It's time! 100k proactive maintenance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bgustafson, Apr 8, 2018.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    What I like about brake Kleen is that if you suspect a plugged channel, you can direct a concentrated spray into that opening;).
    But I use both(y).
    Bay Stater and Mendel Leisk like this.
  2. Bgustafson
    Bgustafson Active Member
    259
    222
    Chicago
    It’s soaking on Oxiclean now! Looking good. Lots of bubbling.
    Also - should I replace this ignition coil due to the cracked boot? Is it fine?
  3. Mendel Leisk
    42,355
    I see coils for $70.60 (US) online, plus shipping. I'd be inclined to just put it back in.
    m.wynn likes this.
  4. Bgustafson
    259
    222
    Chicago
    Yeah, they’re pricey for sure. But I would hate to have to take the wiper assembly off again... what a pain.
  5. Mendel Leisk
    42,355
    It gets easier...
    Maybe put the coils in as-is and test drive without the cowl and wipers, see how it behaves. I think that's doable? (n)
    Bay Stater and Raytheeagle like this.
  6. Mendel Leisk
    42,355
    Trailer park, but you could wrap some electrical tape around it. Or a large diameter shrink tube?
  7. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Time vs. money;).
    Is that how the boot came out, or did you damage it:whistle:?
    If that is “as found”, I’d throw it back in:).
    The windshield wiper cowling is a 1/2 hour job, so it all depends what your time is worth;).
    Keep us posted (y).
    Bay Stater, m.wynn and Mendel Leisk like this.
  8. fmerkel
    fmerkel Member
    88
    46
    Seattle, WA
    Shrink wrap or electrical tape and use it. Mostly cosmetic.
    Bgustafson likes this.
  9. Bgustafson
    259
    222
    Chicago
    Do I have to answer that question? :whistle: ................
    EGR is back in and hooked up! Took four rounds of Oxi. Kept getting brown water and more particles coming out. I alternated plugging each end and then soaking. A also learned giving it some good bangs in the sink really loosens up a lot!! I cleaned it until nothing but clear water would come out both ends no matter how hard I tried.
    Onto manifold cleaning!
    Just checked the throttle body, and oh my..... there is a ton of oil under there.
    F257486E-7B11-4672-9B39-76A2776A3ED8.jpeg 6F314F4B-2897-499E-9D48-26AA8B223050.jpeg 8F03DE0C-ADA1-4551-9F3E-F0E23DC6A328.jpeg
    #89 Bgustafson, May 6, 2018
    icyrius, Bay Stater, m.wynn and 4 others like this.
  10. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Bull in a china shop, eh:)?
    Good to hear things are progressing well;).
    There’s always a nice size spooge pool under the throttle body :(.
    But you know how to deal with that(y).
    Bay Stater, m.wynn and Bgustafson like this.
  11. Bgustafson
    259
    222
    Chicago
    Intake manifold is out! Easy.
    LOL found a little surprise! Wonder how long that’s been there?? Since day one?? Which Toyota assembly line guy took the smoke break? :ROFLMAO::ROFLMAO:
    #91 Bgustafson, May 6, 2018
  12. Bgustafson
    259
    222
    Chicago
    It was a good day. PCV valve installed. Manifold clean and ready for reinstall....but first the OCC! :)
    .... still not sure where to place it. Need more votes! I want easy access.(y)
    Bay Stater and Michael Mann like this.
  13. Michael Mann
    Michael Mann Active Member
    167
    408
    Bay Area, CA
    Thanks for the motivation! I’ll be following in your footsteps shortly. I just have one question did you replace gaskets while doing the cleaning process or reuse the original ones?
  14. Bgustafson
    259
    222
    Chicago
    Good question. I’m replacing the intake manifold gasket, but reusing the smaller EGR pipe gasket. The gasket looked ok when I removed it, but figured it’s best to just replace it while I’m there.(y)
  15. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    If you need any assistance or want to use my spare cooler, let me know ;).
    Cleaning it currently (y).
    Bay Stater, m.wynn and Michael Mann like this.
  16. Mendel Leisk
    42,355
    I reused all gaskets, but we're pretty low mileage. They did look fine.
  17. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    First round at about 120 k miles I replaced all gaskets;).
    Round 2 at 175 k miles I reused:whistle:.
    All gaskets are $35 online, so not expensive :).
    But reusing seemed low risk too(y).
  18. Bgustafson
    259
    222
    Chicago
    Going to pick up some brass barbs at the hardware store now.
    I'm a little worried about mounting it under the air intake because in the very cold winters we have here, plastic is very prone to snapping easily. Also, I'll be less motivated to go out in the cold to check it (when it probably needs to be drained the most)...
  19. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    That is my thought too...and winter seems to be the time one would want to check it the most! :D
    Bay Stater likes this.
  20. Bgustafson
    259
    222
    Chicago
    I've been hemming and hawing for the past two hours. I could've had it installed by now! I just need to decide. I'm leaning towards just putting up top because it's easier to check and that's the setup @danlatu is running right now and he's the man.(y)
    I'm sure mounting lower is probably slightly better in the long run, but I'm thinking it's probably fine for now, at least.
