It happened. Flat tire. No spare.
Discussion in 'Prime Main Forum (2017-2022)' started by JMalmsteen, Dec 21, 2017.
  1. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
  2. bb4srv
    bb4srv Active Member
    140
    107
    2018 Prius Prime
    Technology
    How you get all the flats??? In my 24 years of driving, I experienced only 1 flat tire and that was in 1990s where there's no TPMS. All the cars I've owned, I removed the spare tire and all the jacks and wrenches to save weight.
    Nail would usually result in slow leak so the TPMS would kick in or through regular pressure checks.
    HPrimeAdvanced likes this.
  3. frodoz737
    frodoz737 Top Wrench
    4,800
    2,560
    33
  4. bwilson4web
    16,531
    Become a customer of Lowe’s or Home Depot.
  5. bisco
    52,841
    live near a housing boom.
  6. padroo
    padroo Senior Member
    2,763
    2,253
    I will be driving to Florida next month and will have a full size spare in the back.
  7. padroo
    2,763
    2,253
  8. DavidA
    2,349
    1,825
    Chicago western burbs
    ...and not a duplicate post, I will also be driving to Florida late next month and will also have a spare donut in the back.
    Geo Dude and HPrimeAdvanced like this.
  9. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    I guess that Florida has all those nails for us to get flats with?! Har, har. They've saved a few for us out here in Socal, as evidenced by my 2, nail-induced adventures here during my first few months of Prime ownership! Yowwch!!
    AChoiredTaste.com
    deadmoney33 likes this.
  10. tchan2700
    tchan2700 Junior Member
    30
    I drove from CA to Nevada and back with a spare tire. Never had to use it but it was one huge thing I didn't have to worry about. But then when I got back to CA, my tire was completely flat due to a screw and I had to use the spare.
  11. DavidA
    2,349
    1,825
    Luckily I didn't need to use the stowed donut tire on my 2,700 miles to Florida and back. Felt good that it was there, though. What I did see was a ton of drivers changing tires on the sides of the roads, or waiting for help because they couldn't change a tire. Flats happen.
  12. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Not sure if this is any help to anyone, but doughnut spares can usually be had at a dealership for free. Just look where they throw all the old tires or look near the detail shop. Guaranteed they have a few sitting around which the guys would love to just get out of their way. I say this because we usually ended up tossing them in a dumpster if nobody took them.
    Also - for what it's worth. A Honda Civic rim will generally fit a Toyota. Had a Civic "steely" rim on my Yaris after I hit a log laying in the road at 55mph. Totally destroyed 2 rims instantly. But the Civic "steely's" were a perfect fit. (We pounded the other rim back into shape enough to where it would balance).
    So be sure to check any Honda dealership as well.
    Geo Dude and padroo like this.
  13. Mendel Leisk
    42,341
    Check the tire condition and age. Ten years since the tire's been manufacturered, I'd pass.
    Some may, a lot don't: different bolt circle, lug nut seat style, hub opening.
    Geo Dude, HPrimeAdvanced and PT Guy like this.
  14. Jayne K
    Jayne K Member
    50
    27
    Utah
    I bought a full at Les Schwab and yes it fits in the cargo area behind the passenger seat if you lay it down.
  15. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    A problem is that if someone crashes into you that loose tire becomes an unguided missile inside your car. There's no good way to lash it down that I've seen. A compact spare behind a front seat might be OK if you can spare the room.
    Mark57 likes this.
  16. Insighter
    Insighter Active Member
    409
    287
    SoCal
    I had heavy-duty steel "D" rings installed in my trunk for a cargo net. The two rear ones (near the bumper) were expensive (around $250, IIRC) because my installer had to take the bumper off and drill holes for them. However, the two front ones (near the back seat, circled in yellow in the attached photo) mounted very quickly and easily with bolts because there are caps there that you can pull out that hide already-threaded holes.
    So, for the price of a couple of "D" rings and bolts, you can have two very sturdy attachment points. You could run a cable or chain through them and through a spare tire, and I think that would secure it very well. You could even use a separate cable to attach the spare to each side, which would be even stronger.
  17. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Would it be possible to stand the tire up and lash it to the back seat utilizing the child seat attach points on the back of the seats? I've utilized those attach points on a few occasions to lash down some RC airplane equipment for the ride home. Seems to work pretty well for what I've used it for.
  18. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    Putting in another word for plug kit and mini-compressor. Fixed a flat on our other car with self-sealing (didn't) tires in less time that it would have taken to put on a spare. And much cheaper. Plugged our Prius tire on the Alaskan Highway last year and no loss of air since. Also carry Gorilla Glue and assortment of large diameter screws if the hole would be too large for a standard plug. That would be a temporary fix! I am also aware that a blowout or sidewall damage would cause some of the hassles and costs others talk about above.
  19. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    HaHa - now there's an idea! I've not seen the big screw/glue trick in a long while. You grow up on a farm like me? Because that's an old timers trick.
    #259 dubit, Aug 6, 2018
    Geo Dude likes this.
  20. PA Prius
    762
    251
    SE Pennsylvania
    Nailed it.
