Issue: Depress Brake Pedal and Push Power Switch to Start
Discussion in 'Prime Technical Discussion' started by ED23LL, Dec 12, 2017.
  1. ED23LL
    ED23LL New Member
    CALIFORNIA
    I've been randomly experiencing this issue with my 2 month old Prius Prime Premium. Even though I'm depressing the brake pedal and power switch the ignition won't start. I have to do it a couple of times to get the car to start.
    Does anybody also experience this issue? What might be the cause of the issue?
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    do you see "READY" displayed in green on your dashboard?
  3. ED23LL
    ED23LL New Member
    CALIFORNIA
    I don't see any "READY" displayed on my dash.
  4. Prodigyplace
    12,720
    11,852
    Central Virginia
    Sounds like a warranty issue. Either brake pedal switch or something else. The car sees something preventing it from READY mode.
  5. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    Push harder on the brake pedal
    Lee Jay, priuscatprimeguy and scona like this.
  6. Trollbait
    12,836
    There is another thread here about a dead 12 volt battery. Part of the lead up symptoms were trouble starting.
    Whatever your issue, it should be covered by the warranty.
  7. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Perhaps add a delay of maybe 1-2 seconds between the brake pedal press and the power button press. Try not to do them simultaneously.
    Prodigyplace likes this.
  8. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Is there a "Ready" light indication on the panel somewhere ?
    This happens to me with my C ALL the time.......if I don't wait a couple of seconds after pushing the brake to hit the "start" button.
    On the C, I think a green "key" symbol shows up to indicate that all the security checks have passed and it's OK to start.
  9. priuscatprimeguy
    2,730
    2,640
    I asked that question way back in the beginning of this thread
  10. Prodigyplace
    12,720
    11,852
    Central Virginia
    Post 2 asks about READY light.. I see no other instruction about a delay between pressing the brake & pressing Start.
  11. priuscatprimeguy
    2,730
    2,640
    true, sorry:cry:
  12. E-GINO
    E-GINO Active Member
    196
    206
    Rome, Italy
    Could be an issue originated by the combination of low temperatures and a not optimal status-of-charge of the 12V battery.
    BTW around a week ago the car I was renting (a Ford Fusion hybrid) did the same thing two or three times, OAT around 30 F.
    Very scaring, expecially when one did not buy the premium road assistance option... however, after cycling several times the IGN ON pushbutton while keeping pressed the brake pedal, the system started.. I could notice because this time the car did not chime and the steering wheel was unlocked.
  13. ED23LL
    ED23LL New Member
    CALIFORNIA
    Update: I changed my key fob and used the spare that comes with it and never experienced the issue. I will keep you posted incase it happened again.
    Just 2 cents. It's a brand new car and I assumed that both the key fobs have new batteries in them.
  14. bisco
    52,916
    they probably do, but who knows how it was abused between the factory and dealership. just change the battery.
    priuscatprimeguy likes this.
  15. FuelMiser
    1,349
    929
    Monument, CO
    If it was a signal detection issue with the original fob, it should have caused the "key/fob not detected" warning light when you pressed the Power button...
  16. Sam Spade
    2,036
    1,024
    2017 Prius c
    It may not be a battery problem at all.
    That one FOB might just be defective.
    You have a warranty. USE IT.
  17. ifty1989
    ifty1989 Junior Member
    england
    2014 Prius c
    Excel
    Has anyone come to conclusion to this problem. Having it on my 2017 prius no fault codes or anything
  18. bisco
    52,916
    see post #13. for a problem like this, you need to do some investigating.
    test the 12v health, make sure the fob lights up, make sure the brake lights come on when you step on the pedal, etc.
