January 2014 - Dashboard Report
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Feb 5, 2014.
  1. Trollbait
    12,829
    Outside of spikes in gas prices, a 4x4 truck tend to hold its value. Hummers might of become a collectors car also. The first one always was being based on a military vehicle with most of capabilities. The others might be now collectable with the company gone.
    52,855
    boy, that's all over the place.(n)
  3. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Increasing competition from conventionals ...
    mid-cycle refreshed 2014 Civic sedan EX now has CVT standard, gets 33 mpg combined, Smart Entry, push button start, rearview camera, touchscreen interface, moonroof, 16" alloys, has 143 HP and weighs 200 lbs less than Prius liftback ...
    and costs over $3k less than Prius Two. Takes 6 yrs to earn that back at $4 gas and 12k / yr.
    Increasing competition. :cool:
  4. bwilson4web
    16,535
    Good point!
    In October 2005, there was no real competition for the 2003 Prius. Even in May 2009, the new cars had not advanced. But now, we're starting to see new cars that s*ck less:
    • City/Hwy - model year
    • 28/36 - Echo 2005, sedan vs 2003 Prius, 52/45
    • 21/29 - Matrix 2010, hatchback vs 2010 Prius, 51/48
    We have to make purchase decisions at a given point in time and live with the consequences. Now four and nine years later, the market has changed and we have options not previously available. Small wonder that today's buyers might make a different choice. The boundaries of the decision point have changed.
    What this says to me is Toyota will have to 'up their game' with the Prius. There are 'low hanging fruit', which many of us have tested with our personal vehicles:
    1. Active cooling air management - we know from radiator blocking this reduces aerodynamic drag.
    2. High pressure tires with softer suspension - reduces rolling resistance so let the vehicle suspension absorb the bumps. Semi-trailer trucks run 70-100 psi tires. It also allows use of larger diameter, low-profile tires . . . the current style.
    3. Remote start - by letting the car start as we walk to the vehicle, we can shorten the initial 60-70 seconds needed to reach fuel-trim, more efficient warm-up.
    4. More aggressive, coolant warm-up - currently it stops around 40C, it could go to 55C without a problem.
    5. Include transaxle warm-up - put a loop in to speed up transmission warm-up from the exhaust heat loop.
    6. More aggressive, operation using traction battery during the warm-up - good, it extend after fuel-trim feedback start and further reduce rich-trim operation.
    7. Include transaxle oil change with first oil change - this gets the manufacturing debris out for more efficient operation later. Filtering is all that is needed to recycle the oil . . . or put an oil filter in the transaxle connected to an oversized drain plug.
    8. Serious 'overhead' power reduction - the car consumes ~1/2 HP just sitting there powering the electronics. Low power electronics could solve this problem . . . and use flash memory.
    9. Replace exterior mirrors with cameras displaying on the rear view mirror - improved safety and lower drag.
    10. Serious wheel well and tire cover drag reduction.
    11. Battery weight reduction - helps but we're starting to get in the shallow end of the pool.
    This is my short list.
    engerysaver likes this.
  5. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Competition for 2014 Corolla Eco Premium with Valvematic, 30/42, 35mpg combined, but not Prius!
  6. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
  7. Sergiospl
    3,938
    1,351
    28
    Was pointing out that low 30's combined of Honda Civic and other compacts do not compete with 50 mpg combined, but much closer to the 2014 Corolla Eco with 30/42/35mpg equally equipped.
  8. austingreen
    13,714
    4,232
    Austin, TX, USA
    Sure it is, but to grow hybrids need to reach into segments of non-hybrids. I consider the aqua/prius c more of a hybrid yaris than a smaller prius, but that model was more competitive in the compact segment. As people started thinking gasoline would be in the $3-$4 range last year those that want a compact form factor, if they can get 33 mpg epa versus 50 mpg in the prius would spend an extra $6200 over 10 years/150,000 miles in gas, but are likely to have less depreciation. If they like a compact better, that costs less upfront that gas savings isn't likely to sway them.
    The prius also competes in the midsize segment, and here the erosion is more to mid sized hybrids. Say the midsized hybrid doesn't get sticker, but around 40 mpg versus 50 mpg, at $4 gas over 150,000 miles/10 years only about $3000 more. If you like the better acceleration and comfort of the camry hybrid, fusion hybrid, accord hybrid these have now gotten much closer in gas mileage than before.
