Its the tranny part 2: $4211
Discussion in 'Gen 2 Prius Main Forum' started by exstudent, Jan 29, 2011.
  1. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    38
    Santa Fe, NM
    Shamrock, how many miles did you have on your 2010? Had you ever changed the fluid?
  2. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Original Poster here. Once again, THANKS for everyones feedback! I've gotten some persepctives I wouldn't have thought of.
    I plan on changing the transmission fluid this week. This will be a first time change at 99,100 miles w/ the original factory fill. I'll take pictures of the fluid, drain and fill plugs, and send the fluid off for testing. What type of container should I use for testing (plastic, glass) and how much fluid will be needed?
    I plan to get a second opinion of the noise coming from the transmission, as diagnosed by a Toyota dealership, AFTER I change the transmission fluid. Should I go to another Toyota dealership or an independent repair shop that specializes in Toyotas for this second diagnosis?
    Other folks may find this info helpful for future part pricing search. Doing two google searches "prius used transmission," "toyota prius parts," I got these results:
    engineandtransmissionworld.com=$595 for a used 2007 transmission, 26,718 miles from CarFax report, 90 day standard warranty, but it appears you can buy a 2 year part/labor nation wide warranty, shipping to a business included (residences/Alaska/Hawaii is an additional fee).
    autoguide.net or autopartsfair.com=Varoius pricing and you must call. This site appears to be a broker; they know who has the part and will be able to get the part for you. You just have to pick what part you want coming out of what salvage yard.
    trademotion=$2,603 for a new transmission. Shipping/tax unknown.
    camelbacktoyota=$2917 for a new transmission. Shipping/tax unknown.
    toyotapartszone=$3174 for a new transmission. Shipping/tax unknown.
    Seeing a 2007 transmission for $600 w/ a CarFax report made me happy. Is there anything I should be weary of? Would a CarFax report indicate that the vehicle was salvaged from a lake? One would probably not want to buy such a transmission. Engineandtransmissionworld says they clean and test the parts before shipping it out, and provide the customer with the CarFax report.
  3. Optimus
    Optimus Member
    274
    25
    Also try the website Car-Part.com--Used Auto Parts Market. It's an online database where salvage yards post their inventory. It's been around for years and is nation-wide. You can narrow your search based on location as well, if you want. Some of these places even show pictures of the exact vehicle they are parting out.
  4. jdenenberg
    jdenenberg EE Professor
    3,957
    1,955
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I'm the individual that started the suggestion of a first refresh of Prius 2004+ ATF at 30k miles and 60k miles thereafter. This was after getting my third lab analysis of Toyota Type WS ATF at 180k miles (every 60k miles). The ATF at 61k miles was loaded with metallic content and was overdue for replacement. At 120k miles the ATF looked much better and was even cleaner at 180k miles. I have attached the lab report here for the convenience of this discussion thread. There are four columns:
    1. The analysis at 180k miles - Still better and maybe my Prius can go farther than 60k from now on, but it's only $100 to do the refresh at my dealer - low cost insurance.
    2. The analysis at 120k miles - Much lower metallic content
    3. The analysis at 61k miles - Note the high FE, Al and CU levels. The high silicon levels may be due to leaching of the sealants used in manufacture and is ignorable.
    4. Analysis of Virgin Toyota Type WS ATF - very clean.
    JeffD
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Either plastic or glass is fine as long as the container is clean. 100 ml of fluid should be plenty. Try not to collect the initial gush or the final drops - try to collect somewhere in the middle. Run the car a little bit to stir up the fluid before draining. Make sure you are able to open the fill plug before opening the drain. Call R&G Lab and ask for standard oil test plus viscosity index. Mention Bob Wilson and PriusChat to get a small discount. Post the result in this thread:
    http://priuschat.com/forums/gen-ii-...bleshooting/38524-transaxle-oil-analysis.html
    Good luck! :)
  6. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    Is the AT replacement a good DIY project, or do you folks recommend a dealer / Toyota Specialist shop handle it?
