It's Been a Long Time/ What I've Learned
Discussion in 'Gen 3 Prius Fuel Economy' started by DrScooter, Dec 7, 2015.
  1. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    While an analog gas gauge may seem to be more accurate, I find they vary a bit with temperature and also hit E with a few gallons left in the tank, so really no big difference. On my Prius, each bar corresponds to about a gallon of gas, so when 9 bars are gone and one is left it's about a 9 gallon fill-up. When the last bar starts flashing it's 10 to fill up, and about 2 left in the tank. By that time I've gone 400-500 miles which is farther than I can go in any other car I've owned, excepting the Chevy pickup with the 34 gallon tank.
    I'll save my whining for the digital speedometer. An analog speedo (ie, moving needle) makes it so much easier to judge the rate of change of speed.
  2. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    Saved me the effort of typing! Except I prefer the digital speedometer.
  3. yeldogt
    yeldogt Active Member
    810
    313
    NE
    The "extra" services are a huge profit center for the dealerships ... I'm amazed at all the "protection" plans available .. from lost keys, interior protection .. wheels and tires .. unreal. Same goes for the service department -- they try and sell a $99.00 Tbody cleaning for a two year old car w/ 25k on it .. as "recommended " .... to maintain fuel economy. Some goes for injector cleaning and the BG brake flush.
    I had my local guy do the transaxle around 100k -- questionable .. but easy to do.
  4. DrScooter
    DrScooter Junior Member
    62
    St.Louis
    Okay, fair enough. I'm a math "challenged person. Now my brother and his kids love it. Even tell math jokes and laugh and laugh, me I just don't get it. One time I had a Math Teacher and he taught us how to figure out the best value in a Pizza if we had to choose between round and square for your money. You must admit, that it's an odd country when seemingly the only people who can use the Metric System are drug dealers ..............
  5. bisco
    52,544
    i buy the pizza that taste good to me. seems to be the bet 'value'.:cool:
  6. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    I choose the pizza that has the most calories, which coincidentally is often the one that tastes the best. I've even calculated calories per dollar when choosing a pizza. You almost always get more pizza per dollar ordering the largest size pizza. It's an easy mistake to think that going from a 12" pizza to 14" is only a 16% increase in pizza, but the area grows exponentially with an increasing diameter, and the true increase is 36%.
    Regarding new tires; they often get poorer fuel economy for several reasons. First, if the new tires are the same model as the old set, then they have more tread and a larger circumference, which means the odometer will under-report miles driven compared to the worn tires. Second, the increased tread creates higher rolling resistance since more rubber is being forced to bend as the tire rotates. Third, you're traveling faster on the new tires at any displayed speed since the increased tire diameter causes you to go more distance per revolution of the wheel. What was indicated at 60 MPH on worn out tires is a little faster on the new tires even though the speed indication is the same. Increasing speed decreases fuel economy.
    #26 Redpoint5, Dec 13, 2015
  7. Vman455
    Vman455 Senior Member
    540
    556
    The Middle
    Stability, as in: understeer. Higher tire pressures in front will increase the tendency to understeer. Front sway bars also increase the tendency to understeer. Vice versa for oversteer. Understeering is safer in panic situations for inexperienced (read: the vast majority of) drivers, so nearly all mass-market cars have moderate to significant understeer dialed in from the factory.
    retired4999 likes this.
  8. Coach
    Coach New Member
    16
    Sacramento
    One more gripe: after driving around sunny California I've noticed the sun visor is a bit short when trying to block the sun in the driver side window. I realize the sun visor has to be short to fit when it's in its normal position in the front windshield. However, there should be an insert in the sun visor that allows you to extend the length of the visor to cover the driver side window.
    CR94 likes this.
  9. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    Agreed.
    And "VisorMates" on Amazon was the simplest fix I found:
  10. Coach
    Coach New Member
    16
    Sacramento
    FroggyTaco - thanks for the info regarding the "Visor Mates." I'll order mine off Amazon too.
