work on. Even though my small part is data recording, in an excess of caution, my maintenance activity scheduled two weeks earlier, Dec 23 through Jan 6, is at risk of being canceled. The activity is to fix a problem that leads to rebooting our monitoring systems due to a latent Oracle vs. Redhat bug. But this has always been a risk associated with maintaining a NASA network.
    Hindsight says I should have scheduled a series of back-to-back, daily maintenance activities, one for each of my 14 systems. If some unplanned "mission freeze" occurs, simply cancel the impacted daily upgrade and then double-up on one of the other activities. <grins>
    Assuming my big activity is going to get canceled on Monday, I'll smile and say, "Thank you Sir! May I have another?" We have had no luck negotiating a modification to an activity. So when the activity is killed, I'll smile and schedule 14, one-day, activities for each of my systems. Meanwhile, I'll preload the upgrade software on the systems.
    If a system fails before the upgrade, I'll 'make operable' by doing the software upgrade at that time and then close the ticket. There is no fault nor foul if an activity is canceled by the requester before the window. So with 14, one-day activities, the probability of a mission problem blocking my activity is substantially reduced.
    In reality, all 14 systems could be updated in one activity but 'putting all eggs in one activity basket' is what is about to delay my current activity.
  2. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Hey Bob...
    Do they normally keep a Soyuz module docked at the ISS for emergency evac?
    If they do- then worst case- they jump in before the air gets toxic and head down to Russia...
    The whole ISS is an amazing feat of engineering- especially considering the way it was built in space and that the first time most modules came together was while in orbit!
  3. tochatihu
    tochatihu Senior Member
    9,854
    3,815
    Kunming Yunnan China
    2001 Prius
    As I understand there are now 6 aboard ISS. That means they should have two Soyuz (es) connected, and functional for de-orbiting.
    One aspect of the cooling impairment is they also needed to switch off a lot of equipment. Including science experiments. So aside from the ones that suit up for EVA or 'drive the arm', there is not much happening up there.
    About the valve, it seems to me that the new cooling pump (to be installed) has a new valve. Is that so?
    There was at least one prior similar problem (2010) and somehow at that time there was no decision made to move towards proportional valving. All of this is what I get from media coverage, I have no insider insights at all. Seems like Bob does, though.
  4. bwilson4web
    16,374
    Actually I would not have cared but it looks like my activity is going to be canceled on Monday. So I'll do plan "B" . . . a series of 1 day 'scheduled activities,' perhaps with an idle day in between, and do the updates then. I'll schedule one activity per system but 'opps' I'll do as many in parallel as I can in the first ones. Then I'll cancel the rest.
    Now I have a special fondness for ammonia refrigeration systems:
    • the first one was ammonia based
    • Summer of 1968 I worked at an ice plant that used ammonia refrigeration
    • One of the largest ammonia refrigeration explosions was in Oklahoma City where I grew up
    Did I mention I was a mechanical engineering student in college? Thermodynamics including refrigeration and Carnot cycles, these are the things I find fascinating.
  5. icarus
    icarus Senior Member
    4,884
    976
    earth
    I still use ammonia absorption fridges. They are quite common for off grid applications as well as
    RVs. With no moving parts with care a good one will last forever. I have one the over 50 years old, and one that's been working continuosly for over 30 years.
    I also worked redoing a ammonia cold storeage wharehouse a number of years back.
    Icarus
  6. fuzzy1
    10,603
    Always!!!!
  7. bwilson4web
    16,374
    I have long wondered if that refrigeration cycle would work using exhaust heat?
  8. icarus
    4,884
    976
    earth
    It needs enough heat to boil the ammonia, and then set up a thermo siphon. Not enough heat and they won't cycle, too much and you risk burning out the boiler.
    Icarus
  9. Chuck.
    2,766
    1,510
    Lewisville, TX (Dallas area)
    This weekend I saw Gravity as it was mentioned in regards to the space walks. The movie seemed a bit far-fetched on the debris. That and the scientist returned in a Soyuz capsule with the parachute deployed in orbit - how do you fix that? :confused:
