Issues with Interior Dome Lights Turning On By Themselves!
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by col127, Jan 4, 2013.
  1. col127
    col127 Member
    345
    Illinois
    Hi All,
    Been noticing a strange phenomenon in my Prius C lately.
    The interior dome lights in my car are getting switched on mysteriously. I've noticed this several times. They are only set to turn on when the door opens (middle position).
    However, a few times, I would lock the car, the lights would turn off inside and if I returned to the car later on (i.e. in the morning after locking the car at night), I would see the lights are on inside the car. And no, I didn't press the unlock key or grab the door handle - I know that turns the car lights on that way...
    What's going on? Has this happened to anyone else?
    I guess I'm going to need to bring this in for warranty.
  2. TrafficMPG
    TrafficMPG Junior Member
    It's probably part of the Smart key system. In my Rav4, it would turn on the lights as I approached the car.
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    It does the same thing in my Gen II! Nice feature to have!
  4. col127
    col127 Member
    345
    Illinois
    Lol... maybe I'll test it again without the key in my pocket. I just dont' want my battery draining or something.
  5. allroadusa
    allroadusa New Member
    16
    France
    2012 Prius+ MPV
    It's part of the smart key system. Don't worry, the dome lights will shut off again when you go away
  6. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    Yep, as above, the SKS will turn the light on when you approach, if the switch is on the door setting. You can ask a dealer to turn this function off if you wish. The delay before the lights fade to off can also be customised - the default is 15 seconds, but 7.5 seconds or 30 seconds are also options the dealer can switch to. That setting would apply to all situations where the lights fade to off on delay.
  7. col127
    col127 Member
    345
    Illinois
    Thanks everyone! Didn't know the car had the feature. :) always learning new things about my prius c!! :)
  8. CMJAnew
    CMJAnew Member
    120
    24
    Its just like your refrigerator
