Issue with JDM Steering Wheel
Discussion in 'Gen 3 Prius Accessories and Modifications' started by The Critic, Feb 2, 2013.
  1. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I have no unusual sounds from the front since changing to the JDM steering wheel.
  2. koipond
    koipond Member
    198
    40
    Any tips on adjusting the tie rods? I've never done that and would love a tutorial so i can get my new leather wheel centered just right....
    SCH-I535 ? 4
  3. Infini
    Infini Member
    169
    30
    Los Angeles
    I'm in need of this as well.
    Talked to my Michanic. He wants to try to get the wheel in as lose as possible with the splines cause messing with the tie rods effects the alignment and will cause camber. Thus will effect the life of the tire and mpg.
  4. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Getting the wheel in as close as possible makes sense. The rest of his explanation makes no sense.
    Camber is the angle of the road wheel relative to the vertical when pointing straight ahead. If it has positive camber the top of the wheel is leaning out--negative is the opposite.
    If done wrong, fiddling with the tie rods will change the toe-in (wheel-to-wheel angle as viewed from above).
  5. Infini
    Infini Member
    169
    30
    Los Angeles
    Toe,
    Toe, I meant toe.
    I also think it makes sense to get an alignment asap.
  6. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    The toe in will only be affected if the adjustments aren't made equally on both sides.
    SCH-I535 now Free
  7. Infini
    Infini Member
    169
    30
    Los Angeles
    Hmmmm equally like, right side one turn left and left side one turn left? I do not know I need to understand this more in order to explain it better.
  8. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I think that's it.
    The thread pitch will be the same for both sides.
