I've searched the forums to no avail, my 2013 Prius 2 is misfiring in all cylinders after replacing
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Allison Meggison, Jun 10, 2019.
  1. bisco
    51,968
    howdy :)
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Just looking at all the dirt on the valve cover - how much of that will end up in the engine? I would definitely have cleaned up that engine first.
    That Harbor Freight Earthquake impact has good reviews. I need one.
    The el-cheapo Harbor Freight torque adapter? I'll pass on that.
    #22 jb in NE, Jun 12, 2019
  3. Mendel Leisk
    41,485
    If you hire those guys, clean your engine beforehand!
  4. Allison Meggison
    Allison Meggison Junior Member
    71
    El cajon
  5. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    You will only serve to delay the inevitable with stop leak. Especially if the car is using a lot of coolant. I used Blue Devil in March of 2018, July 4th weekend my engine suffered a violent, sudden, catastrophic engine failure when the sealant stopped working.
  6. Allison Meggison
    71
    El cajon
    Omg really? what happened? Idk what to do i can't afford to fix it and have a loan on it... and nobody will buy it because its broken
  7. ASRDogman
    ASRDogman Senior Member
    7,599
    3,915
    You can learn to repair it yourself. Unless you have physical restraints...
  8. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    There are people who have used stop leak “successfully” and not had any issue. There are a few of us on the board that had issues with blown engine, clogged heater core, clogged radiator, and the like. I can’t say that yours will end up like mine, but the possibility is there.
    If you have the physical ability, and the automotive knowledge, take it apart and fix it yourself. If not, you likely know someone close by that can do the scope of work required. A friend, family member, etc. You may not be able to afford the $4-5k charged to swap the engine completely. But for $700-1000 you could get the head gasket done and be safe from the issues you have now.
    mjoo likes this.
  9. Leadfoot J. McCoalroller
    8,092
    7,574
    Pennsylvania
    2018 Prius c
    head gasket in a bottle is a last-chance OMG hail mary effort. A temporary fix at best.
    Sometimes it works, but it nearly always causes expensive complications. If I broke down in the middle of nowhere I would have no qualms about using it to get myself and my family back to civilization, but if the car was already in my driveway I wouldn't even think of using it.
    If you don't have the cash to fix it, you may need to trade it in on something else and start over on a bigger loan. It's a terrible situation and it won't do you any financial favors. I can't recommend it, but it is the most common solution to this kind of problem. I'm only pointing it out so that you have a reference point to compare with any other option that might come up. Good luck!
    kithmo and mikey_t like this.
  10. Allison Meggison
    71
    El cajon
    I wish I had $700-1000 to spend on having the gasket replaced and I have tried trading it in at Honda and they said I needed another $3k down plus the trade in so now I'm saving. I'm going to try a few other places. I'll probably just have to figure out how to put a new engine in myself or do the gasket replacement myself. Nobody I know will do it for less than a grand. I'll figure it out. Thanks for the feedback.
  11. xerox6135
    xerox6135 Member
    170
    94
    michigan
    If your losing coolant have a leak down test done . I am 99 percent sure you have a blown head gasket. More than likely if you have been driving it very long that way you have trashed the engine .
  12. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    If you have one, this is a justifiable use for a credit card.
    RMB likes this.
