Jail Break iPhone?
Discussion in 'Fred's House of Pancakes' started by TonyPSchaefer, Aug 14, 2009.
  1. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    I considered Jailbreaking, but the only thing I want to do right now (tethering) can be done in a really simple, elegant way without actually carrying out the Jailbreak. As SageBrush points out, I actually rarely use the tethering feature because it's slow, but there have been a couple of times where there's been no WiFi and the tethering has come in really handy.
    I think I probably *will* Jailbreak when I travel to India in a couple months (so that I can use non-AT&T SIMs), but I think I'll probably restore it to "unbroken" when I return to the US. That's the nice thing about the Jailbreaking methods out there; it's pretty easy to go back once you've Jailbroken.
  2. hill
    8,898
    ah, to broaden one's horizons ... illustratively, I was simply saying that MY phone's battery is killed by tom tom. iphone is not the only phone that can be jacked up beyond it's intended use. sorry for the confusion.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    As an example, my AT&T Tilt (HTC Kaiser) is cut loose from AT&T. I dumped their crappy firmware and reflashed with some good open source firmware. Now the Kaiser works better and can run any application, not just the ones AT&T likes.
    Tom
  4. patsparks
    10,664
    567
    Adelaide South Australia
    What is "jail break" when refering to a phone?
  5. DarrenG
    DarrenG Member
    138
    Hampshire, UK
    JailBreak is the process or hacking an iPhone to allow the install of non-approved apps, utilities and other mods.
    Unlock is the process to allow use on other network SIM cards. To unlock you need to JailBreak first.
  6. DarrenG
    DarrenG Member
    138
    Hampshire, UK
    Ah I see. Not sure why you suggest Turn-by-turn navigation is "beyond it's intended use"? My 3GS isn't too bad on GPS and I can use Geocache apps and similar for a few hours on battery but for in-car use over prolonged period it is of course advisable to have external power. No different to most PND's.
  7. patsparks
    10,664
    567
    Thank you.
    I knew what unlocking is but never heard of "Jail break". Now I know.
  8. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I jailbroke my phone today. Went VERY smoothly with the blackra1n, literally under 2 minutes with 2 installs (required to accomplish the tethering). I've installed a number of aps from cydia an rock. Categories is great which allows you to organize your apps into files. the tethering was very smooth. setting a background was a nice touch. it gives you the ability to spoof the phone into thinking it's on a wifi even when on EDGE or 3G so you can use VoiP apps like Skype. SBSettings is a cool way to quickly access stuff in the General Settings area.
    And backgrounder is a must.
    Hopefully it will work well, but from all I've read, it is easy enough to restore to the original firmware if there are problems.
  9. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    When I played with it - broke it then restored it - I thought the pineapple was a nice touch:
  10. likes2fly
    likes2fly Junior Member
    17
    I've since installed a new iphone clip(proclip) which is rock solid. there are new tv out progams and gps programs out now.
  11. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    I jail break and use mine also unlocked love being able to get paid programs for free have naviagon, tom tom, and others all on my phone and love to themethem it:)
  12. efusco
    19,891
    1,196
    Nixa, MO
    Not sure I feel so good about using pirated programs/apps...and when I checked yesterday the site was down, or at least not working well...maybe just a server change, but a post on Wiki suggested they were taken down.
    But, what theme is that on your phone? I like it. I'm using iComplete which is pretty slick too.
      File size:
      223.5 KB
      1,082
      File size:
      253.9 KB
      923
  13. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
  14. efusco
    19,891
    1,196
    Nixa, MO
    so what theme is it?
  15. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    IMac Aurora
