Issues with 2012 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by STC315, Nov 18, 2022.
  1. STC315
    STC315 New Member
    Yuma, AZ
    L Eco
    Greetings from Yuma, Arizona. New member with a 2012 base hybrid with 181,000 miles. Right after getting an oil change at Valvoline, car began running like crap and won't stay running. Got trouble codes P3190 and P3191. Tried replacing MAF sensor because it's what Dr. Google said. No luck. I think it's something from oil change but can't imagine what an oil change could do unless they didn't put oil in it. Oil is up to the top dimple on dipstick. Any ideas?
  2. STC315
    STC315 New Member
    Yuma, AZ
    L Eco
    I have video of it on my Youtube but I couldn't upload due to new member restrictions. It's STC315 on youtube and video title is prius issue.
    Thanks,
    Sam
  3. jolynf13
    jolynf13 Junior Member
    25
    san diego
    Mine turn out to be fuel pump...u might have some oil on your throttle body. First cleaned maf sensor, throttle body, egr pipe and egr cooler. Mine shows same bars for fuel but my fuel pump stop working...no gas reaching the engine
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Post some non offensive comments like Scotty kilmer used to say on his product give aways and you’ll be able to post videos. Do it enough and you’ll be a senior member in no tome.
    #4 Grit, Nov 19, 2022
  5. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    First mistake was going to a quickie oil change place. Though me and the other techs at hyundai made a lot
    of money replace pistons and/or engine when the didn't tighten the drain plug or left the old oil filter gasket on! (y)
    You need a code reader, or techstream. You can't trust goog....
    You should check the engine compartment, they might have pulled something off it the removed the cover
    for the head. A hose might be off, or loose.
    Grit likes this.
  6. Paladain55
    Paladain55 Active Member
    414
    172
    The South
    Your motor has a crazy start up knock in that video. So you probably have some big problems above a maf. I find it some what funny that the car is misfiring and it isn't giving you a code for it. lol
    Anyways, go ahead and remove the spark plugs and look at them. make sure the gap is correct and if they are too carbon clogged or worn for the spark to jump the gap replace them. Post a picture, make sure one isn't cleaner than the others etc...
    next i would just pop off the fuel tank lid and just make sure you aren't that 0.1% that got bad gas before a gas station finally replaced their tanks. If you see water or trash anything separate down at the bottom around the fuel pump from the actual gasoline in the tank.
    After that test for a head gasket failure. Do the leak down test and get the coolant sniffer kit and see if the car fails.
    *Also, definitely pop the throttle body open and check for fluid in the intake manifold.
    Grit and Mendel Leisk like this.
  7. Mendel Leisk
    42,361
    Unless you’ve got a very good oil catch can installed, you will see fluid there; it’s “normal”. :rolleyes:
    CR94 and Grit like this.
  8. Paladain55
    414
    172
    The South
    i say that's fine. but he is knocking so better do it all and see if you get lucky some where lol
    Mendel Leisk and Grit like this.
  9. bisco
    52,876
