It has begun... Prius Modding
Discussion in 'Gen 5 Prius Main Forum' started by Preebee, May 17, 2023.
  1. thetoys
    thetoys Member
    50
    29
    Toronto, ON
    2024 Prius Prime
    XSE Premium
    #21 thetoys, Jul 18, 2023
  2. PriusPrimetime
    71
    59
    FL
    2023 Prius Prime
    XSE
    #22 PriusPrimetime, Jul 22, 2023
    Agent337 likes this.
  3. Preebee
    Preebee Senior Member
    871
    774
    Midwest
    2023 Prius
    I believe it will lead to more harsh cornering points on the app. And there's nothing wrong with that. ;):cool:
  4. PriusPrimetime
    71
    59
    FL
    2023 Prius Prime
    XSE
    This the Toyota App? My salesperson is dropping off the car tomorrow at 9am and said this was the only thing we need to do when they get here. It actually tracks how you drive?
  5. Preebee
    871
    774
    Midwest
    2023 Prius
    Yes, if you opt in. It's called drive pulse and trips.
  6. PhoS
    PhoS Active Member
    258
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    The 1" drop sounds pretty ideal. I'll probably wait a little longer to see what else comes out but I will definitely be doing springs and a rear sway bar at the minimum. I don't really want to fork out 2k for a set of coil-overs and risk having too firm of a ride. The stock ride is pretty good but I think the weight transfer/body roll could be tidied up a bit.
    Agent337, Preebee and PriusPrimetime like this.
  7. PriusPrimetime
    71
    59
    FL
    2023 Prius Prime
    XSE
    Yeah, when i see my car sit next to a stock Model 3 at a charge station, the Prius does look higher. I'll for sure be doing springs. If others are not released in the next few months I'll likely order those RS-R's.
  8. Jim Call
    Jim Call Active Member
    107
    115
    Asheville
    2023 Prius
    100% plug and play. Find it on eBay for about $80 for the complete kit. Yep, more than worthwhile!
    thetoys likes this.
  9. thetoys
    thetoys Member
    50
    29
    Toronto, ON
    2024 Prius Prime
    XSE Premium
    Thanks Jim:
    The horn is from which model Lexus and Year?
  10. PriusPrimetime
    71
    59
    FL
    2023 Prius Prime
    XSE
  11. PriusPrimetime
    71
    59
    FL
    2023 Prius Prime
    XSE
  12. Roqu3
    Roqu3 Member
    92
    63
    Lima
    2019 Prius c
    That is like the red bullet thing that some people say it works and others that is just a scam/snake oil/etc, search for "red bullet vvti" on the forum to see those very detailed discussions
  13. PhoS
    PhoS Active Member
    258
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Those are some of the most legit wheel spacers I've ever seen with the extended lug nuts, washers etc. Some will argue increased wear and tear on wheel bearings but I doubt it's even measurable.
    Add me to the non-believer crowd. The ECM controls the VVTI actuation, one would think they would tune them for optimal performance from the factory?
    Roqu3 likes this.
