I've got Questions!
Discussion in 'Newbie Forum' started by 70AARCUDA, Mar 9, 2014.
  1. tomtoy
    tomtoy Junior Member
    Iowa
    Hello! And welcome to the forum, gush a lot of questions, are there any that haven't been answered already?
  2. miscrms
    miscrms Plug Envious Member
    2,079
    527
    Phoenix, AZ
    Congrats! There is a wealth of accumulated knowledge here on PC, I would definitely read all you can and don't hesitate to ask questions!
    I thought this was stickied somewhere, but had to go digging to find it. The video in this thread provides some good tips on where to start for getting the most out of your Prius.
    Max MPG Driving Techniques Youtube Video | PriusChat
    Rob
  3. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    Thanks, that was a GREAT video...especially for the wife (I'm a hypermiler, she isn't). One question though, are those 2010 numbers/values still applicable to the 2014 models, ie: the mechanics haven't changed over the years?
  4. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Still the same as far as driving/hypermiling. Get in and go :)
  5. 70AARCUDA
    845
    209
    Tucson, AZ
    A little analysis of those video "numbers" (ie: 62 mpg @ 55 mph; 58 mpg @ 60 mph; 54 mpg @ 65 mph; 50 mpg @ 70 mph) yields this simple MPG vs. MPH relationship:
    MPG = 106 - 0.8×MPH
    ...although based upon only four data points, I suspect this equation is valid. What similar numbers have others gotten?
  6. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Updated MPG vs MPH chart | PriusChat
  7. 70AARCUDA
    845
    209
    Tucson, AZ
    Yep, that's the kind of 'graphed' MPG vs. MPH information I'm used to looking at (on Ecomodder Forum).
    Which brings up a question: at what engine speed (RPM) or vehicle speed (MPH) does the CVT "kick-in"? I've heard 37 mph and 41 mph mentioned, but don't know to which Gen-vehicle they apply?
  8. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    46 mph is when ICE must kick in for Gen3. 63 mph for PiP.
    As for eCVT, it is used all the time. Electric motor is the "low gear". Instead of multiplying torque with mechanical spin ratio, eCVT does it with electricity.
  9. 70AARCUDA
    845
    209
    Tucson, AZ
    46 MPH for ICE in regular Gen-III Prius, "Thanks!"
    Where is all this information published? Toyota 'Service Manual' or Chilton after-market book(s)?
  10. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Not sure it is published but if you have an OBDII adapter, you can see the engine rpm.
  11. 70AARCUDA
    845
    209
    Tucson, AZ
    Actually, I have two, a ScanGaugeII and a ScanGaugeE, but have not yet tried to install either one. What operating parameters for the Prius should be monitored first (for FE)?
