I've got Questions!
Discussion in 'Newbie Forum' started by 70AARCUDA, Mar 9, 2014.
  1. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    1) What is the typical battery-pack life?
    2) Is battery life driven more by usage (miles), temperature (hot/cold), or what?
    3) How leather-like is that faux-leather "Softex™," which is really just expanded polyurethane plastic (and they want an UP-CHARGE for it?)
    4) What brand are the OEM P195/65R15 tires and are they LRR?
    5) How accurate are the dash gauge MPG readings?
    6) How accurate are the dash gauge BATTERY readings (%-left, range, etc.)?
    7) How safe is their Smart Key System: "...may interfere with some pacemakers or cardiac defibrillators"? (I have one)
    8) How well do the 'heated front seats work? What effect on battery life?
    9) How visible/useful is the Heads-Up Display (HUD)...especially in sunlight?
    10) How many problems with the Multi-Information Display (MID) unit (screen & electronics)...touch screen?
    11) How effective is that battery-powered AC in hot summertime & at stoplights?
    12) Will my ScanGaugeII™ also work on these Prius's (Prii)?
    13) What, roughly, is the current replacement BATTERY(NiMH) cost: (a) OEM Toyota, (b) refurbished, (c) after-market?
    14) Does Toyota "limit/shorten" their battery warranty in HOT weather states, such as AZ, TX, NM, etc.?
    Addendum: Forgot to mention my location: Tucson, Arid-(hotter than the hubs-of-Hades)-zona.
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    1. Figure 8 - 12 years, 150 - 300k miles
    2. Mountains and severe heat will put your battery on the lower end of expected longevity
    5. 5% optimistic
    6. Ignore
    7. Safe
    8. As well as others ? No effect on battery life
    10. Few to none
    11. Quite
  3. 70AARCUDA
    845
    209
    Tucson, AZ
    Thanks. Oops, forgot a VERY important question:
  4. SageBrush
    11,627
    2,533
    Southwest Colorado
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    3. Feels like pleather to me.
    4. Toyota seems to use three brands of LRR tires Yokohama, Goodyear and most recently and most likely what you will find today is Bridgestone Ecopia.
    12. Yes.
    iPhone ?
  6. 70AARCUDA
    845
    209
    Tucson, AZ
    Oops, just thought of another one:
  7. SageBrush
    11,627
    2,533
    Southwest Colorado
    13. a) $3000 b)$1800
  8. 70AARCUDA
    845
    209
    Tucson, AZ
    Hm-m-m, sounds better than I thought.
    Years ago, a Honda Civic battery was ~$8K, meaning the cost has roughly halved over the years.
  9. joeman
    joeman Member
    239
    Raleigh, N.C.
    Side note: Are the hybrid batteries supplied to Toyota and the ones to Honda, do they fall from the same tree .
    Thinking not?
  10. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Heated seat at high uses about 50w, about headlight bulb.
    Electric AC can do full blast when engine is not running since the coldness has nothing to do with the rpm of the engine.
  11. joeman
    joeman Member
    239
    Raleigh, N.C.
    Looks like the heavy hitters went home.
  12. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Different suppliers. Panasonic (PEVE) supplies Prius. Sanyo supplies Honda.
    Hybrid tech differs in how battery pack was babied. HSD has two motor/generators but IMA had one. HSD is less restrictive to charge the battery.
  13. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Very different. According to the current Consumers Reports, Honda batteries are failing at a far higher rate than those used in the Prius:
    Honda Civic Hybrid — Shocking Battery Failure Rates | PriusChat
    "In the latest 2013 Annual Auto Survey by Consumer Reports, the battery replacement rate for 2009 Honda Civic Hybrid are at 30% and the 2010 model at 32%. In contrast, the battery replacement rate for Toyota Prius are at less than 0.3% for the 2009 model and 0.1% for the 2010 model."
  14. joeman
    joeman Member
    239
    Raleigh, N.C.
    Good to know , understand Consumer Reports give the Prius Battery more longevity than the Honda Battery.
    (Whoops , looks like we posted at same time) great minds
    ftl likes this.
  15. 70AARCUDA
    845
    209
    Tucson, AZ
    Thanks, so roughly 1/15th of a hp...of course, there's the how long ON question.
    But, what's the "load" on the battery (Watts) during those times...or, is it basically irrevelent because 'IF' the computer(s) detect that the battery is approaching "too low voltage" it simply restarts the engine?
  16. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Yeah, Honda batteries are outfailing Prius at a rate of a hundred to one or worse :eek:
  17. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    If I recall, the electric AC can draw 1-2 kW. Battery pack is rated 28kW (including propulsion). Yes, engine will come on if the pack state of charge approaches 40% (min). Max it allows is 80%. That narrow range is used to prolong battery life.
  18. joeman
    joeman Member
    239
    Raleigh, N.C.
    Just bought my 06 with 144k recently, previous owner replace original battery at128k.
    I know there is all sorts of reasons the battery can fail. But seems like if most of the miles were put on the car from NC to Fla and back on flat roads, battery might have lasted longer. Maybe one reason was the southern heat, especially Fla. Yea, I know there are many other reasons.
    This part of state where car originated is slight rolling hills.
  19. 70AARCUDA
    845
    209
    Tucson, AZ
    Now, those are some VERY reassuring numbers!
    Just thought of another question:
  20. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    so "fed up" with GM's lack of 'customer service response' ... that we're seriously considering dumping it and moving on to a...Toyota Prius...
    I can't guarantee that your local Toyota dealers are any better. How do they rate with the better business bureau?
    Reliably 200k. You might look at it in terms of how long the warranty is vs. how long you keep your cars.
    Temperature, in particular overheating. It doesn't seem to care about cold. Don't let the battery vents get blocked up. It doesn't like that.
    Accurate enough that I haven't really questioned them.
    Sorry, I just ignore those, so I don't know. I consider them useless visual clutter. I don't drive according to the battery, I drive according to my needs. I paid for a gas engine and I'm not afraid to use it.
    Talk to your cardiologist, not random strangers on the net. That being said, you can turn it off at the car. It is nice to have if your doctor approves though. He may be able to lend you a field strength meter so you can walk around and check.
    Good & I don't know. It's the equivalent of sitting and idling the car with your headlights on. Some of us disdain the wimpy stock battery and switch over to optimas.
    I can see it fine but don't seem to actually use it. It is actually too bright for my taste.
    So you'll mount a pair of longhorns on the front? :whistle: Given how different this is than your last car, I would suggest you look into renting one for a couple weeks, maybe a month or so, just to be sure you can be happy with something so different than what you're used to.