    Now with the prius gen IV redesign, they can probably get closer in terms of performance to the midsized hybrids which would create a reason to step up from a compact. If they further moved manufacturing to the US costs would get reduced allowing them more profits or a lower price and more sales. But more competition from higher mileage cars really is eating into prius liftback market.
    Trollbait likes this.
  9. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Short term, that's a reasonable assessment.
    Long term, more competition is a win for Prius. Counterintuitively, waiting for the next generation is too.
    Other automakers pushing the shift away from traditional vehicles is how penetration deeper into the market will happen. It's necessary for expansion. This opportunity for catching up helps all involved.
    We obviously find the slow pace annoying. That's how the mainstream market works though. The high-end niche can move rapidly. But with the majority in the middle, speed of change is glacial. Paradigm shifts means someone will lose. That means fighting for survival, even though the inevitable cannot be avoided... only delayed.
    That's why Toyota's effort to offer an affordable plug-in option is so important. They are well aware of how long it takes to refine a design and not incur increase cost as a consequence. Being able to share improvements with the regular model makes competing with the wide variety of competitors, including their own traditional vehicles, is a major benefit.
    Notice how much of a non-issue the switch to lithium has been so far. Both the 7-seat Prius wagon and the PHV work well with it. Although still expensive compared to NiHM, the new battery type has proven resilient in addition to being more efficient. Increased competition will help drive down the battery cost. Toyota is positioning to take advantage of that.
    bwilson4web likes this.
  10. Trollbait
    12,829
    Agree with most of these.
    3. That's how I use my Sonic's remote start on cold mornings. Most use it to turn on the car and idle it for a warm cabin though. Likely real world use will drop overall fuel economy.
    9. This requires a change in federal and/or state regulations.
    10. Improves aero, but decreases styling for most of the public. Could drive away sales with 'funny' looks.
    7. There isn't a transmission filter. I understand it doesn't have all the wear components of an automatic, but I believe most manual transmissions have a more aggressive change schedule than the Prius.
  11. austingreen
    13,714
    4,232
    Austin, TX, USA
    Yes I was only talking short term, until the next generation prius comes out. :) I hope toyota knocks it out of the park, but know it will only look like small changes on paper.
    +1
    These more efficient compacts also are helping push new rubber compounds for a better combination of low rolling resistance and handling. They also have electronic power steering, which may push those costs lower than older less reliable power steering systems. This should help reduce the hybrid premium.
  12. El Dobro
    El Dobro A Member
    7,106
    3,282
    Gasoline and diesel prices are on the rise again. Let's see how February does.
  13. bwilson4web
    16,535
    I was expecting gas prices to increase as this is the time of year when they traditionally increase. But Thursday, Feb 6, I bought a tank for $3.03/gal and this evening I saw gas advertised for $2.99/gal. Granted, Atlanta and cities near Huntsville were shutdown due to snow and ice storms. Highways became parking lots so gas sales would have been suppressed. Still, this is an impressive decrease, regardless of how brief . . . the second week of February. But February is not yet over.
  14. austingreen
    13,714
    4,232
    Austin, TX, USA
    The predictions for automarket recovery really are march or april. We still have the cold weather this month that may keep people away. Every year gas prices rise in feb-april because of changes from winter to summer blends. THis is especially true in california where carb requires large numbers of different blends, and oil companies rebel by doing maintenance slowly to cause a bigger spike.
    Historical Gas Price Charts - GasBuddy.com
    This year with the weather febuary looks behind on gas prices rising. They will rise, but eia projects gas prices on average will be lower this year than last and lower in 2015 than this year. Predictions are that hybrid market will still grow this year more than a growing automarket, but lower gas prices likely mean less growth and a likely disapointing Febuary.
  15. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    How odd are some collections... :D
    25 Strangest Collections on the Web - Neatorama
    Trollbait and austingreen like this.
  16. El Dobro
    El Dobro A Member
    7,106
    3,282
    Fuel prices were dropping around here fairly steadily over the past few weeks, but jumped literally overnight from 5 to 15 cents a gallon. With diesel fuel running $4+ now, I am not missing the TDIs.
  17. telmo744
    2,181
    769
    Portugal
  18. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    telmo744 likes this.
  19. Robert Holt
    Robert Holt Senior Member
    1,313
    890
    Or Russia invades the Ukraine and provokes a new Cold War!
