Its hard to believe - body side molding
Discussion in 'Gen 2 Prius Main Forum' started by FJRCRAZED, May 5, 2006.
  1. barbaram
    barbaram Active Member
    912
    70
    Trenton, NJ
    Any photos of the angled install?
  2. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    <div class='quotetop'>QUOTE(Rick Grahn @ May 6 2006, 06:43 AM) [snapback]250696[/snapback]</div>
    Pics please????
    <div class='quotetop'>QUOTE(barbaram @ May 13 2006, 05:37 AM) [snapback]254659[/snapback]</div>
    I second that!!
  3. Prizzle
    Prizzle New Member
    123
  4. bagwell
    592
    49
    the woodlands, tx
    <div class='quotetop'>QUOTE(Prizzle @ May 16 2006, 10:08 AM) [snapback]256245[/snapback]</div> gracias!
    looks great (esp without the without the wheel trim rings!)
    I think those are the perfect height / rake
  5. Prizzle
    Prizzle New Member
    123
    <div class='quotetop'>QUOTE(bagwell @ May 16 2006, 11:22 AM) [snapback]256257[/snapback]</div>
    The way I did it ( or tried) was to start at the rear at wheel well height and rake forward at the same or slightly lesser angle as the door handles ( which in turn is a slightly lesser rake than the crease above the handles) The effect is that all of the lines converge at a single point forward of the car, which to my eye both gives the car more apparent length and an apparent lower profile.
  6. tanteb & rgrpick
    tanteb & rgrpick New Member
    95
    Prizzle, would you mind if I print a copy pf your car, with your description. Might be easier when I take it in to be done.
    TIA (hopefully),
  7. Prizzle
    Prizzle New Member
    123
    <div class='quotetop'>QUOTE(tanteb & rgrpick @ May 16 2006, 05:54 PM) [snapback]256519[/snapback]</div>
    It's in the public domain now! Glad to be of help!
  8. tanteb & rgrpick
    95
    <div class='quotetop'>QUOTE(Prizzle @ May 16 2006, 05:57 PM) [snapback]256520[/snapback]</div>
    Thanks
  9. Prizzle
    Prizzle New Member
    123
    <div class='quotetop'>QUOTE(tanteb & rgrpick @ May 18 2006, 08:02 PM) [snapback]257764[/snapback]</div>
    Yer welcome and I am flatterred.
    Gonna start raining again here tomorrow for another week or more.
  10. Graz
    Graz Member
    179
    28
    About 2 months after I put my moulding on, I screwed up and parked next to a lifted GMC 1500. Guess what I found on my door after I came back to my car???
    A dent and scrape about an inch long on the driver side door about 8 inches under the window. Why don't they make these Prii out of the same plastics that they used to make the Fierro out of. Or the same stuff that Bell used to make telephones out of. It has to be lighter than that CHEAP LIGHTWEIGHT TIN that Yota uses.
  11. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(Graz @ May 18 2006, 09:47 PM) [snapback]257890[/snapback]</div>
    Yup. This is the only thing that keeps me from spending the money and time to put the "protectors" on. When I park next to other cars, I realize how few of the doors would actually strike the protectors if swung all the way out. Pretty small percentage! The BEST solution is to require everybody to have door edge guards on their own cars. If everybody had it, everybody is protected, no matter the shape/height/size of the other door. But no... leave it to me to protect everybody else's car... sigh.
  12. barbaram
    912
    70
    Trenton, NJ
    That was the BEST feature of my Saturn LS- the plastic side body! Car looked new when 5 yrs old!Can't figure why it never caught on with any other makers.......
