It's time! 100k proactive maintenance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bgustafson, Apr 8, 2018.
  1. Bgustafson
    Bgustafson Active Member
    259
    222
    Chicago
  2. Mendel Leisk
    42,355
    Maybe local automotive store sells by the foot?
  3. Bgustafson
    259
    222
    Chicago
    Right. How much do I need? I’m planning to mount on driver’s side in an easily accessible area for now.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    When I mounted our catch can to the front cross member, I only used 2 feet of hose:).
    So not much;).
    Good luck with your install(y).
  5. Mendel Leisk
    42,355
    At around $1.50 a foot, doesn't hurt to get a bit too much. Run some other tube or whatever along the same route. To get a rough idea.
    Raytheeagle likes this.
  6. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Or some bailing twine :whistle:.
    Bay Stater and Mendel Leisk like this.
  7. Bgustafson
    259
    222
    Chicago
    I like how you think! (y)
    Also, I forgot to ask this earlier, what order should I complete all these tasks in?
    I'm planning on doing: (in no particular order)
    Spark plugs
    OCC
    Intake manifold / throttle body cleaning
    PCV valve
    EGR cleaning
    Transaxle flush
    Bay Stater and Raytheeagle like this.
  8. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    The order I would do knowing you are over 100 k miles (adding a job;)):
    • Egr cleaning
    • Intake manifold cleaning
    • PCV valve replacement
    • oCC install (go low:))
    • Engine coolant drain and fill (if not done or no records of it being performed)
    • Spark plugs
    The transaxle drain and fill can be done separately at a different time ;).
    Keep us posted (y).
    #28 Raytheeagle, Apr 23, 2018
    Bay Stater, SFO, orenji and 2 others like this.
  9. Mendel Leisk
    42,355
    Editorial: add OCC install, after PCV valve replacement?
  10. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Edited;).
    Missed the OCC:whistle:.
    Probably not the only thing I missed today:eek::oops::sick::rolleyes:.
  11. Mendel Leisk
    42,355
  12. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Tough day sluggin it out for you:whistle:?
    13 hours was my limit for paradise today:cool:.
    Have to save some for tomorrow (y).
    #32 Raytheeagle, Apr 23, 2018
  13. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    Bay Stater likes this.
  14. farmecologist
    1,960
    1,801
    Southern MN
    Might wanna do the EGR/plugs at the same time ( because cowling is off )...and manifold/PCV at the same time ( because manifold is off ).
    That is my 'plan' anyways! :D
    Edit : Edited for clarity
    #34 farmecologist, Apr 24, 2018
  15. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    I took a suggestion from @Mendel Leisk: when doing the EGR cooler cleaning, it's easiest to just drain some coolant from the radiator to minimize coolant loss when removing the EGR cooler. Since I was due for a coolant change anyway, I went ahead and just did a full drain of the cooling system. Then cleaned the EGR system and replaced plugs.
  16. Bgustafson
    259
    222
    Chicago
    Is this the correct coolant to purchase?
    1 Gallon Toyota-Lexus-Scion Super Long Life Pink Antifreeze Coolant - OEM NEW! 719279493849 | eBay
    Also - how much transmission fluid do I need to purchase?
    #36 Bgustafson, Apr 24, 2018
  17. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
  18. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    I have my OCC installed at the same location behind the left headlight. I used about 4 ft for each hose.
    audiodave likes this.
  19. Bgustafson
    259
    222
    Chicago
    That's what I was planning to do - but a lot of people here have mentioned it needs to be low?
    No mount required?
  20. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    If mounting it low to the front cross member, you can fab a bracket, or use whatcha got;).
    I had a soup can layin around so I zip tied it to the front cross member, put some foam around the lip, then dropped the oil catch can in:).
    Been running good with this setup for over 8 k miles and no issues(y).
    Bay Stater and Grit like this.
