Issue starting when it is cold
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Chad O, Nov 30, 2012.
  1. Chad O
    Chad O New Member
    Now that the temp has dropped down, I seem to have some problems when I first go to start the car in the morning.. If it is below 35 degrees out is when I'm experiencing these problems. I can push the power button and the radio might come on, but no fan or temp controls. If I sit and play with the Power button pushing it several times or holding it, it eventually will start(after a minute or two).. I should mention that if I try to put it in Drive or reverse, it does nothing until the engine starts.. Is anybody else having an issue like this? Is there a fix to it??
  2. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Chad, congratulations! Your 2010 Prius is the only one that I've ever heard of that does this. Let's check! Anyone else?
  3. rcturner
    rcturner Junior Member
    53
    The only time you should spend on this is the time it takes to get it to the dealer. These thing don't heal themselves.
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,145
    6,988
    Texas Hill Country
    Probably not getting to Ready mode which prevents you from shifting or the gas engine from starting. First guess would be a low 12v battery effected strongly by the low temps.
    Codyroo likes this.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I agree that a good guess would be your 12v battery.
    I also agree that your best move is to simply have it diagnosed at the dealership. You should still be under warranty?
  6. BZzap!
    BZzap! Senior Member
    1,607
    878
    What weight oil are you using?
  7. Former Member 68813
    3,524
    983
    US
    If you actually read the post, the problem is not with engine starting, but rather getting the Ready light. My guess is 12V battery, too.
  8. Andrea Moreland
    Andrea Moreland New Member
    I had a similar issue this morning. I went out to start my Prius and it made the most horrible sound like it did not want to start. Then it was ticking and knocking really loudly for about 10 min.....until it warmed up, I'm guessing. It is 2 degrees outside and only 5 degrees in my garage. So, that may have something to do with it. Is there some way to plug the car in to keep the engine warm?
  9. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Another possibility is the brake switch is not making. Check your brake light reflections to make sure the brake switch is working.
  10. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
  11. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    There is a Toyota Service Bulletin regarding cold soak knocks (which is what it sounds like you are experiencing). Some people have noted this after the car has sat in a cold environment for awhile.
    Could you enlighten us on what happened previously to the knocking you heard. Specifically, what was done with the car prior to shutting down before you started the car? For example, was the car moved from the driveway to the front of the house, the gas engine came on and ran for 2 seconds before being shut down. Then, the next day, you came out and started it and the engine started knocking (like a small hammer hitting inside the engine compartment a few to several times per second)?
  12. Codyroo
    1,826
    515
    Pleasanton, Ca
    Chad O - I had a similar problem to my car and it was the 12 volt battery. Next time it happens, check to see if you still have the "orange light" on the power button and see if the word "READY" is appearing on your dash. If you have a volt meter, take a measurement on the battery terminals (it's in the right rear of the car accessible from the hatch area).
    If your 12 volt battery has had any discharges (leaving a dome light on all night, for example) it greatly shortens the life of these small batteries. I replaced my battery with an OPTIMA battery and this problem went away. The Optima battery is a bit more expensive that the OEM battery, but is supposed to be a lot more rugged.
    My OEM battery lasted about 9 months before problems manifested. I replaced it after 18 months. Likely the car was in a dealership where people were in and out of it and wore down the 12 volt battery.
  13. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yikes, what kind of a garage is that! :eek: Must live in Alaska?
  14. bisco
    52,905
    yes, you can add an engine block heater that plugs in at night. see your dealer or qualified mechanic. you can also do it yourself if you are so inclined and have a place to work that is above 5 degrees.:eek:
  15. Ridder
    Ridder Member
    141
    51
    Netherlands
    Yesterday my Prius didn't start after I got in.
    I couldn't lock the doors anymore after I got out.
    I called Toyota Assistance and they jumpstarted the car and I drove straight away to the dealer.
    It was supposed to be serviced today but I brought it in one day early.
    It's still there.
    The car has only 6K mi on it and I only have it for a week.
    Temperatures were around freezing point ( 0 degr. C, 32 degr. F)
  16. Codyroo
    1,826
    515
    Pleasanton, Ca
    Hopefully they will find out what the issue is. I'm sorry that a week old car is giving you issues, but hopefully it is something that is easy to remedy.
