It happened. Flat tire. No spare.
Discussion in 'Prime Main Forum (2017-2022)' started by JMalmsteen, Dec 21, 2017.
  1. JMalmsteen
    JMalmsteen I love my Prius!
    287
    266
    Long Island, NY/Lancaster, PA
    We replaced the traction battery on our 2007 Prius for 3k at the same dealer that quoted 1k for the tie down (Lancaster Toyota, in PA).
    VFerdman and HPrimeAdvanced like this.
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Neither one has a good chance of success.
    jtv, Mendel Leisk and HPrimeAdvanced like this.
  3. Lee Jay
    5,850
    4,036
    It's not easy to get good statistics on flat tires. However, I've dug up some things.
    The average US driver will experience 5 flat tires in their driving lifetime.
    Of those 5, 75% are either slow leaks caught before the tire is undrivable or caught in parking lots before driving.
    Of the remaining 25%, the most common causes are improper tire inflation pressure (mostly low pressures causing excess heat leading to blowouts), rubbing and sidewall damage caused by hitting curbs and other objects on the road, and wearing the tires down beyond the wear bars until they start to leak. The causes of the slow leaks are usually different (punctures, leaking valve stems, etc.).
    In other words, if you properly maintain your tires (proper pressure, replace at 4/32 tread remaining) and drive carefully enough not to hit things, you stand a better than even chance of making it through your entire driving life without a flat leaving you on the side of the road.
    Thinking back, I think I've had 6 "flats" in my life. Two were caused by improper tire maintenance. One was low pressure, one was worn down beyond the wear bars (neither were my job to maintain). Of the other 4, 3 were punctures by screws or nails which led to slow leaks and one was a defective side wall from the manufacturer leading to a slow leak through the bead.
    HPrimeAdvanced likes this.
  4. JMalmsteen
    287
    266
    How much room do you have left in your trunk with the donut spare?
  5. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Tons, because it's just me!! I fold down the seats. That's why you hear me bellyaching about wanting a coupe Prime; I don't WANT seating for more than 2 people. If you had to accommodate 4 or 5 people, with 3 months' worth of luggage, and guitars and amps, it might get a tad tight! I just hate buses (SUV's)! In that case I just rent an appropriate Land Barge!!
    JMalmsteen likes this.
  6. VFerdman
    VFerdman Senior Member
    1,200
    1,218
    Western Massachusetts
    That is not unreasonable for the traction battery. Perhaps $1K for the spare hardware is not that unreasonable either. And that is the real reason manufacturers are deleting the spare. It's a rather large chunk of savings for them.
    So is there actual room for a spare in the Prime? I though they used the space for the spare for more battery and adding spare was only possible by taking up some luggage space.
    Geo Dude likes this.
  7. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    The spare tire well in the unibody is below the battery and unused, but per @Lee Jay, it's not deep enough to hold a spare still.
  8. VFerdman
    1,200
    1,218
    Wait, what? There is a well for the spare that is not big enough for a spare? How does that make sense? Is it just wasted space? Or is there no space for a full spare? Is it big enough for a doughnut? A doughnut spare is better than no spare.
  9. Prodigyplace
    12,711
    11,848
    Central Virginia
    They reused the unibody from the Gen 4 on the Prime. Some Gen 4 trims have a spare tire.
  10. VFerdman
    1,200
    1,218
    Seems like an afterthought, not real design. I am surprised at Toyota, but I understand that it saved them a bundle in engineering work by reusing the unibody. But still, it's just comes off as half-assed GM of the 80's kind of car building.
  11. Mendel Leisk
    42,322
    There's no room on the the Prime, because it continues to be essentially a regular Prius, with a bolt-on Plug-in kit. It's a compliance car. If they wanted to they could get a spare in there, at the least a drop-down truck style spare. But it would take engineering, a rework of the bodywork.
    Geo Dude, scona and VFerdman like this.
  12. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    An aftermarket mini-spare was the only thing that worked for my sidewall gash in my Energi I discovered after work. Items 1-3 & 5-7 were useless in my situation. My #4 was to call the house for someone to bring the spare from the garage and I was on my way a few minutes later; road trips, the spare comes along. A new, matching tire wasn't available locally so I drove on the spare for nearly a week while waiting on shipping.
    It's always best to move off the road to a safer area. I have standing instructions to all my family that's it's OK to ruin a flat wheel/tire in doing so; that's what the spare is for. The same goes for a minor wreck. My wife has a co-worker dealing this Christmas with a son who was seriously injured by another vehicle while standing next to his wrecked car on the highway.
  13. Sid786
    Sid786 Active Member
    267
    148
    Cherry Hill, NJ
    Thanks Mendel, your response is very helpful.
    Wheels for 2017 Toyota Prius | Toyota Parts
    In the above link, can someone please tell me the difference between:
    42611-47440 Wheel, Alloy (15, TYPE A)
    42611-47450 Wheel, Alloy (15, TYPE B)
  14. Prodigyplace
    12,711
    11,848
    Central Virginia
  15. VFerdman
    1,200
    1,218
    Well, a rework of bodywork not just in the spare whell department would behoove Toyota in this case :)
  16. Lee Jay
    5,850
    4,036
    The G4 with spare is shown below. Note that the tire is thicker than the recess so they surrounded the tire with about 3" of foam.
    This is the area below the Prime's battery. Note that the battery is sitting on the pan at the same place where the foam sits:
    And this is my arm in that location. This is nowhere near thick enough for even a compact spare:
    Geo Dude, VFerdman and HPrimeAdvanced like this.
  17. frodoz737
    frodoz737 Top Wrench
    4,798
    2,560
    33
    Doesn't the Prime come with cargo tie downs like Gen III's?
  18. fotomoto
    5,639
    3,815
    So. Texas
    Interesting. But, yes, that is "somewhere" near enough space. I just measured my mini-spare @ 6 inches and my hand (5ft 10 in. frame) at 5.5 inches across so if your hand is approx. the same size, there appears to be enough room. Now getting to it easily would be another can o' worms. Let's see, Step 1: Loosen battery connections. Step 2: lift battery up.... :p
    Besides the battery being in the way, I suspect another big reason for not making room for the spare would mean an intrusion into gas tank capacity to gain the necessary clearance.
  19. frodoz737
    4,798
    2,560
    33
    They didn't want to give up cargo space...which is a selling point.
  20. Lee Jay
    5,850
    4,036
    It's not. My hand is 3.5" wide in that direction.
    fotomoto likes this.
