Jacking Up The Gen 5
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by VelvetFoot, Mar 10, 2026.
  1. Trollbait
    12,829
    Yes, there are ones that fit onto the cradle most jack stands have.
  2. Templeton
    Templeton Active Member
    371
    132
    usa
    2024 Prius Prime
    SE
    I got a set of these AL jack stands and I have looked high and low, but I cannot find any pads that fit these ...
  3. Mendel Leisk
    42,345
    The best way to find out is by having a 5th gen on hand. What I've used on m 3rd gen:
    Rear: Look for the oblong openings (roughly 1'x2", usually with rubber caps) on a exposed and heavy gauge "hump", just inboard of the rear scissor jack location. Those openings are for locator pins I think, and have extra, heavy gauge layers. I've been putting my jackstands longitudinally at the low point of those.
    Front: Look for longitudinal "beams" (roughly 1.5" square cross-section thickenings of the floor pan). I've been placing my jackstand cradles transversely at the frontmost end of those.
    Visual aid, but again, this is third gen:
    Bare jackstand cradles work well with these points, since they're wide, rounded. I did spray my jackstand cradles with multi-layers of plasti-dip, many years back, but they're pretty chewed up now.
    With 5th gen (sim to 4th and 2nd), the front jacking point is waaaay back, which is problematic. One workaround is to initially roll the front wheels up onto low-rise ramps, not only just so the jack can fit under there, but to provide enough clearance to operate the handle, get the lift started. If you're shopping floor jack, one that starts lifting with just a slight amount of up/down is crucial. Project Farm has a review (link starts at relevant point in video) that test this.
    I've got a venerable Samona 3 ton floor jack that thankfully works well. When doing our son's Mazda CX-5, low rise ramps for the front jacking point (way back, sim to 5th gen) really help.
    #23 Mendel Leisk, Apr 14, 2026
  4. Templeton
    371
    132
    usa
    2024 Prius Prime
    SE
    Thanks. Any idea with the car in your photo why that shop lifted the car by using the pinch weld spots in the rear and the front suspension in the front instead of the spots that you suggest?
  5. Mendel Leisk
    42,345
    No clue, don't care. :)
    The front points I garnered from a past member here, "Hobbit" IIRC. He recommended them for 2nd gen. I looked on our 3rd gen, saw similar structure, so used them.
    I've had the whole car on jackstands thus, twice yearly, for tire swaps, so over 30 times now, for that alone. The front end at least an additional 30 times for oil changes and various other services, and maybe another 10~15 times, front or rear, for rustprooofing forays, brakes, what have you..
  6. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    For what Generation Prius? Does it make a difference? Hockey puck pic.
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,575
    2,603
    Taylors, SC
    These are the ones that you need. My friend makes them out of ultra durable UHMW Spectra.
    He is currently sold out of 60 units but is in the process of making a new version.
    These can be fitted to these models of aluminum jack stands like the Big Red ones;
    Compatible ALUMINUM pin adjustable Torin Big Red Type jack stands
    TCE 3 ton aluminum
    Torin Big Red T43004
    Harbor Freight Daytona
    Sunex 1003AJ
    Power Zone 68066
    Schwaben 3 ton aluminum
    Jacko 3 ton aluminum
    NAPA Carlyle # NLE 7916455
    OTC SA02 2 ton aluminum (shown in the photos)
    Templeton likes this.
  8. Trollbait
    12,829
    I got universal ones that fir the typical pyramid jack stands. They are made of a block rubber similar to a puck, with a notch for the frame seam.
    They are for the Outback, back as long as the notch is deep enough to clear the seam, they'll work with any car.
  9. Templeton
    371
    132
    usa
    2024 Prius Prime
    SE
    Yes, those look perfect.
    When will they be available again? Where do l go to buy them? And the million dollar question: how much will they cost?
  10. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    I do believe it's supposed to be supported on the lip of the protruding metal on the Gen5, not on either side.
    See hockey puck picture.
  11. Hammersmith
    Hammersmith Senior Member
    2,486
    2,544
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    edit: I wrote a bunch of stuff, but this video shows it far better(plus I now know how to access the front jack point without using ramps - yay). Notice how beefy the jack stand positions are on the gen5. I see no need at all for adaptors.
    #31 Hammersmith, Apr 16, 2026
    VelvetFoot likes this.
  12. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    Now, that's a neat trick!
  13. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    I'd opine that any non-Gen5 info above may not be relevant.