  7. jk450
    jk450 New Member
    55
    His information is often wrong, and he tries to sell parts to folks before they know whether or not the part is faulty. If, however, one is not knowledgeable enough to recognize when freidawg's advice is incorrect, then I could understand how that person might be fooled into thinking otherwise.
  8. jk450
    jk450 New Member
    55
    If the transmission is producing noise, it is highly unlikely that a fluid change will fix it. But there's no harm in trying. It's a cheap experiment.
    Most dealerships aren't interested in installing a used transaxle. I'd find an independent shop with Prius experience. Isolating the noise to the transmission is generally a simple task. Transaxle replacement is also fairly straightforward.
    By the way, the spider gears rarely fail in the Gen II transaxle. Your vehicle probably has a planetary gear and/or chain issue. The root cause is a bit moot, however, as long as the issue in in the transaxle.
    $600 is a decent price. CarFax reports are not always accurate. However, most used transaxles in your area will be from crashed cars. Make sure the junkyard will take back the transaxle if it is defective.
    Many junkyards claim to test parts, but in this case, the "test" part of "clean and test" is BS. Perhaps they are testing something that they think is of value. However, you can't fully test this transaxle after it has been removed from the vehicle unless you know it very well, have the correct testing equipment, and completely disassemble it. That would cost more in labor time that the transaxle is worth.
  9. dinger_greg
    dinger_greg New Member
    86
    Brookfield, WI
    Transaxle fluid change is a easy DIY job. Almost as easy as changing the oil.:)
  10. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Why on earth would you have to replace the transmission on a 2010? And why wouldn't it be covered by the warranty?
    But again, the logic doesn't work. How would Toyota save money by using a lifetime fluid? The fluid itself costs more when installed at the factory, and you cut down on revenue for the dealers because they do less transmission drain and fills.
    Then you have the added potential for failures within the warranty period, within any extended warranty period, and within any certified pre-owned warranty period for the second owner.
    All of this in the hopes that people would trade in their broken down cars...that they would have to repair in order to resell, and buy new Toyotas. Which...with the sour taste of a Toyota transmission failure at 100k miles they would be less likely to do.
    So whatever questionable profit might be made from that would have to be weighed against the potential loss of sales due to an eroded reputation within the buying population.
    Theres just not a way to put that into a sound business argument...and Toyota has always demonstrated that they make sound business decisions overall.
  11. Patrick Wong
    18,210
    6,514
    I assume that shamrock1 bought a totalled 2010 vehicle and is repairing it.
  12. exstudent
    2,214
    905
    Torrance, CA
    Thanks all. The additional feedback is great.
    Looks like caveat emptor, even w/ a Car Fax report. The engineandtransmissionworld site, where I am thinking of buying the $595 transmission, with the supposed 26,718 CarFax miles, has a two year, nationwide, parts and labor, extended warranty for $395. I just emailed them with a request for the details; interested in the fine print. Do you folks think the extended warranty would be worthwhile to get, assuming the insurer is legitimate and doesn't go bankrupt in the next 2-3 years?
    Just calling around, I found a shop that would do the install for $900. Don't know how good/bad this shop is, but its a reference point. Still trying to find a place that specializes in Toyotas, though.
    Looks like I may just be set back $1495 or $1890 w/ a used transmission, vs $4211 w/ a NEW transmission from the cheapest Toyota dealer.
    Happier. But sucks the transmission died prematurely, IMO. Some of the high mileage club members indicated that they haven't changed their fluid with any great frequency either. Lucky them.
  13. Patrick Wong
    18,210
    6,514
    Well, it looks like you are on track to spend $1,500 on the repair, if you didn't buy the extended warranty. The $395 warranty would be useful if you think that the probability of replacement unit failure within 2 years to be > 26.3%.
