January 2006 MPG Averages
Discussion in 'Gen 2 Prius Fuel Economy' started by Tideland Prius, Jan 6, 2006.
  1. Tideland Prius
    16,445
    Total Mileage: 21571.9km
    Tank Mileage: 425.8km
    MFD Avg: 5.0L/100km
    Calc'd Avg: 5.01L/100km
    Fuel Used: 21.335
    Cost of Tank: $18.01
    Price per litre: 84.4¢
    Avg Temps: 11°C
    Notes:
    This is the first time I stopped at the first click and that the calc'd average matched the MFD average exactly!
  2. BoBraxton
    BoBraxton New Member
    82
    Fairfax, VA
    Silver 2005 purchased end of March.
    In cold weather the mpg is around 38mpg up to about 41mpg
    Virginia, near Washington, D.C.
  3. maggieddd
    maggieddd Senior Member
    2,090
    Boston
    Silver, purchased mid July 2005
    Total milage 13,956
    New England
    Avg temp. 30°F
    49MPG
  4. driveprius
    driveprius New Member
    112
    Delaware
    Since starting to drive with my 2005 Prius in October. I'm now starting to see some of my best mileage. The weather has warmed up a bit, but my driving technique has definitely improved alot.
    Best tank mileage: 50 mph
    January tank mileage: 45.5 mph
    Tank miles: 414 miles
    Gallons consumed: 9.1 gallons. Unable to fill up past 9.1 gallons before pump shuts off.
    Temperature Range: 30 to 45 deg F
    Some commentary of what I've experienced in trying to learn how to drive better.
    1) When starting off from a cold engine, apply gentle acceleration. You're mileage will be displaying numbers below 20 mpg quite a bit, but don't panic and try to accelerate harder so that you can coast sooner.
    2) After about 5 minutes of warm up you can start trying to do some pulse-and-glide techniques. In the pulse phase it's recommended that you accelerate with no arrows going to or from the battery. This is known as "dead band" driving. However, I've found there are at least two distinct regions of acceleration where dead banding occurs. At really gentle acceleration there's dead banding. But at a more brisk acceleration it occurs again. I try to choose the more brisk region. Note that while you are in dead banding your mileage will generally be below 20 mpg. The biggest thing that I've learned is not to panic with this low mileage as I will get it back when I can start to coast.
    3) During the glide phase you're told to try and get no arrows to appear. However, in real life you might have a line of cars pushing you to go faster on the local roads. Ideally your supposed to pulse to 40 mph and coast to 30 mph. I have to pulse to about 55 mph and coast to 45 mph. Note that in coasting at this higher speed you may not be able to get no arrows to appear. In that case I have at times elected to cruise with a bit of electric. On level road, the battery seems to last quite a bit.
  5. priusblue
    priusblue New Member
    152
    My first tank!
    Total Mileage: 413 mi
    Tank Mileage: 408 mi
    MFD Avg: 51.9 mpg (reset accidentally at about 130 miles)
    Calc'd Avg: 51.1 mpg
    Fuel Used: 7.986 us gal
    Cost of Tank: $18.84
    Price per gal: $2.36
    Avg Temps: 46 °F
  6. Tideland Prius
    16,445
  7. kinghuang
    kinghuang Member
    119
    Calgary, AB, Canada
    Total Mileage: 19026km
    Tank Mileage: 787km
    MFD Avg: 4.6L/100km
    Fuel Used: 37.998
    Price per litre: 83.4¢
  8. Tideland Prius
    16,445
    omg, you're still getting 4.6L/100km in Calgary?
  9. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    First tank in Jan: 50.2 MPG
    I'm currently on my second tank (135 mi into it): 51.8 MPG. I hope that lasts!
    Oh, and my car's silver too! ~3200 mi.
  10. Ray Moore
    Ray Moore Active Member
    857
    52
    Texas Hill Country
    620 miles at 56.0 MPG
    currently 158 miles at 59.8 MPG
  11. kinghuang
    kinghuang Member
    119
    Calgary, AB, Canada
    It's been pretty warm over the past couple of weeks. Around 4°C or so. I averaged 4.9L/100km on the tank before that, which included a trip out to Banff.
  12. Tideland Prius
    16,445
    lol. We're sitting at 6-10°C and rain for the last 2 weeks and I'm at 5.0L/100km. 4.6 is what I get in the spring/autumn at 15°C!
  13. Tideland Prius
    16,445
    Total Mileage: 22175km
    Tank Mileage: 603.5km
    MFD Avg: 4.9L/100km
    Calc'd Avg: 5.18L/100km
    Fuel Used: 31.280
    Cost of Tank: $27.34
    Price per litre: 87.4¢
    Avg Temps: 9°C
  14. EricGo
    EricGo New Member
    1,805
    Albuquerque, NM (SouthWest US)
    Tank mileage: 528 miles
    Jan mileage: 1060 miles
    MFD Tank: 58.8 mpg
    Calc Tank: 56.5 mpg
    ------------ 4.16 Litres/100 km
    Calc Jan:-- 4.10 Litres/100 km
    Refill: 9.276 US Gallons
    Tank $: 20.86
    $/Gallon: 2.25
    Avg Temp: 20 - 50F
  15. Ray Moore
    857
    52
    Texas Hill Country
    Last tank for January-
    682 miles at 58.5 MPG.
    Calculated higher but I go with the MFD as it is more consistent.
  16. Ray Moore
    857
    52
    Texas Hill Country
    On a side note. The consumption in my 4200 sq ft house for January was 896 KWh and 10 gallons of propane. I'm equally proud of that. That's not to say we couldn't do better.
  17. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    My best January ever. ~1300 miles averaged 54.6mpg. Thanks mostly to this being the second warmest January in history in my area, but also to the use of my Engine Block Heater.
    Lifetime is up to 52.7mpg and if Feb. and March are anywhere close to my lifetime average I should be able to reach and/or surpass 53mpg for lifetime by this summer.
