Jack stands or ramps better for oil changes and gen. maintenance?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rmi, Apr 1, 2012.
  1. rmi
    rmi Junior Member
    38
    Athens, GA
    I have two jackstands that I used to balance motorcycle wheels. Used them a couple times on different vehicles for oil changes.
    What would be the best/safest to use with the Prius? Is that the same for our Beetle too or is there something special about the Prius' chasis?
    Thanks in advance (getting ready to change the Beetle oil this week and preparing for first Prius oil change).
    Ryan
  2. Mike500
    Mike500 Senior Member
    2,593
    763
  3. rmi
    rmi Junior Member
    38
    Athens, GA
    Might be the best, but also might be out of my price range. Are ramps that much better than jack stands?
    Ryan
  4. sooperedd
    sooperedd Junior Member
    48
    Colorado
    I trust ramps more than stands, but moreover I don't trust anything when I'm under a car. I will use the jack, chock blocks, and extra jack stands when I'm under it, and I'm still leery.
    I just bought a 3 ton floor jack for the Prius that lifts 20" and I am going to use the new floor jack, chock blocks, extra jack stands and concrete blocks under the wheels once it's off the ground.
    I know a guy that got his skull cracked from a slipped jack. He has never been the same.
  5. Mike500
    2,593
    763
    Yes, they are the safest....much better than jack stands, unless you need the tires off. Years, ago, I got under the car with jack stands. I've seen others change oil or a starter under a bumper jack. I've heard too many cases, where others have been killed under a jacked up car. It does happen more often than you think. It would be even worse, if you were injured. Now, I will only get under a car under ramps.
    My life is worth a lot more than $137. What's yours worth? When it comes to safety equipment, I buy the best available.
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    I have a set of Rhino Ramps from Advanced Auto for a lot less. I do not know where the sliding comments come from. Mine have never slid on me. I slide my ramps right up to the tires and then pull up on the ramps. I have never had an issue.
    I use a hydraulic jack and jack stands if I am going to jack up the back of the car also, such as for changing transaxle fluid and you want the car level when refilling. I will keep the jack just below the jack point when using jack stands as a backup.
    For oil changes I think the ramps are much quicker than the jack and jack stands but either one should work with a little caution and safety.
    One guys carries a tool box thicker than him under the car with him. Not a bad idea.
    TsKarma likes this.
  7. Mike500
    2,593
    763
    I wonder who carries the liability insurance polict for Blitz USA? While they caim "business as usual," they have filed a Bankruptcy Petition for reorganization under Chapter 11.
    Blitz USA
    I remember how they made those leaky jerry cans for over 50 years under the U.S.M.C label.
    They let everyone thing that U.S.M.C. meant United States Marine Corps, when they really meant United States Metal Container.
  8. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    Warning: if you install lowering springs, the ramps become difficult to impossible to use. Your front bumper hits the ramp before the tires in that case. That's where I am with Rhino ramps.
    I imagine I can engineer a supplimental "pre-ramp" to make the lift more gradual.
  9. Mike500
    2,593
    763
    Not cheap, but special ramps are aviable for very low or lowered cars;
    http://www.amazon.com/dp/product/B003ZAGI9E?tag=priuschatcom-20 http://www.amazon.com/dp/product/B003ZAHTC4?tag=priuschatcom-20
  10. macmaster05
    macmaster05 Senor Member
    4,050
    728
    Jacks are fine if you follow the weight instructions, use wheel chocks, find the correct Jack points, and are careful all around. The guys with horror stories will probably disagree but most of the time people who advise against jacks or had bad experiences were lifting pick-up trucks or small SUVs with 2-1/4 ton stands.
    No matter what you use just be smart, go slow, and you'll be fine.
  11. rmi
    rmi Junior Member
    38
    Athens, GA
    I think about that every time I'm under the car. Ramps AND jackstands would make me feel a lot safer.
    Thanks- Ryan
  12. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Have you ever seen the seal give out in a hydraulic floor jack? You won't be able to tell if the whoosh sound is the fluid in the jack rushing past the seal, or the air leaving the collapsed lungs of the guy underneath the car. Never work underneath a car supported only by a floor jack.
    These ramps are nice, but you still have a problem if you rotate the tires. A car on 4 jack stands is reasonably safe and secure. Backup precautions can be added as well (blocks, old wheels, jacks, etc).
  13. macmaster05
    4,050
    728
    :suspicious: I was talking about jack stands and so was the OP. Not the lifts.
  14. Launch Vehicle
    Launch Vehicle Junior Member
    82
    Missouri
    Are Rhino Ramps tall enough to allow the oil access panel to fully open?
  15. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Good question!
    Posted from my iPhone via the Tapatalk app.
  16. macman408
    macman408 Electron Guidance Counselor
    1,179
    365
    I'm curious if I'm taking any risks when I do my maintenance; my most recent routine is to use a hydraulic jack to lift the front, lower it onto 2 jack stands, keep the hydraulic jack in the front as a backup, and start draining the oil. While it's draining, I move the hydraulic jack to the back and lift it up high enough to rotate the tires - but I absolutely go nowhere near underneath the car while the back end is off the ground. Once the tires are rotated, I put the jack back under the front lift point, chock the rear tires again, and finish the oil change.
    Any particular risks here that I should be aware of? I suppose it's always possible I could drop the car onto 3 wheels if the hydraulic jack fails, but a little body damage to the back isn't the end of the world.
  17. macmaster05
    4,050
    728
    There are no associated risks with that method as far as I can tell, but it seems you're putting unnecessary work on your hydro jack. You don't need to use a Jack as "backup" for stands. I would just buy another pair of stands for working on that rear. To me it seems like your only advantage to what you're doing now is saving time.
  18. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
  19. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Only issue with that method is that once the front of the vehicle is up on the jack stands it's no longer immobilized like it is with wheel chocks. If you're using a common garage type floor jack- when lifting the jack has to creep in towards towards the lift point due to the hinge/fulcrum design of the floor jack. If the wheels of the jack stick/drag- it could in theory pull the car rearwards towards the jack and off center on the jack stands causing a dangerous off balance condition.
    Although it's less convenient and more work- probably safer to change the oil, lower the car, then chock the front and rear of both tires on one side- lift the other side and do the tire rotation. Lather-rinse-repeat for the other side.
  20. ny_rob
    1,968
    813
    L.I.- NY
    I'll admit I've done tire rotations with just a floor jack and wheel chocks and - no jack stands. But, I'm 100% careful not to get any part of my body under any part of the vehicle.
    If for any reason I have to reach under/get under the vehicle it's floor jack, wheel chocks and jack stands all the way. I personally would never get under a vehicle without wheel chocks and jack stands. I wouldn't bet my life on a hydraulic floor jack.
