Issues after software update on 2014 Prius V
Discussion in 'Prius v Main Forum' started by borna, Oct 29, 2020.
  1. borna
    borna Junior Member
    venice
    2014 Prius v wagon
    Hello guys, just had safety software update done on this car ,(has only 60k miles) and the next day on the dash Brake , ABS, Traction and yellow (!) went on, and also noticed driver side LED Brake rear light not working as well.
    Just wondering if anyone have experienced anything similar?
    I went back to the dealer and they decline that is related and asking for a $170 diagnostic which I cannot afford at this time due to my income loss
    Thank you for any feedback
  2. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    Which update? Inverter/Motor/Generator or ABS/Brake Booster/Accumulator?
  3. Kenny94945
    Kenny94945 Active Member
    864
    439
    Sausalito
    2016 Prius v wagon
    Brake light could be coincidental or it was out for some time and you never noticed.
    I'll offer this.
    Many of these updates are done by plugging into the connector under the dash.
    I don't believe either of the updates mention above require lifting the hood.
    Perhaps the mechanic left the key on during the software update which drained the battery, causing your warning lights?
    First, check the codes and list, then clear the codes.
    Charge your 12 volt battery.
    See the results and report to us.
    Being on a tight budget, this test and recharge should have no costs.
    I also don't believe that lights bulbs are replaceable in the tail light, you need to buy a tail light assembly.... try a wrecking/ junk yard... maybe $50 (maybe).
    Battery will be at least $100 if not near $200.
    Another co-member may have specific Prius repair/ tests better than I can offer.
    Good luck.
  4. borna
    borna Junior Member
    venice
    2014 Prius v wagon
    Hey thanks guys , it was the Safety Recall 20TA10
    I tried another brake light , also did not worked . I suspect could be related
  5. Air_Boss
    4,259
    1,197
    New Yawk
    A bad connection to a wheel speed sensor will trigger "Brake, ABS, Traction and Yellow (!)"
    borna likes this.
  6. borna
    borna Junior Member
    venice
    2014 Prius v wagon
    Or could it be a bad sensor itself ?
    Air_Boss likes this.
  7. Air_Boss
    4,259
    1,197
    New Yawk
    Yes, though in my experience it's the harness that gets snagged and the connector jostled, resulting in a poor connection. Also occurs if moisture gets into the connector.
    borna likes this.
  8. borna
    borna Junior Member
    venice
    2014 Prius v wagon
    I'm just puzzled why the LED tail brake light not working , will a bad sensor cause your rear brake light stop working?
  9. Air_Boss
    4,259
    1,197
    New Yawk
    No, that would either be a brake harness or brake LED issue.
  10. borna
    borna Junior Member
    venice
    2014 Prius v wagon
    I switched the left light to the other side and it works !
  11. Air_Boss
    4,259
    1,197
    New Yawk
    So it's the LED lamp or the pigtail to it.
  12. borna
    borna Junior Member
    venice
    2014 Prius v wagon
    Rear driver side brake LED light works on the opposite side but not where it should :mad:
  13. Air_Boss
    4,259
    1,197
    New Yawk
    So it's the right side harness breakout for the lamp, or its connector.
  14. borna
    borna Junior Member
    venice
    2014 Prius v wagon
    I took it to mechanic and their reading the codes say rear speed sensor , just wondering if all these are related
  15. Air_Boss
    4,259
    1,197
    New Yawk
    Damage to the harness that carries both rear speed sensor and right read brake wires.
    borna likes this.
  16. borna
    borna Junior Member
    venice
    2014 Prius v wagon
    Took it to the my mechanic he found out rats been chewing on the wires !
    I'm lucky they did not chew on hybrid system wires at least .
  17. Air_Boss
    4,259
    1,197
    New Yawk
    There is a history of rodents liking Toyota wire coverings. There must be some peanut butter mixed in the PVC.
    borna likes this.
  18. borna
    borna Junior Member
    venice
    2014 Prius v wagon
    Soy based wiring !
    Then again they chew on anything , but its puzzling to me how did they get inside the car :mad:
  19. ChapmanF
    19,042
    There are numerous threads here on PriusChat about preventing such entry. They are usually titled something about mouse-proofing rather than rat-proofing, but you can probably copy them as long as the rats can't read.
    borna likes this.
