Japan hit by 8.9 earthquake w/tsunami
Discussion in 'Fred's House of Pancakes' started by Trebuchet, Mar 11, 2011.
  1. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    We have following map from our government
    Ken@Japan
  2. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I've had radioactive goo a few times too. Difference is it's in a form that doesn't stick around in the body very long.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Another crazy video of the power of the tsunami :(
  4. Trebuchet
    Trebuchet Senior Member
    3,772
    936
    43
    It would seem that if caught in a tsunami survival in a car is about as likely as survival in a mobile home during a tornado. :eek: Although I did hear of one old couple caught in their car during the tsunami survived but I'm quite sure it wasn't anywhere near there.
  5. tochatihu
    tochatihu Senior Member
    9,784
    3,769
    Kunming Yunnan China
    2001 Prius
    Things appear to be degrading. When BBC reports 'ten million times normal' that's when I, within one to two hundreds km radius would start taking those iodine pills.
    Many (I might say 'we') assailed the panic buying of KI pills, but now it's show time.
    If you are near field, the point is to flood your thyroid with the happy I isotope, in advance of whenever the unhappy I isotope might arrive. If your kidneys or other internal organs do not work well, don't flood yourself with KI. However, sadly, AFAIK there is no plan B.
    If you are far field (>200 km), I say do nothing. If you have stockpiled KI pills, consider donating them to the near field. Attend to the news media, such as it is.
    Particulate-filtering face masks do nothing against 131I because it is a gas. Activated charcoal facemasks (the ones that are filled with black stuff) are effective to a degree. I have done no searching whether there is a DIY website describing how to make activated charcoal. "Activating" is nothing more that increasing surface area of charcoal by heating it in the absence of oxygen.
    Good luck Japan. Dang I wish we were not in this situation now. I wish that all of you had convenient access to radiation-monitoring equipment. I started another darn thread about that. Who cares...
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Another false alarm. Something was wrong with the reading.
    Tom
  7. SPEEDEAMON
    SPEEDEAMON Professional Car Nut
    1,556
    606
    Los Angeles
    Sometimes, I think Homer Simpson is running the operation
    2 people like this.
  8. Trebuchet
    3,772
    936
    43
  9. qbee42
    18,058
    3,079
    Northern Michigan
    How do we know he isn't? They all wear those white suits, so as to not be identified in a lineup.
    Tom
  10. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    From what I read,the worker who took the reading evacuated before doing a 2nd reading to verify.
    That doesnt necessarily mean the first reading was false.
  11. qbee42
    18,058
    3,079
    Northern Michigan
    Subsequent news releases have stated that it was. However, it was for Iodine 134, which only has a half life of 53 hours. Unless more contamination is added, Iodine 134 levels drop very quickly.
    Tom
  12. a_gray_prius
    2,927
    783
    IL
  13. qbee42
    18,058
    3,079
    Northern Michigan
    Thorium 232 (half-life = 1.406×10^10 years)
    Thorium 209 (half-life = 7 mS)
  14. a_gray_prius
    2,927
    783
    IL
    Neither of those are used for medical applications. My post edited.
  15. qbee42
    18,058
    3,079
    Northern Michigan
    I should hope not. I posted them to show the wide variation in half-life, even from isotopes of the same element.
    Tom
  16. tochatihu
    9,784
    3,769
    2001 Prius
    Indeed TEPCO (per BBC) has withdrawn their '10 million' report. Replaced by the puddles in question near reactor two confirmed at 1000 mSv/hr.
    The facility was evacuated, and it is not clear when/if the workers may return. Indeed if the pddle is dominated by 131I it will decay quickly.
    But, while no workers on site there will be a great reduction on what can be done for thermal and pressure control. There is no plan being publicly promugated on how this is going to be resolved.
    This puddle was obviously unexpected and were it related to a containment vessel pressure venting, they might have said so. Absent that, and absent published pressure readings from reactor 2 containment, reactor 2 containment has failed. If this massively interrupts onsite work, more containment failures will follow.
    I wait for you here to disagree with these conclusions/speculations. I wait for TEPCO to inform the public.
    Ken, is there an nsc.go.jp update since March 23?
  17. fuzzy1
    10,454
    53 minutes, from everything I've seen. So it drops by a factor of 100 million per day.
    Which also means that whatever is being detected is being made now, not left over from earlier problems or from before the reactor scram.
  18. bisco
    51,948
    they found iodine in rainwater in massachusetts today.
  19. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Don't overlook the bigger picture. The iodine is only one of the many, many fission products released in this disaster. There are a great many others scattered inside the facilities that make them too dangerous to do any sustained work for years. Too much time is being wasted having a small overwhelmed TEPCO crew do what needs to be a national emergency undertaking, not a utility bandaid job.
  20. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Or the amount released is immense. Note that a lot of decay products come from decay chains, not the immediate fission.
