Jack Points
Discussion in 'Gen 3 Prius Main Forum' started by Jim Calvert, Sep 28, 2009.
  1. Jim Calvert
    Jim Calvert New Member
    255
    28
    Worthington, Ohio
    The 2010 Owners Manual shows a vague sketch of the floor jack lift points on page 415. The sketch of the front lift point, for example, looks just like an engine oil drain plug.
    So does anyone have a more precise drawing or sketch of these floor jack lift points?
    By the way, nowhere in the owners manual is there any mention of the engine oil drain plug. Is there one? Also, there is no mention of the oil filter. Is there one?
    Thanks,
    Jim
  2. judyok
    judyok New Member
    that's a Uk plug !
  3. Jim Calvert
    255
    28
    Worthington, Ohio
    Sooooo helpful. :rolleyes:
  4. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    There is a frame member that crosses under the engine. That is the front jack point. Be careful you don't damage the undertray when using it. There is a frame extension just ahead of the spare tire well in the back that comes down quite a ways. That is the rear jack point.
    You can also use the side jack points, but I recommend some kind of "interface" device between the floor jack and those, such as a hard rubber block (hockey puck) or a plywood block with a slot cut in it for the weld seam.
  5. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
  6. Jim Calvert
    255
    28
    Worthington, Ohio
    Thank you, David and Tumbleweed. Most informative.
    Jim