    I think that the probability of failure is much lower than that. If the transaxle has no accident damage and works upon installation, then it should be good for a reasonable length of time.
  14. shamrock1
    shamrock1 Junior Member
    Bellingham, Washington
    Patrick Wong is right, this is transaxle was damaged in a accident with only 1200 miles on the car and the car was totalled, after replacing the transaxle the car ran same as before, now its running as a Taxi in Canada. Unless you are in a accident these transaxles should last long long time. I know with gen II the taxis do 350000 to 400000 km which is about 250000 miles
  15. ualdriver
    ualdriver Member
    358
    65
    Midwest US
    This automatic transmission fluid change that is suggested at 30K......what is it that I should be asking for? Is it a AT fluid flush? Drain and replace? I thought there was some sort of fluid change where bad mechanics try to flush but you're not supposed to flush or.....?
    Also, how much does this procedure cost? Should I take it to a Toyota dealer or a local shop?
    Thanks!
  16. Optimus
    Optimus Member
    274
    25
    If you haven't checked car-part.com yet, there are 25 pages of transmissions with prices, starting at the $200 mark. There are several more pages of places selling transmissions without a price listed too. You might be able to find something local, or closer, and be able to avoid shipping costs.
  17. 2009Prius
    2,705
    512
    63
    Just drain and fill with Toyota ATF WS. You will need 4 quarts and two replacement aluminum washers for the drain and fill plugs.
    Tightening torque of the drain/fill plugs is 29 ft.-lb.
    Tools for opening the plugs: 24 mm (or 15/16") socket and 10 mm hex key.
    If DIY make sure you are able to open the fill plug before draining. A piece of flexible hose attached to a funnel will help the fill process.
    Either dealer or independent shop can do this very simple drain and fill work. You may want to call around to find out pricing. Some people have gotten very good price from dealers.
    Also see here:
    http://priuschat.com/forums/gen-ii-...bleshooting/44124-changing-transaxle-oil.html
    Good luck! :)
  18. PriusTech
    PriusTech Active Member
    263
    120
    Reno
    Drain and fill only. This is not a typical automatic transmission. It never needs a flush because all the fluid is drained on a drain and fill. Anyone that tries to sell you a flush is just a rip-off.
    It's not that hard DIY. You can have it done at an independent. Make SURE they use the Toyota brand WS fluid, there is no substitute. Best off supply it yourself.
  19. exstudent
    2,214
    905
    Torrance, CA
    GREAT NEWS!
    The Service Advisor was somehow able to get the transmission covered under the longer California emissions warranty (15 year/150,000 miles). The warranty book for my Prius, does not mention the transmission/transaxle under the Federal or California descriptions, either. I'm guessing the Service advisor made a strong case to Toyota that the transmission would be failing imminently, resulting in the Red Triangle of Death and some warning codes (excessive polution perhaps), all due to the transmission. Or, maybe this Service Advisor knew the right people to make things happen.
    I'm very happy with the outcome, as it saved me at least $1500 (used transmission) or $4200 (new transmission).
    I also wrote a letter praising the service advisor and condemming Toyota's NO Customer Experience Center for not covering the transmission udner the Emissions Warranty, as I had initially requested.
    Now I just need to send the sample of the original transmission fluid off for testing. This fluid doesn't smell burnt. It smells like normal ATF, just a little darker purplish in color.
    I have pictures of the fluid in a plastic water bottle and drops on a white paper towel. Is this something that would be useful to see?
    Thanks for everyone's input!
  20. Patrick Wong
    18,210
    6,514
    Amazing, I would not have thought that was a likely outcome. Good for you!
    When the original fluid was drained, did you find metal particles in the fluid? What did the drain plug look like before it was cleaned? If you have a photo of that, it would be interesting to see. Pictures of the dark used fluid itself won't be particularly helpful.
    If the shop plans to disassemble the transaxle to locate the failed parts, and you can get photos, that would be very interesting to post.
