It’s hot in CA why does fan take forever to kick on after starting car?
Discussion in 'Gen 4 Prius Technical Discussion' started by 1stPriusLA, Jun 4, 2018.
  1. Merkey
    Merkey Active Member
    315
    285
    Birmingham, Michigan
    Thanks
    Raytheeagle likes this.
  2. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    "It's hot". I'd love to swap temps with you! Looks like you'll have a high of around 72 degrees in LA today compared to 101 degrees in Las Vegas.
    1stPriusLA likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    Is there a setting for "rear camera delay" ?
    If you stop smoking your tires when backing up, maybe the camera could keep up. :ROFLMAO:
    kithmo likes this.
  4. sam spade 2
    7,035
    2,803
    2017 Prius c
    A whole 10 seconds ?
    Please make the pain go away. :rolleyes:
    kithmo and Mendel Leisk like this.
  5. Diemaster
    Diemaster Active Member
    295
    260
    so. cal
    It's a Prius. The only way the tires will smoke is if you get a lit cigarette stuck in the treads.:LOL:
  6. Mendel Leisk
    41,467
    Yeah, close to ten sconds, interminable, lol. Anyway, from the owner's manual:
    1stPriusLA and alanclarkeau like this.
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    As @alanclarkeau mentioned earlier, home air conditioners do the same thing. The fan doesn't start till there's something cold to blow through it. Also, on the home a/c, the fan continues to run after the compressor stops in order to avoid stranding cold air in the ducts and wasting it. Probably unnecessary in a car since the ducts are so short.
    alanclarkeau likes this.
  8. sam spade 2
    7,035
    2,803
    2017 Prius c
    There is a similar reason.
    When the A/C shuts off, the evaporator is still wet and somewhat cold. After it sits a while, it is then wet and warm or HOT.
    If you blast air through it immediately upon starting, you get a BLAST of hot damp air. Not what you want.
    Patience is a virtue.
    RCO and jerrymildred like this.
  9. bisco
    51,952
    i open the doors in that kind of heat and stand outside waiting for some to escape. so 10 seconds wouldn't bother me.
    jerrymildred and Raytheeagle like this.
  10. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    If it's hot - I've remotely opened the windows anyway.
    RCO and kithmo like this.
  11. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Mine does, it takes about 10 seconds for the Nav screen (aka reversing camera screen) to boot up, by that time I've down to the end of my drive using the mirrors.
  12. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Don't you just love the global opening (and closing on UK models) on windows
  13. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    or turn off the traction control (Gen 4)
  14. alanclarkeau
    7,045
    7,592
    Mine close too!!
  15. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Good E.S.P. from afar, I guess (y)
    Merkey and Raytheeagle like this.
  16. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Never got around to setting mine up. Is it via the upper MID, or an app?
  17. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Via Carista app (y)
    RCO likes this.
  18. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Ah, so that's why I haven't done it. Mine is a lease car and I'm a cheapskate!
  19. alanclarkeau
    7,045
    7,592
    ask your dealer - who should have done it before they gave you the car!!!!
  20. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    He's gone away, fired? Deceased? Posted? Exterminated? Otherwise disposed of.....?
    Anyway thanks, Alan.
