It’s Christmas?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Acadianer, Apr 1, 2021.
  1. Acadianer
    Acadianer Member
    123
    82
    Technology
    No, not really.
    Our 2010 does light up like a Xmas tree though... I’m not sure if any other lights can turn on the dash really. Started yesterday when I stopped at my parents. Then take pedal felt weird and an odd noise was heard. When I started the car when leaving, all The lights were on. This morning I tried unplugging the battery for fun, but nothing changed. Got on the highway to go to work and cruise won’t work, the cruise symbol just flashes...
    many ideas?
    Would a normal obdii reader tell
    Me anything?
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Yes but you need an OBDII reader that's Prius literate. Simplest would be one of the many Bluetooth or WiFi units available on Amazon. There are cheap ones there, but you can't count on their quality. Carista is popular. They have a subscription app that has a free trial; that would be the most expedient. Or connect it to one of the many iOS or Android apps that will read your codes. The ultimate reader would be Techstream on an old Windows laptop with the cable -- also available on Amazon or Ebay.
    Also, you're asking Prius Prime owners. The principles are the same for both cars, but it'll be better if you click the "Report" button on your post and ask the moderator to move it to the Gen 3 Prius Care, Maintenance & Troubleshooting forum.
  3. ETC(SS)
    7,410
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Check the 12 V battery first......and it's main cable connections.
  5. Acadianer
    Acadianer Member
    123
    82
    Technology
    Yeah, we put a new battery in last month when is was doing other weird things and would start, then wouldn’t turn off once started lol. Terminals were fine this am
  6. sam spade 2
    7,035
    2,804
    2017 Prius c
    Was the new battery fully charged before being installed......or soon after ?
  7. Acadianer
    Acadianer Member
    123
    82
    Technology
    Yes
  8. Acadianer
    Acadianer Member
    123
    82
    Technology
    I just noticed while out for lunch that the regen brakes don’t charge
  9. jerrymildred
    11,517
    14,164
    Tampa, FL
    Are you sure the inverter coolant pump is running?
  10. Acadianer
    Acadianer Member
    123
    82
    Technology
    Not sure no, how would I know/check this out?
  11. jerrymildred
    11,517
    14,164
    Tampa, FL
    For one thing, you ought to hear it when the car is in ready mode and you have the hood up. Also, if you take the cap off the inverter coolant reservoir, you should be able to see the coolant swirling in it.
  12. Acadianer
    Acadianer Member
    123
    82
    Technology
    Ok, that’s the larger reservoir on the drivers side correct?
  13. Mendel Leisk
    42,119
    N’mind Christmas, dealership time?
  14. jerrymildred
    11,517
    14,164
    Tampa, FL
    The one with the pink fluid in it right behind the inverter.
    https://c8.alamy.com/comp/bhtwbg/2010-toyota-prius-hybrid-engine-brake-fluid-and-inverter-coolant-bhtwbg.jpg
    Edit to add: now that I think more about it, you might need the dealer as @Mendel Leisk suggests. Please don't be offended, but If you don't know where the coolant reservoir is you are likely to not be ready to take this on yourself.
  15. Acadianer
    Acadianer Member
    123
    82
    Technology
    My local dealership won’t have anymore of my business. The next closest dealership is beyond a border that I’m aloud to cross because of pandemic restrictions
  16. Acadianer
    Acadianer Member
    123
    82
    Technology
  17. rjparker
    rjparker Tu Humilde Sirviente
    10,796
    6,776
    Texas Hill Country
    Probably Christmas for the dealer's service department. These cars have problems with their brake master cylinder and pump. I would take it in to be diagnosed as it can be a safety concern. Perhaps Toyota Canada has a customer support program to help if this proves to be the issue.
    #17 rjparker, Apr 1, 2021
  18. Acadianer
    Acadianer Member
    123
    82
    Technology
    Rear drivers side bearing was shot. The connector was also corroded. $250 for a new bearing, $50 for a barely used wire. No more Xmas tree
    privilege likes this.
  19. privilege
    privilege Active Member
    659
    169
    Birmingham
    $250, for a wheel bearing ? holy crap , is it some proprietary size or something ?
  20. Acadianer
    Acadianer Member
    123
    82
    Technology
    Keep in mind, $250cdn... FOR THE CHEAP 1 YR WARRANTY ONE!!! The « good » one was just under $500. The wire was a $50 used wire... new wire was 3 days and $200. Think it’s time to put the ole Prius for sale LOL
