It's time! 100k proactive maintenance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bgustafson, Apr 8, 2018.
  1. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    Imagine how much money you just saved on labor cost lol then you’ll want to redo it the second time ;)
  2. Bgustafson
    Bgustafson Active Member
    259
    222
    Chicago
    Oh Mendel, I love you. Your replies are always so detailed....but we don't all have time to soak the clips like you. :whistle: :). I wish I was retired!
    Not to mention they would've just sprayed some brake cleaner in that EGR and called it good. :eek:
  3. Bgustafson
    259
    222
    Chicago
    Drove about 100 miles today, mostly highway. Wasn't expecting to see a difference, nor even looking for it.... but I am, without a doubt, getting about 5mpg improvement on the highway. Was usually 48, now averaging 52-53mpg. Around town has seen an improvement as well.
    Secondly, I opened up the catch can today and there's already about a teaspoon of oil in there! (y)
  4. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Congratulations! You should be all set for another 120K miles or so.:)
    Not to mention money saved for DIY and avoid potential ICE problems. :)
    Is that your lift? Cool. :cool:
    Raytheeagle likes this.
  5. Bay Stater
    534
    771
    Central Mass
    That is a job I need to do. Never done brakes maintenance before. :unsure:
  6. NutzAboutBolts
    1,756
    1,789
    Bay Area
    Time to start ;) we’ll be there for you! through YouTube... :ROFLMAO::ROFLMAO::ROFLMAO:
  7. Bay Stater
    534
    771
    Central Mass
    Thanks NutzaboutBolts!;)
    Bgustafson and NutzAboutBolts like this.
  8. Bgustafson
    259
    222
    Chicago
    Oye. The thought of doing more work right now is not very appealing, but a brake job can't be too complex I would hope.:rolleyes:
  9. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    They’re not hard if you follow the videos ;).
    Get it all done (y).
    Bay Stater and NutzAboutBolts like this.
  10. Mendel Leisk
    42,355
    Just to cluck: you guys change your oil like clockwork, but the recommended US brake inspection interval, 30K or 36 months (whichever comes first): not so much... :(
    That is not the regular "visual inspection", check your booklet.
  11. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    A quick note regarding brake work: Mind your grease!
    I did the rear brakes on my '13 V last fall. Changed the pads & rotors, and disassembled/cleaned/lubed the slide pins.
    I used the same brake lube I've used on every car I've owned in the last 20 years -- on European, American, and Japanese vehicles.[​IMG]
    When I inspected them this last weekend, the pins were bound up. I had to resort to grabbing the ends with pliers and prying on the pliers with a pry-bar in order to get the pins out. When I inspected the pins and the bores -- everything looked to be in great shape. I cleaned them up, regreased and began reassembly. But the pins would not go back into the bore!
    The rubber seals near the tips of the pins had swollen just enough that they had earlier been causing the pins to bind, and now would not allow the pins to go back in the bores.
    I ordered a seal kit, and will finish the job this weekend.
    My advice: use only silicone grease on the slide pins.
    Edit: to be clear, the above linked Permatex grease is an excellent product, and I will continue to use it for brakes (pad backings and other points of contact) and other applications. It just appears to not be compatable with the Toyota seals in the brake slide pins.
    Bay Stater likes this.
  12. Mendel Leisk
    42,355
    The seal kit includes the rubber rings on caliper pins? Can you post numbers?
    That's alarming. The rubber rings on the pins (is it the rears just, fuzzy memory) are the first I've encountered. Toyota's Repair Manual instruction for brakes uses a very generic description for pin lube, and no special warning, that there's a proprietory lube, say similar to the transaxle fluid warning.
    FWIW, Sil-Glyde Brake Lubricant has worked for me, has been on there for about 5 years and 50K kms, but now I'm wondering. Some of my notes:
    Toyota Repair Manual description caliper pin grease:
    "lithium soap base glycol (rubber) grease"
    And this is maybe the kosher stuff, forget from where I got the info, maybe @ChapmanF :
    Toyota Disk Brake Grease III, tube 100 gm, p/n 08887-02706
    When I google the above, the closest I find on Amazon is this:
    Description of the above:
    Genuine Toyota (08887-80609) Brake Caliper Grease
    (if above link not working, try temporarily switching off ad-blocker)
    ($38 (US), for a wee tube?!)
    (Hah: only $79 (CDN) on Amazon.ca.)
    with another part number, maybe updated? There's also mention of a few other products, in the "customers who bought this also bought" section, including "3M 08943 Clear Silicone Paste", which might be the stuff @NutzAboutBolts in his video, mentioned below.
    I watched @NutzAboutBolts video on the rear brake pin lube again, see he just says "clear silicone paste". Maybe he can comment, what brand.
    #132 Mendel Leisk, May 10, 2018
  13. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    I got them at Rock Auto. Caliper Slide Pin Boot Kit
    Rear: CARLSON 16204
    Front: CARLSON 16153
    Search those numbers and they are available at a number of suppliers online.
    Bay Stater and Mendel Leisk like this.
  14. Mendel Leisk
    42,355
    Thanks for the numbers, see them on EBay, and salted away.
    The Permatex Lube you pictured above says something about metal-to-metal contact only, which might be a euphimism for not compatible for some rubber?? I see there's also this:
    And it says "Compatible with most plastics and rubbers used in Disc Brake Caliper systems".
  15. Mendel Leisk
    42,355
    This seems very topical. He's saying some brake pin lubes are good, but swell rubber, while others (including Sil-Glyde) are ok. Mentions Carlson rebuild kits too.
  16. hotelprisoner
    hotelprisoner Member
    104
    87
    Ontario, Canada
    Technology
    I’ve used this for a while. Need to get the previous gunk out of the shafts first.
  17. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
  18. NutzAboutBolts
    1,756
    1,789
    Bay Area
    Yeah the sliding pin rubber end swelled up on my 2001 Honda Accord as well. Not sure who serviced it last or what silicone greased was use, it was the first time I’ve encountered that issue, luckily Winchester auto had a kit so I could change it the same day. Make sure to use the proper silicone grease or else that can happen.
  19. Mendel Leisk
    42,355
    Well a couple of data points, mine and that video, indicate the Sil-Glyde Brake Lubricant is ok, ie: suitable for caliper pins, and doesn't swell rubber. Back of the tube also recommends for rubber parts. Obviously there are others, but it's one pick that's readily available in North America, and pretty cheap.
  20. Bgustafson
    259
    222
    Chicago
    Sounds scientific. (y)
